Old 08-07-2015, 02:51 AM   #1
kimy2003
Drives: FT86 M/T
having 100% throttle
was taking some logs and noticed the throttle as the RPM reaches pass 4~5k goes down to 90%. its happening with OTS map. i would like to know if that means the throttle body is not fully open?
and if so how do i fix this so that its always 100%?
kimy2003 is offline   Reply With Quote
Old 08-07-2015, 03:12 AM   #2
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
http://www.ft86club.com/forums/showthread.php?t=34629
http://www.ft86club.com/forums/showthread.php?t=48289
http://www.ft86club.com/forums/showthread.php?t=88069
Old 08-07-2015, 09:45 AM   #3
ShadowSeraph
Tech Master / Car Geek
ShadowSeraph's Avatar
Drives: 2013 AT Hot Lava FR-S
This is normal for the maps. From my tinkering lately, It looks like this can be modified by changing values in the Drive-by-Wire Throttle (DBW) > Target Throttle Plate Position Maximum(Requested Torque) table.
Perrin: Crank pulley, 3" Cat back, Nameless: 3" FP/OP
GFB: water and alternator pulleys
Borla: UEL Header
Hyper Black ROTA T2R 18x9.5, DSS CF Shaft for AT
-= OFT - Stage 2 UEL E85 - fine tuned by me. =-
ShadowSeraph is offline   Reply With Quote
Old 08-07-2015, 11:01 AM   #4
Kodename47
Kodename47's Avatar
Drives: UK GT86
Nope, that table will make no difference AFAIK. It's set to max throttle opening at 100% requested torque across the entire RPM range as standard anyway. I've already tried increasing the values by a little and it made no difference.
What have you tried?
I'm actually in the process of testing myself, have been testing the calculated torque and requested torque table relationship. Hint, there isn't any on the MT.
.: Stealth 86 :.
Kodename 47 DJ:
Old 08-07-2015, 12:33 PM   #5
ShadowSeraph
I admittedly am still quite new to tuning and figuring the tables/relationships out/ learning what it is all about. I am an IT guy branching out into car programming. I did not see the OP was driving a M/T... I have an auto. I could have been reading it wrong, but after a number of runs and logs on the street, it appeared to make a difference (at least on an auto) modifying the previously mentioned table as the %'s did increase across the RPM's. Eh.. time to tinker around with things more tonight... maybe modify the other couple tables along with this one too in low increments.
Borla: UEL Header
Old 08-07-2015, 05:39 PM   #6
Kodename47
Kodename47's Avatar
Drives: UK GT86
I was actually asking how you changed the table. But simply raising the throttle angles at 100% desired torque makes no difference. MT or AT should both react the same to changes to that table too.
The calculated torque tables are more for AT and don't seem to do much on a MT from my testing.
.: Stealth 86 :.
Kodename 47 DJ:
Old 08-08-2015, 04:53 AM   #7
kimy2003
Drives: FT86 M/T
i see that majority of the posts say that its normal, but when i see the shiv's log i see most of time his hitting 100% TP through out at throttle reading from OFT log. so i would definitly like to know how he gets that.
Old 08-08-2015, 06:49 AM   #8
steve99
Drives: FT86
if you log throttle pedal position you will see 100%
if you log the actual throttle plate position in the throttle body you will see less than 100% and it tapering off at higher rpm.
unless the logging device rescales the data it extracts from ecu
Shiv@Openflash (08-11-2015)
Old 08-08-2015, 08:53 AM   #9
kimy2003
Drives: FT86 M/T
so,,, that is now back to my initial question.
throttle plate position, can that stay 100%? or is there even any loss from it which i should care about?
Old 08-08-2015, 04:08 PM   #10
steve99
Drives: FT86
If you fiddled with the throttle control tables you may be able to do that
its not something i have messed with
Adjusting DBW (drive by wire ) throttle tables
Note these tables are complex in their interaction and you may produce unwanted or undesirable results.
Read this thread first by @mad_sb
http://www.ft86club.com/forums/showthread.php?t=28453
see thread for autos
http://www.ft86club.com/forums/showthread.php?t=80600
@Wayno has used the "requested Torque B" DBW table from the manual roms in auto roms with good results
Old 08-08-2015, 06:57 PM   #11
Kodename47
Kodename47's Avatar
Drives: UK GT86
I'll chime in with my latest test using ECUtek. This is a 3rd gear WOT pull:
However I also logged desired TPS Voltage and actual TPS Voltage. Both of these are 4V for the entire range. So I've come to the conclusion that the throttle isn't actually shutting at all, but for some reason the ECU shows that it does.
.: Stealth 86 :.
Kodename 47 DJ:
Old 08-08-2015, 08:12 PM   #12
ztan
Drives: Toyota 86
Do you know what the RAM addresses are for these measurements? There are plenty of throttle and request values all through the code, to tease these things out, we need to know exactly where in RAM the values are pulled from.
A01G:
I've been logging FFF89030 for my throttle which does not fall off at high RPM. Throttle position sensors TPS1 and TPS2 RAM addresses closest to the 16 bit ADC pull are located at FFF87C50 and FFF87C54 respectively.
ztan is offline   Reply With Quote
Old 08-09-2015, 11:28 AM   #13
Kodename47
Kodename47's Avatar
Drives: UK GT86
A01G:
No idea. It doesn't state in ECUtek. I have 4 TPS voltage parameters, 2 log a flat value throughout the entire log, so I discounted those. I then had 2 that are very similar, one has max of 4.22V and the other max is 4v. Seeing as the desired v matches the 4v parameter i've compared that value. Both of the TPS voltage parameters stay at their max value through an entire WOT pull though which confirmed it for me.
.: Stealth 86 :.
Kodename 47 DJ:
The Following 2 Users Say Thank You to Kodename47 For This Useful Post:
burdickjp (08-10-2015), ztan (08-09-2015)
Old 08-10-2015, 02:24 PM   #14
burdickjp
Drives: 2013 ultramarine Scion FR-S
What do you have done to the car? I wouldn't worry about it unless you're boosted.
burdickjp is offline   Reply With Quote
oft, throttle
Part throttle faster than full throttle brn12345 Engine, Exhaust, Transmission 38 10-21-2021 12:20 PM
do you know what your throttle is doing? 7thgear Tracking / Autocross / HPDE / Drifting 17 06-19-2014 05:38 PM
AFR of ~15 during throttle but up to 20.3 off throttle, idles at ~15 ok? tracerit Engine, Exhaust, Transmission 11 02-15-2014 12:44 PM
5th Gear and 6th Gear 0% throttle to 80% throttle gear crunch? kharn83 Issues | Warranty | Recalls / TSB 9 08-06-2012 07:44 PM
