Old 06-18-2014, 09:49 PM   #1
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
do you know what your throttle is doing?
nerding over some data I pulled from my last autocross and compared it to a friend's
top is pedal position and bottom is throttle position
"what does this mean?"
given that this graph represents 350 meters of track, there is a measurable latency between when you're on the gas and when the throttle reacts
in the case of my friend, who at times stabbed the gas, the response was almost nothing..
BRING BACK CALBES!!
1st graph is me, 2nd graph is my friend
The Following User Says Thank You to 7thgear For This Useful Post:
hmong337 (06-19-2014)
Old 06-19-2014, 02:22 AM   #2
D K
Stig's dark passenger
Was the traction control on?
D K is offline   Reply With Quote
Old 06-19-2014, 03:15 AM   #3
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
I'm old school and will always be. After 1 year of owning this car, I still hate the dbw!
CABLES FTMFW!!!!
hmong337 is offline   Reply With Quote
Old 06-19-2014, 05:09 AM   #4
What was the status of VSC?
Old 06-19-2014, 08:39 AM   #5
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
both tc and vsc was disabled via the 5-second press (not ready for the pedal dance quite yet)
in my car anyway... i'll ask my friend, but he's also on top of his game so I doubt he left em on.
interstingly enough our net times were the same for this configuration (with me 0.4s faster)
Old 06-19-2014, 10:51 AM   #6
renfield90
The Stig's German cousin
7thgear, It sure looks like TC was cutting in - see the drop in throttle position during the first long sustained 100% pedal section. Unless those graphs are reversed...then we have a safety problem (or a performance enhancement, depending on your view).
Old 06-19-2014, 10:57 AM   #7
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
I'm not seeing what you're seeing.
there are two graphs, the blue and red, they represent different drivers.
within each graph, however, Top is pedal, lower is throttle, both graphs are aligned (id overlap them but I can figure out how to change colours for same-lap/car but different graphs)
Old 06-19-2014, 11:41 AM   #8
AustinTX
Pawn in game of life
AustinTX's Avatar
Drives: 19 STX BRZzz
Seems like the differences are mostly the smoothing of transient inputs, for example the missing blip in the center of the lower graph. This difference may be a physical constraint of the motor used to drive the butterfly, but it is more likely an effect of the ECU controlling transient inputs to protect the engine. Both graphs show little gas pedal modulation, but the lower graph shows some extremely aggressive throttle input. Tip-in enrichment and timing are probably going crazy on the lower graph. Time to drive smoother
Autocross nut
AustinTX is offline   Reply With Quote
Old 06-19-2014, 11:45 AM   #9
sluflyer06
Drives: 2014 BRZ Ltd - DGM
CABLES FTMFW!!!!
What were you driving before, basically all cars have gone DBW years and years ago. I mean by WRX was 8 model years older than my BRZ and it already had DBW.
2014 BRZ Ltd. - DGM
E30 318is trackday funday car
E46 323ci vert
sluflyer06 is offline   Reply With Quote
Old 06-19-2014, 11:50 AM   #10
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
Originally Posted by AustinTX View Post
Both graphs show little gas pedal modulation, d
so modulating the throttle for over 80% of a run is little modulation?
I agree that my friend is more stabby with his gas, but he is trying to get the car to rotate by powering through turns while I'm trying to ensure that it doesn't plow through the turn.
given that our end times were so close together, the real point to take away is that I need to be more aggressive and he needs to dial it back a little.
Old 06-19-2014, 11:59 AM   #11
hmong337
Emperor JDM
hmong337's Avatar
Everything 90's. My FRS is my first actual newer car.
Don't you guys miss revving the car from under the hood? Haha.
The Following 6 Users Say Thank You to hmong337 For This Useful Post:
chas3wba0 (06-19-2014), CSG Mike (06-19-2014), JRP (06-20-2014), MINOCIN (06-20-2014), tahdizzle (06-19-2014), Trac Toy (06-19-2014)
Old 06-19-2014, 12:40 PM   #12
AustinTX
AustinTX's Avatar
True, the upper one doesn't look bad at all considering this is still a momentum car.
Autocross nut
Old 06-19-2014, 01:17 PM   #13
Interesting. I use stabs to rotate the car too, but I've never had the car flat out ignore it like that before.
Old 06-19-2014, 01:33 PM   #14
celica73
Drives: '13 BRZ / '11 Outback / '06 Tundra
what is the data sampling rate?
celica73 is offline   Reply With Quote
Part throttle faster than full throttle brn12345 Engine, Exhaust, Transmission 38 10-21-2021 01:20 PM
AFR of ~15 during throttle but up to 20.3 off throttle, idles at ~15 ok? tracerit Engine, Exhaust, Transmission 11 02-15-2014 01:44 PM
throttle dip? JDM FRS Issues | Warranty | Recalls / TSB 18 07-07-2013 04:50 AM
5th Gear and 6th Gear 0% throttle to 80% throttle gear crunch? kharn83 Issues | Warranty | Recalls / TSB 9 08-06-2012 08:44 PM
