Old 08-02-2015, 08:00 PM   #561
Husker BRZ
Go Big Red!!
Drives: 2013 SSM BRZ Limited
[quote=steve99;2343789]
Originally Posted by Husker BRZ View Post
is your intake stock ?
are you running E85 or petrol tune ?
My intake is the grimmspeed. I'm running the 93 tune while I wait for the grimmspeed one from the openflash guys. I can't get them to e-mail me back yet.
Husker BRZ is offline   Reply With Quote
Old 08-03-2015, 01:23 AM   #562
steve99
Drives: FT86
[quote=Husker BRZ;2343840]
have a read of the flashing reset learning link below you can get ecu to set fuel trims in 5 minutes.
Old 08-04-2015, 03:04 PM   #563
JonAvalon
SCBYD0
JonAvalon's Avatar
Drives: 18 BRZ (WRB)
@steve99 @Wayno @phrosty @Shiv@Openflash
I might need some help trying to find whats going on. The AM continues to fluctuate below 1 and if I'm looking at the data correctly I'm knocking quite a bit for being on E85. My car is an auto, this mornings commute I drove it in auto mode the entire time and things looked much better than previous logs. My fuel level was around half tank during the morning drive which is Valero E85. I've been told the one I went to is low content E85. So today during lunch I went to a Racetrac that supposedly has better E85 so I filled up the tank from half. I'm hoping that wasn't a bad idea to mix it? I did some logging after filling up, I'm guessing it has to relearn every time I fill up so should I see it fluctuate like that?
The car technically drives fine, I've been trying to drive carefully but if the engine isn't happy then I certainly want to fix any issues.
Mods:
Stock intake w/ Supertek filter
OFH
OFT
Top Speed Pro 1 Axelback
Stg 2 UEL E85 tune v2.063
Morning Drive 1 & 2 (half tank)
http://datazap.me/u/jonavalon/1st-e8...og=0&data=1-10
Lunch drive 1 (before filling up)
http://datazap.me/u/jonavalon/e85-lu...10&zoom=0-6466
Lunch drive 2 (after filling up, mostly in manual mode)
http://datazap.me/u/jonavalon/e85-lu...og=0&data=1-10
Another log from yesterday evening.
http://datazap.me/u/jonavalon/1st-e8...6?log=0&data=1
JonAvalon is offline   Reply With Quote
Old 08-06-2015, 02:52 AM   #564
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Mods:
OFH
OFT
It likes to knock around 2400 rpm, and although you've logged a bunch of useless stuff instead of engine load, i'm guessing it's around 0.7 g/rev as it's at light throttle.
The AT tends to knock more than MT, worse maf calibration and have higher engine loads, that last one is compounded on E85 and will cause you to have worse fuel economy than MT. Basically, it doesn't run well out of the box like it does on most MT's.
There's already a thread with example AT maps. You just need romraider and the definitions attached to the thread.
Old 08-06-2015, 08:46 AM   #565
gt86persianclub
gt86persianclub's Avatar
Drives: My Boy
Mods:
OFH
OFT
I had same experience with E85 and the knock exist between 2000-3000rpm .
these parameters increase the knock :
1. hot temperature , above 30 celsius degree
2. high load
3. higher height from see level (above 1800m)
gt86persianclub is offline   Reply With Quote
Old 08-06-2015, 09:30 AM   #566
mid_life_crisis
Drives: FR-S 10 #103 AT
http://datazap.me/u/midlifecrisis/lo...&data=4-8-9-10
No power mods, just an Openflash with Wayno's modified tables for AT.
The knock looks excellent to me, only slight corrections and the multiplier is pegged at 1. It looks to me like the ST Fuel trims are all over the place though. Can someone who knows what they're doing provide some feedback please? Thanks.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 08-06-2015, 09:39 AM   #567
steve99
Drives: FT86
I would be more concerned if the STFT was not all over the place :-)
Totally normal have a read here
http://www.ft86club.com/forums/showt...01#post1842501
Old 08-06-2015, 10:55 AM   #568
mid_life_crisis
According to that article, the 15.x AFR is not acceptable. Should I take steps or are those okay where they're showing up?
