Old 08-06-2015, 06:37 PM   #15
Icanfaptothis86
tickle fight referee
Icanfaptothis86's Avatar
Drives: 2015 Subaru BRZ
Originally Posted by PST View Post
Our 2015 BRZ was 54.5% front with a full tank of gas and 175 lbs of driver. Also worth noting, the LF/RR cross was 50.1%. That's extremely hard to achieve, even with adjustable shocks. Those numbers were taken on Intercomp scales on a poured epoxy surface plate.
To the OP, what exactly are you trying to change about the car? You're saying you want to improve the balance of the car, but you didn't post your previous balance numbers.
Can you link to details/specs on the car ?
Celery man
Electrical space wizard
Icanfaptothis86 is offline   Reply With Quote
Old 08-06-2015, 07:34 PM   #16
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
Our car? Sure.
http://www.ft86club.com/forums/showthread.php?t=90384
GSpeed is offline   Reply With Quote
The Following User Says Thank You to GSpeed For This Useful Post:
Icanfaptothis86 (08-07-2015)
Old 08-07-2015, 02:25 AM   #17
mokinbird87
BOXER FR
mokinbird87's Avatar
Drives: WRB BRZ Limited
oh no specific numbers yet. solely all butt dyno I would like for the front end to have less inertia and turn in a bit sharper. There are lots of ways to achieve this, but I want to do it with removing the weight off the nose first, and then move onto other procedures ( stiffer springs in the rear, etc). extra camber and caster helps tremendously from the Raceseng plates, but imagine how much sharper it would feel with less weight in the front! It`s not really apples to apples but the S2000 would be a good benchmark here.
mokinbird87 is offline   Reply With Quote
Old 08-07-2015, 04:17 AM   #18
MaximeT
MaximeT's Avatar
Drives: GT86-ACE-JRZ-RPF1-Essex
If you got lightweight wheels, battery, brakes, empty windshield fluid, the only thing missing is the front crash beam. (Which I would like to keep). You're done with weight saving.
You won't get s2000 weight distribution unless you move engine further back.
You have to change functional parts now if you want a different feeling/performance/balance.
You can do tires (more), rear sway bare (more), shocks settings. (Less front compression).
JRZ 12-32 | ACE 350 | Delicious Tuning | RPF1 | Essex Sprint | SPL | Powerflex | My Car
MaximeT is offline   Reply With Quote
Old 08-07-2015, 07:42 AM   #19
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
What's your front toe look like?
It's going to be EXTREMELY difficult to appreciably reduce your polar moment of inertia a significant amount while keeping "street car" status.
Not trying to tell you you're wrong, but I'm afraid you're barking up the wrong tree. There are a lot of other things to change before you have to resort to weight loss. Just lowering our car 1" sped up weight transfer 20% through chicanes.
The Following 2 Users Say Thank You to GSpeed For This Useful Post:
mokinbird87 (08-07-2015), Tristor (08-30-2018)
Old 08-07-2015, 07:59 AM   #20
DarkSunrise
DarkSunrise's Avatar
I remember there used to be some company that made lightweight front LCA's. Robispec I think?
2022 BRZ Build
2013 FR-S Build
Old 08-07-2015, 08:02 AM   #21
MaximeT
MaximeT's Avatar
I think so, never saw the price and availability. I would change coilovers before that.
Old 08-07-2015, 09:01 AM   #22
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Good excuse to get a roll bar. Good safety equipment if you track a lot while shifting the weight balance rearward. And attach a fire extinguisher somewhere behind the center line to shift even more weight rearward.
Intent > Content
The Following User Says Thank You to solidONE For This Useful Post:
Old 08-07-2015, 11:25 AM   #23
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
So I'm assuming an alignment didn't shave enough weight off for you?
-alex
drewbot (08-07-2015)
Old 08-07-2015, 11:56 AM   #24
mokinbird87
BOXER FR
oh yea definitely appreciate the feedback.. that`s why I made this thread you know. things like the faster weight transfer of 20% by lowering 1" is something I would`ve never known. I checked out your build thread and lots of good info there! My alignment specs are: front: -1.5 camber 6 degrees of caster, 0 toe. rear: -1.3, -1.5 (OEM spec) camber, 3/32nd toe in for stability under braking. I guess that contradicts the want of a "sharp" front end but tire preservation is quite important to me I could crank up the rear camber but I dont have adjustment at the rear yet.
Old 08-07-2015, 12:05 PM   #25
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
I understand doing your best to balance the weight of the car, makes sense to me but as others have said it will be very hard to get any seriously noticeable differences.
My question is, what are you doing with the car that makes the balance troublesome?
If it's autoX then the toe will give you more turn in than you could ever want.
If it's track then why not go for aero modifications?
Look up Element Tuning for their balls out time trial car, lots of aero on that to balance the car and add grip.
ineedyourdiddly
Old 08-07-2015, 12:05 PM   #26
Icanfaptothis86
Pardon my ignorance LCA ?
Celery man
Old 08-07-2015, 12:05 PM   #27
mokinbird87
BOXER FR
not a bad idea at all.
Old 08-07-2015, 12:06 PM   #28
MaximeT
MaximeT's Avatar
Lower Control Arm
Making the BRZ ever lighter Alabang BRZ Cosmetic Modification (Interior/Exterior/Lighting) 10 04-16-2014 08:57 AM
Are dry carbon fiber front 1/4 panels lighter than OEM? Superhatch Cosmetic Modification (Interior/Exterior/Lighting) 5 05-27-2013 03:47 AM
Better to go wider or lighter? BRAWL Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 08-02-2012 09:48 PM
Increased whp by having lighter wheels mechaghost Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 26 07-03-2012 12:46 AM
What return from going with lighter wheels? bazguitarman Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 30 06-01-2012 09:35 AM
