Old 11-16-2013, 04:35 PM   #1
jarviz
jarviz's Avatar
Drives: Raven FRS MT
tire recommendations?
My tires are in need of replacement - does anybody have any tires they recommend for under $120 a piece?
Just some All-seasons would be fine as I don't plan on driving this car in the snow. Thanks!
jarviz is offline   Reply With Quote
Old 11-16-2013, 04:45 PM   #2
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
Continental ExtremeContact DW. Tirerack has 'em for $110 each. A great tire.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Gary in NJ is offline   Reply With Quote
Old 11-16-2013, 04:54 PM   #3
ZionsWrath
Thanks
ZionsWrath's Avatar
Can you stretch it and get Continental DWS at $129 each?
I have DWS in 235/255 and am happy with them from a DD perspective (also not driven in snow). Still a lot of tread left after 15k miles or so on them.
Old 11-16-2013, 09:02 PM   #4
Gary in NJ
Gary in NJ's Avatar
The DW will perform better then the DWS in dry and wet conditions. Since the OP said snow will not be an issue, the DW is a much better choice.
Old 11-17-2013, 10:26 AM   #5
jarviz
jarviz's Avatar
Thanks! I've heard about those. I'll have to go check them out.
Old 11-17-2013, 10:27 AM   #6
ZionsWrath
Thanks
ZionsWrath's Avatar
Yes but he is in NY and will have to drive in cold and potentially unexpected ice and for sure snow melt/refreeze. If he has another car for winter than sure DW is better, but if this is his only and year round car sans snow, DWS is the better option.
Old 11-17-2013, 10:54 AM   #7
rainmonkey
Drives: BRZ - Dark Grey
what size are you looking for? size affects price as well.
rainmonkey is offline   Reply With Quote
Old 11-17-2013, 10:55 AM   #8
ZionsWrath
Thanks
ZionsWrath's Avatar
stock
Old 11-17-2013, 10:59 AM   #9
rainmonkey
will you be driving around in cold weather? ie inappropriate for summer tires? cuz the hankook v12's have pretty good reviews and are really cheap in stock size
Old 11-17-2013, 11:06 AM   #10
ZionsWrath
Thanks
ZionsWrath's Avatar
He is from NY, so he will have to drive in cold temps if this is his DD
Old 11-17-2013, 12:45 PM   #11
Gary in NJ
Gary in NJ's Avatar
The DW's should not be driven in the snow. Even 1/4 inch of snow will be a dangerous proposition. If there is a chance that you will drive in the snow or in freezing weather, get the DWS.
Old 11-17-2013, 12:47 PM   #12
jarviz
jarviz's Avatar
Are the DW's any worse than the OEM tires in winter?
Old 11-17-2013, 04:30 PM   #13
Gary in NJ
Gary in NJ's Avatar
No, they are the same...they both suck in snow, ice or sub-freezing conditions. I understood your original post as you would not be driving your car in the winter. Since you are driving in the winter, get a proper winter tire. Winter tires aren't just designed for snow, they are designed to work in temperatures below 40F. If you can only afford one set of tires, the DWS would be the way to go, but you will be trading cold weather performance for handling and stopping performance in the months when it is warmer then 40F.
Old 11-17-2013, 05:44 PM   #14
hanabie
hanabie's Avatar
Drives: WRB LMTD '13
it depends on your size. I have not seen any DW and DWS size 245 above are less than 120 each. They are pretty much close to 160-200.
hanabie is offline   Reply With Quote
Tire brand recommendations arashishozen Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 11-14-2013 10:12 AM
Tire recommendations Shenks Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 22 09-24-2013 11:46 PM
Tire Recommendations Re~Mix Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 09-16-2013 11:06 PM
Inexpensive but Safe Tire Recommendations? Anthony Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 15 08-13-2013 11:18 PM
Need Tire recommendations please, non track use JoeBoxer Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 26 01-03-2013 04:15 PM