Old 08-06-2015, 11:06 AM   #569
JonAvalon
SCBYD0
JonAvalon's Avatar
Yea I had a feeling someone would mention engine load. I put it back on yesterday, some of the stuff I left in there from testing but I'll remove them. Here are logs from yesterday with engine load if you want to take a look, no pulls just regular driving.
http://datazap.me/u/jonavalon/aftern...ta=1-3-4-10-11
http://datazap.me/u/jonavalon/aftern...log=0&data=1-3
I honestly didn't know that, good to know. I've been doing countless research and that didn't cross my mind. I hope I'm not trying to come across as a total noob about this stuff. I'm really trying to learn about this; what the data means, what I should watch out for etc. But I think I'm getting slowly a decent grasp of it.
Yep I've been looking at your thread for a while, great stuff. I've been trying to figure out how to do all of that in romraider.
2. high load
Thanks
Old 08-06-2015, 11:24 AM   #570
steve99
Drives: FT86
Have a look at your throttle position when afr is 15 its zero, the ecu shuts off injectors on overun to save fuel this is normal
Old 08-06-2015, 11:40 AM   #571
steve99
Drives: FT86
2. high load
Yea I had a feeling someone would mention engine load. I put it back on yesterday but what else should I add for logging? (IAT?) Some of the stuff I left in there from testing but I'll remove them. Here are logs from yesterday with engine load if you want to take a look, no pulls just regular driving.
Thanks
Ok giving away my secrets here
mod your IAT temp compensation tables as per below to make the retard cut in at lower temps (note mine is in Celsius you will need to convert back to that weird F scale you guys use) and the IAT activation table to make it more aggressive in the problem area.Also the activation table is scaled differently to yours
where i have 0 you use -100
50 you use -50
29.7 you use -70.3
100 you use 0
ie take a 100 off all the values you see in my IAT activation table
also mod the cold/warm/hot port/direct injection ration tables to run less port injection in problem areas ie around 2000 rpm.
Old 08-06-2015, 11:41 AM   #572
nickmerronesucks
Ned flanders
nickmerronesucks's Avatar
Drives: 13 BRZ, 16 Hellcat, 22 Ram 2500
I don't have my datalog to post right now. but Yesterday I received a new tune from shiv for my OFT350 SBD Kit. Ran great yesterday...afr was at 14.7 idle was perfect..now today I start it up and idle is kinda acting like a Honda with a bad iacv...and AFR is 18.1 at idle...what could of have happened? Something with the tune? I will admit as soon as I reflashed it yesterday I beat the poop out of it trying to get logs for shiv. I did datalog my ride to work so I will try and get it posted asap. Vacuum looks like its reading correctly too so I don't believe its a vacuum leak.
797Performance.com
nickmerronesucks is offline   Reply With Quote
Old 08-06-2015, 11:50 AM   #573
steve99
Drives: FT86
sounds like a hardware problem ie intake or exhaust leak, dirty maf/map sensor ect. melted wiring ect.
i would talk to shiv, turbos running lean not good
Old 08-06-2015, 11:53 AM   #574
nickmerronesucks
Ned flanders
Yeah im eagerly waiting for a response from shiv. I have like 30 miles on the setup. hoping its just maybe something stupid.
797Performance.com
RGM Supercharged 86 performance data TheGooseman AFRICA 14 12-13-2014 01:15 AM
Interpreting Ecutek Data Logs? cuddefred Software Tuning 3 09-02-2013 12:55 PM
VIR - Impressions/Pics/Logs/Video (Track Daze) swift996 Tracking / Autocross / HPDE / Drifting 39 08-30-2013 09:21 AM
Noise tube delete air/fuel logs? jm1681 Engine, Exhaust, Transmission 13 10-17-2012 04:57 PM
ECU Data Logger Motordyne Engine, Exhaust, Transmission 5 07-18-2012 09:27 AM
