| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
Drives: MT WRB BRZ Limited, 2007 911s
Good Floor Jack Suggestions
Since this is the first car I really care about, I'm going to start doing most of the maintenance myself. Does anyone have any suggestions for a good quality (and not crazy expensive) floor jack that will last?
#2 |
I'm sure a Craftsman floor jack will work just fine, and priced reasonably well too. Then again, since the car sits quite low, you might need a low profile floor jack. Here's one:
http://www.sears.com/craftsman-2-1-2...2&blockType=G2 |
#3 |
Conedancer
Drives: 2013 Subaru BRZ SWP
Join my BRZ/FRS FB Group ![]() Thanks to:Kartboy/Wheeldude/Nameless Performance /Gaurd Transmission LSD |
#4 |
FIA Licensed Rally Driver
#5 |
Señor Member
Drives: 2013 SSM DZE BRZ
The jack you buy is much less important than the jack stands you buy IMO. Whatever you end up buying, make sure your safety equipment is top-notch.
#6 | ||
Drives: M3
#7 |
Running in the 90s
Drives: 2014 Scion FR-S Monogram
+1 :happy0180:
藤原とうふ店(自家用)
MattR's Tofu Runner |
#8 |
*****istrator
Drives: 2013 Scion FR-S 10-Series M/T
if you plan on adding a front lip or a low aftermarket bodykit, get the flattest jack you can buy..
#9 |
Senior Member/Old Fanboi
Drives: 2000 2ZZ-GE MR2 Spyder HT
The Harbor Freight low profile aluminum racing jack is great because it can fit under anything that is above about 3.3 inches off the ground at the jack point. My jack points are 3.7 inches. I bought a 1.5 ton for 59.99 but I do wish that I would have gone for the bigger version. The other nice thing is it only takes 3 pumps to raise the car completely.
Some question Harbor Freight quality and durability but I have had no issues. Plus, if you look at their ads in MT, C&D or R&D you will find a 20% off coupon that you can use when you buy one (even if on sale).
So many modders have more cents than sense!
#10 |
Gundam Meister
Drives: A Gundam
Yeah, getting high quality jack stands are the most important.
#11 |
Site Moderator
Drives: Stuff
I've been through 4 or 5 hf aluminum jacks now, maybe I use mine more than others. Two of them still work but none are quick pump anymore.
AC Jacks used to be awesome but they shutdown
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#12 |
Drives: Infiniti G35X
I had a friend whose aluminum jack just broke after a few months.
I would suggest the other Harbor Freight ones. The Low-Pro Rapid Pump ones are nice. I believe they have it on sale at HF for $80? I haven't heard of any problems with their jack stands, either. |
#13 |
First 86
They break all the time. Autox'ers use them cause they're cheap to replace and you don't care as much when they break/get lost/stolen/fall off your trailer/run over/caught on fire/tossed when a midget is not available.
Scion First 86 in Lexington KY - Firestorm 6MT - Delivered May 17, 2012
Mods: Motegi 17x7 TrakLites, BFG Rivals, K&N 33-2300 Filter, Nameless Perf. Track Pipe, TRD springs & rear bar, Hotchkis front bar (eh), Kask trailer hitch |
#14 |
Drives: Mercedes C320, S2000
For home use I also use a pair of ramps. I trust them much much more than a jack and have had good experience with them so far.
| NAV Radio suggestions | Dadhawk | Electronics | Audio | NAV | Infotainment | 20 | 07-31-2013 02:25 PM |
| Floor mats and Bespoke Stereo upgrade not available? | DarrenDriven | Scion FR-S / Toyota 86 GT86 General Forum | 23 | 06-09-2012 09:30 AM |
| Video: Jack Hollis and his FiveAD FR-S | poormans_LFA | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 32 | 05-22-2012 06:07 PM |
| Questions for VP of Scion Jack Hollis. | SpeedR | Scion FR-S / Toyota 86 GT86 General Forum | 79 | 04-08-2012 07:51 AM |
| Geneva Show Floor FT-86II | DIG1992 | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 02-28-2011 11:55 AM |
