Old 08-05-2015, 03:23 PM   #9143
WRB5titch
Drives: WRBrz
I've actually tripped the thermal on the way to vegas with the procede controller going up the big uphill. Held throttle around 35-40% so esc was engaged almost the whole way up the hill.
Forgot to mention that it was also about 108-110 degrees during the climb.
EBSC - dt.FF - MXP CompRS
WRB5titch is offline   Reply With Quote
Old 08-05-2015, 04:10 PM   #9144
Mrrksturr
Drives: 2013 Whiteout FRS
@Sojhinn @DAEMANO
Thank you both for the info and the pics. That seems easy enough to do, doesn't look bad either! How far does the duct go into the engine bay? and where/what to zip tie it to
Mrrksturr is offline   Reply With Quote
Old 08-05-2015, 04:14 PM   #9145
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Originally Posted by Mrrksturr View Post
@Sojhinn @DAEMANO
The duct was only 2-3 ft. (Closer to 2 if I remember correctly) and I tied mine to a strong tube in the bay but it could hold itself in the bay with the hole you need to go through.
Installed Mods:
Old 08-05-2015, 04:26 PM   #9146
Tectoniic
#FiftyShadesOfBlue
Tectoniic's Avatar
Drives: 2015 FR-S
I gotta stop reading this thread..... it only makes the wait worse lol.
Engine/Exhaust: OFT w/ E85 Tune | FT86SF Catted UEL | Invidia Q300 Catback
Wheels/Tires/Suspension: Avid.1 AV-20 18x8.5 +33 w/ 245/35/18 PSS | RCE Yellow Springs | Velox LCAs
Cosmetic: Valenti FT86SF Special Edition Tails | Diode Dynamics Full HID/LEDs | BRZ Fender Garnishes
Tectoniic is offline   Reply With Quote
Old 08-05-2015, 08:33 PM   #9147
Sojhinn
Sojhinn's Avatar
I know a lot of you gave the power sonic battery a hard time but man... 8 months on the shelf and it fired my car right up.
Attached are the duct locations on my brz.
Size:  190.9 KBName:  ImageUploadedByTapatalk1438821210.708419.jpg
Size:  277.5 KBName:  ImageUploadedByTapatalk1438821223.578604.jpg
Installed Mods:
Old 08-05-2015, 09:26 PM   #9148
Urmyson
Is it as easy as just swapping out the motor or do you need a new controller and other parts?
Originally Posted by fenton View Post
Yes.....
Peak of 5.4PSI at 3000
Hold 4PSI until 6200
Drops to 3 PSI at 7200
It feels very fast and super responsive. The tune does need some more work for these boost levels as we went lean on a 5th gear pull from 2700 which caused DAM to drop quite a bit.
We will be working to get the tune refined a bit for the higher boost levels and then book some dyno time in August.
Rob was very happy with the Amperage of the new motor and it should be feasible to run this setup at sea level as well. The last one that i had in August(2014) would have been too powerful for the controller at sealevel.
Urmyson is offline   Reply With Quote
Old 08-05-2015, 11:22 PM   #9149
stevo585
Drives: White 2014 BRZ
It really does .I mean all this thread seems to be is 3 people experimenting there really is no product in the typical sense.
stevo585 is offline   Reply With Quote
Old 08-06-2015, 12:09 AM   #9150
Sojhinn
Sojhinn's Avatar
It's the drawback and brilliance of this system. It's so new that new things are popping up all the time but at its current form it's fantastic.
Installed Mods:
Old 08-06-2015, 01:07 AM   #9151
KoolBRZ
KoolBRZ's Avatar
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
Should you get a Procede if you have an AT? Yes!
Today I drove for the first time with my ESC installed and working with a Procede controller. Last night I finished installing the ESC with the 2 stage switch, and drove it that way during the day. Tonight I installed the Procede controller, loaded @dtek's "standard AT" map, and test drove it around a bit. There is no comparison. It's so much more civilized, and usable with the Procede then it was with the switch. I'm going to have fun creating my own maps. I have one question though. The "prespooling" I read about earlier, is there a way to get rid of it with the Procede software? Because AT's don't need to prespool, ever!
KoolBRZ is offline   Reply With Quote
Old 08-06-2015, 01:08 AM   #9152
Sojhinn
Sojhinn's Avatar
If you want to familiarize yourself with the software I can help. Or if you want me to do it... I can too. Also @dtek Im curious to know what you modified from the map to make it AT and see if its anything we could apply to MT procede map. Though to be honest I don't see how it would be different except without the pre spool.
Installed Mods:
Old 08-06-2015, 02:13 AM   #9153
KoolBRZ
KoolBRZ's Avatar
Is pre-spooling when there is anything over -100 in the 20 load ref column?
Old 08-06-2015, 08:00 AM   #9154
Sojhinn
Sojhinn's Avatar
Bottom line on the chart
Installed Mods:
Old 08-06-2015, 10:58 AM   #9155
stevo585
Yes indeed. So lets stop temporarily at this revision. So others can purchase and enjoy this kit.
Old 08-06-2015, 12:10 PM   #9156
KoolBRZ
KoolBRZ's Avatar
My Procede doesn't go between 0 - 100%. It starts at 20%, and goes to 80%. Is there something wrong with my Procede, or with my map? I mean, everything works, so it couldn't be wiring. So should I remake my own map going from 20% to 80%, or did I tap the wrong wire from the ESC-to-throttle connection? I tapped the red wire, by-the-way, since I have the three-wire 2 stage connection.
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
