Old 07-22-2015, 03:46 AM   #1
soulreapersteve
Contract? /人◕ ‿‿ ◕人\
soulreapersteve's Avatar
Tire Recommendations
Hello all,
In the near future, I will be replacing the stock wheels for these (57xtreme 17x9.0 +40):
http://www.evasivemotorsports.com/mm..._Code=57xtreme
Here is where I am requesting help. I do spirited drives on many twisty roads and enjoy the very little effort it takes to slide the tail end out with the stock Primacys. After a few hours of reading/research using the stickied threads, calculators, etc, it appears the stock tires will not fit safely onto the new wheels I'm planning on purchasing. May I get some recommendations on tires similar to the Primacys that will safely fit?
Thanks!
*********Extra tidbits of info*********
- I would get the 17x7 (which the stock tires will fit) but it's not concave enough compared to the 9's, looking at the pictures posted on this forum.
- Keeping stock suspension/height.
- I've been using the following thread/post for information so far. Those 245/40-17 Federal SS-595's look to be grip-orientated tires. http://www.ft86club.com/forums/showthread.php?t=58968
http://www.ft86club.com/forums/showp...3&postcount=20
The Twins make me smile
Old 07-22-2015, 03:57 AM   #2
swarb
595ss are noisy, cheap, and can feather along the tread edges(thus making more noise). They don't have much more grip(if at all) than the stock primacys. They also run slightly larger than advertised.
They do look good(square shoulders) and are extremely cheap. I'm satisfied with them at the price point. One of the better bargain bin tires.
The Following 2 Users Say Thank You to swarb For This Useful Post:
Jolt182 (07-24-2015), soulreapersteve (07-22-2015)
Old 07-24-2015, 03:38 AM   #3
Jolt182
Jolt182's Avatar
Drives: Asphalt FRS
I have Federal SS-595 tires. They are pretty grippy but they do make a bit of noise. Fortunately you'll only hear it if you drive in complete silence. I never do so I never hear them. As Swarb said they do run large. To large for my tastes, the side walls are pretty bulgy but I also didnt want much stretch so I guess I cant complain when it comes to that. If you'd like a pic of how they look on 18x9.5's I can post one up. For the price though they are on point. No doubt about that.
Jolt182 is offline   Reply With Quote
The Following User Says Thank You to Jolt182 For This Useful Post:
soulreapersteve (07-24-2015)
Old 07-24-2015, 12:10 PM   #4
soulreapersteve
Please do post a pic! Looking at the price of the 595s compared to the Primacys, they are a bit cheaper. I also don't want a lot of stretch so I wouldn't mind the bulgy part.
Old 07-24-2015, 11:05 PM   #5
Jolt182
Jolt182's Avatar
Drives: Asphalt FRS
These tires stick just a hair past the rim just FYI.
soulreapersteve (07-25-2015)
Old 07-24-2015, 11:33 PM   #6
ajaxthebetter
Drives: 2014 Subaru BRZ LTD 6MT
I'm on Federals, too. Definitely run on the meaty side, which I love the look of. Even so, the sidewall doesn't seem to flex much. I believe they do have more grip than stock--my speeds reflect this, I feel, but my TC lights are coming on quite often. Maybe it is only marginally better grip--or maybe I just need an alignment. (Recently lowered car; camber bolts; new wheels/tires).
They are noisy. They seem to break away in a linear fashion. Paid 380 bucks shipped from vendor on Ebay. Counting them as a steal, even if only a band aid.
ajaxthebetter is offline   Reply With Quote
Old 07-24-2015, 11:55 PM   #7
Jolt182
Jolt182's Avatar
Drives: Asphalt FRS
Odd that your getting a TC light. Probably an alignment issue. I can barely get my TC light to pop on. Idk how wide of wheels your on though. That may be making the difference as well.
ajaxthebetter (07-25-2015)
Old 07-25-2015, 12:19 AM   #8
ajaxthebetter
Thanks, man. I'm 235/40/17, so a solid size. I should probably just go get it aligned for peace of mind. It often times just cuts me off at somewhat tame speeds. I drove with stock wheels/tires with this new suspension for a couple weeks and didn't have any odd amount of lights--I may just be driving it a bit too excitedly.
Was doing near 65 and had my drivers side tires over the rumble strip and it was flashing like crazy. The thing is, I don't feel the tire losing grip. Although, by the end of the run today I was able to go around a tight corner with tires wailing, no lights. High speed.
Had them on for a week--might just now be spitting off the top layer and getting into the meat of the tire?
The Following User Says Thank You to ajaxthebetter For This Useful Post:
Jolt182 (07-25-2015)
Old 07-25-2015, 12:43 AM   #9
Sammakko
Bilge monkey
Sammakko's Avatar
Drives: '13 BRZ, 82 starlet
i just ran through a set of BFG Rivals (2013 design) and loved em.. ONLY when they were warm though. not too loud, and really took a beating (didn't mind being run hot).
i'm now running Kumho V720s, i'll give a review of them after the autocross event.
are you looking for a tire that'll last more than 10k miles?
Sammakko is offline   Reply With Quote
Old 07-25-2015, 01:47 AM   #10
Fastbrew
Drives: 2014 Pearl White BRZ
I run 255/40/17s in Bridgestone Potenza Pole Position and then Hankook RS3 in Summer on this same setup.
http://www.ft86club.com/forums/showthread.php?t=67968
Nice choice of wheel! I like this car on 17s.
However - if you don't do anything for the HP - you are going to have a harder time slipping that back end.
Fastbrew is offline   Reply With Quote
Old 07-25-2015, 03:26 AM   #11
soulreapersteve
Yeah, I'm looking for ones that'll last for more than 10k miles. I don't do any auto-x or track stuff. Only spirited twisty backroad runs with people and the local driving group. And even then, it's only once every 2 weeks or so.
Looking at your tire post, awesome to see there are no rubbing issues. That's one of my main concerns. 255/40 seem too meaty for me, so I'll probably run 245/40. Not much of a difference I presume.
As for HP, not looking into FI anytime soon. Once I pad my savings, I'll go headers + tune and exhaust. Figured a little more pep for now.
Old 07-25-2015, 04:16 AM   #12
Jolt182
Jolt182's Avatar
Drives: Asphalt FRS
If the car is throwing a TC light at you during what would seem odd times id get it aligned. I have only got the light to pop when im trying and i mean really trying. Like flooring on a U-turn lol. Im pretty wide though at 255/35 so thats also a factor.
Old 07-25-2015, 09:49 AM   #13
ajaxthebetter
Do you know what tire pressure you run? I may fiddle with that a bit too.
Old 07-25-2015, 11:35 AM   #14
Sammakko
Bilge monkey
Sammakko's Avatar
tirerack has the gforce sport comp 2's for 116 apiece right now. it's a great tire, and will last much longer than 10k miles..
The Following User Says Thank You to Sammakko For This Useful Post:
tire recommendations? jarviz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 11-29-2013 04:51 PM
Tire brand recommendations arashishozen Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 11-14-2013 10:12 AM
Tire recommendations Shenks Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 22 09-24-2013 11:46 PM
Tire Recommendations Re~Mix Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 09-16-2013 11:06 PM
Need Tire recommendations please, non track use JoeBoxer Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 26 01-03-2013 04:15 PM
