Old 07-30-2015, 06:06 PM   #1
Andrew360
Andrew360's Avatar
Drives: Whiteout FRS, 07 Stg 2 Vw GTI
Engine code 1264. Losing throttle control. Helpp
I'm getting code 1264 and I lose throttle control. The engine stay on but I can floor the gas and nothing would happen. I have to restart the car to regain throttle control and this would happen randomly when I'm driving.
I have a turbo frs with DW 770cc injectors and their 65c fuel pump. All the connections are good and I recently put in the new pigtail/connectors from DW.
Any ideas on what's wrong and what I can do to fix this? Thanks.
Andrew360 is offline   Reply With Quote
Old 08-02-2015, 08:06 AM   #2
awilson
Drives: 2015 Scion FR-S Series 1 #1451/1500
The reason of Subaru Outback B1264 OBD-II Engine Trouble Code is B1264 Servo Motor Foot Circuit Failure. Probably the same for the FRS.
awilson is offline   Reply With Quote
Old 08-02-2015, 08:52 AM   #3
steve99
Drives: FT86
What is the letter in front of the code if it P1264 thats diretc injector circuit #4 open circuit.
Old 08-02-2015, 05:31 PM   #4
pantdino
Drives: Firestorm 2013 FR-S
That's what the symptoms sound like to me.
These are drive by wire cars. If the rheostat at the pedal is not working the computer doesn't know you stepped on the gas pedal
This is also probably what happens when cars go into full acceleration mode and kill their drivers-- the computer thinks you want full power because the foot pedal has shorted out or whatever.
1995 BMW M3, 1973 DeTomaso Pantera, 1972 Dino 246GT, 1964 Fiat-Abarth 1000TC vintage racer
pantdino is offline   Reply With Quote
Old 09-08-2015, 12:50 PM   #5
Cessblood
Boost equals pleasure
Drives: MT Raven FRS Lexus ES300 &Turbo tc
My friend got the P1262 code this weekend. Did you get everything fix? What was the end results?
Cessblood is offline   Reply With Quote
P0202 engine code and others. What should I do? stockysnail Issues | Warranty | Recalls / TSB 8 07-15-2015 10:32 PM
Losing control Derickie Scion FR-S / Toyota 86 GT86 General Forum 76 05-30-2014 04:25 AM
O2 censor engine code then no cruise control! DrewIsAmus BRZ First-Gen (2012+) — General Topics 7 01-27-2014 10:06 PM
Losing Control. Asterisked Accolade Other Vehicles & General Automotive Discussions 18 04-01-2013 11:39 PM
Control Your Thorttle Output with the Weapon R I-Throttle Controller !! PRO Import Tuners Engine, Exhaust, Bolt-Ons 16 08-14-2012 08:10 PM
