Old 08-07-2015, 02:30 AM   #1
Aztec
Lost in the twisties
Aztec's Avatar
Drives: 2014 BRZ Dark Gray Metallic
4.56 FD Swap Parts and Labor :)
Just got back from getting the final drive swap completed by a local shop in the NW area. Got the ring/pinion and the install kit from weir performance for a little over $400
Found a shop in Portland, OR that had done SEVERAL final drive swaps on the 86 platform, and he's incredibly fair for his rates!
Got the entire labor complete for around $370
$300 for labor
$70 for supplies
It was done in a single day. I just need to change out the fluid in around 1000 miles after the gears have broken in. Absolutely NO whine at all from incorrect backlash. Entire car has more torque, and when this mod is paired with E85. I don't believe there is a better NA setup that you can do!!
[ame="https://www.youtube.com/watch?v=occuNSTlkIo"]UEL E85, 4.56 FD swap 0-80MPH - YouTube[/ame]
Just wanted to share my experience
NEW CAR!🚨🏎️⛽
2014 BRZ: Edelbrock SC, CSG ZachTune, Jackson Radiator/Oil cooler, lightweight flywheel, CNT UEL, Berk OP/FP, Ark Grip Catback, Carbon fiber Driveshaft
Aztec's Build Thread
Aztec is offline   Reply With Quote
The Following 16 Users Say Thank You to Aztec For This Useful Post:
Carlysh (08-11-2015), Cop (02-08-2016), DustinS (02-09-2016), Griever423 (02-07-2016), housecat (08-07-2015), juliog (08-07-2015), kodyo (08-07-2015), KoolBRZ (08-07-2015), Lonewolf (02-07-2016), NLSP (08-07-2015), NWFRS (08-07-2015), RJasonKlein (08-07-2015), stockysnail (08-09-2015), swarb (08-07-2015), TheBRZsKnees (11-09-2017), tmaz42o (06-14-2020)
Old 08-07-2015, 05:59 AM   #2
swarb
incorrect backlash? how much is the correct amount?
Old 08-07-2015, 09:03 AM   #3
mrk1
Drives: Sterling BRZ Ltd
I think FD changes are the best way to change the driving experience of this car, be it up or down.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 08-07-2015, 11:05 PM   #4
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
Backlash would make a deccel whine and pinion depth would make and accel whine.. both are very important. i just took out my gear to prep for turbo.. it feels like my gears got so long going 4.1
IG-Joey_Soul
Progress Thread Ported billet 20G
Grip Ronin is offline   Reply With Quote
The Following User Says Thank You to Grip Ronin For This Useful Post:
Ultramaroon (08-08-2015)
Old 08-08-2015, 12:59 AM   #5
mrk1
I installed MFactory gears and I got a slight whine all the time over about 50mph, MFactory said thats completely normal with there gears.
The Build Thread
Old 08-08-2015, 01:01 AM   #6
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
If anyone needs a spare stock diff to do a gear swap on so your car isn't down, I have like 5 sitting here lol
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
Old 08-08-2015, 01:10 AM   #7
Aztec
Aztec's Avatar
Or find a shop that is able to do the swap in one day
Took @Ultramaroon for a drive out in the twisties outside of portland. He hammered through some of the gears and he loved it
NEW CAR!🚨🏎️⛽
The Following User Says Thank You to Aztec For This Useful Post:
Old 08-08-2015, 01:13 AM   #8
qwerty66
Drives: frs
hey spitfire
how much for one shipped to Vancouver Canada?
qwerty66 is offline   Reply With Quote
Old 08-08-2015, 01:42 AM   #9
It's quite dramatic. First gear is still necessary/usable but second is no longer too tall for tighter switchbacks. Second-third-second transitions are a joy.
The corn juice doesn't hurt either.
Well done!
Aztec (08-08-2015), Sammakko (08-08-2015)
Old 08-08-2015, 04:02 PM   #10
NLSP
NLSP's Avatar
Drives: 2014 Ultramarine FR-S
Sigh...sounds like I HAVE TO add this to the to-do list
Old 08-08-2015, 04:12 PM   #11
Sammakko
Bilge monkey
Sammakko's Avatar
Drives: '13 BRZ, 82 starlet
what's RPM at cruising speed now? 80mphish
Sammakko is offline   Reply With Quote
Old 08-08-2015, 04:20 PM   #12
What's the original ratio? I don't memorize that stuff.
Old 08-08-2015, 04:28 PM   #13
Aztec
Aztec's Avatar
Original ratio is 4.1. Should be about a 10% increase of torque to the wheels, as well as an increase of 10% approx RPMs
80mph is 3800-3900 i believe?
I'll go check brb...
NEW CAR!🚨🏎️⛽
Old 08-08-2015, 05:35 PM   #14
Aztec
Aztec's Avatar
Added a quick 0-85ish video so you can see how much the shorter ratio affects car
Also added to first post
NEW CAR!🚨🏎️⛽
The Following 5 Users Say Thank You to Aztec For This Useful Post:
emirdtm (08-09-2015), Griever423 (02-07-2016), Lonewolf (08-09-2015), NLSP (08-08-2015), Stealthy (08-11-2015)
2jz swap parts Uhoh_Oreo Transmission and Driveline 2 07-07-2015 06:55 PM
Edge wants >$1000 for a suspension swap... NOT INCLUDING PARTS!!! donoman Northern California 41 07-04-2015 10:44 AM
2jz swap parts Uhoh_Oreo Engine, Exhaust, Bolt-Ons 10 03-13-2015 08:26 AM
NY:BRZ & FRS PARTS SWAP THREAD! SalM NY / NJ / CT / PA 16 07-08-2014 11:07 AM
Now till the end of September receive extra discount on Labor/Parts!! Speed Element Northern California 12 09-09-2013 03:54 PM
