#85 | |
Drives: '15 Halo FR-S
Although, an adequate coating, and a good CP system will delay the inevitable for a long, long time. |
#86 |
Drives: WRB Brz / SR S14
Came a day early!
#87 |
Drives: 2014 FR-S
Did you coat the inside of the header as well? Does the slip joint fit back okay? I've read some people don't coat the slip joint area because the coating might be too thick to put back together.
#88 |
Drives: Time-attack Scion Race car
i don't believe the guy coated the inside of the slip joint area for that exact reason. There should be no problems with corrosion there or the salt hitting that area. I can probably have them coat that area, it is just going to cost extra. The rough cost for the black Cerakote is going to be roughly $120 for the headers.
#89 | |
Drives: 2013 Firestorm FR-S
#90 |
Drives: 2013 Subaru BRZ Limited (Black)
I have the same sound. Just installed Gruppe-s UEL header yesterday, and I would describe the sound as less 'wooshy', and a bit more rough. Almost like a rasp, but at the same time, almost like sand flying around in the pipe. Kind of a gritty sound. It only happens on acceleration, and it just sounds out of place. It has a 'ticking' sound, but difficult to describe further. I've done some forum research, and I would say that this is normal. It looks like plugging the sound tube or adding header wrap may deaden the sound, but header wrap can subject the header to more heat over time, taking away from useful life. Just FWIW
#91 | |
#92 |
That Guy
Drives: 2013 asphalt FRS MT
Where do you guys buy these from?
#93 |
http://www.ft86club.com/forums/showthread.php?t=81839
You can call him or simply pm him. |
#94 |
Drives: 2013 Firestorm FRS
I had a chance to drive through a tunnel the other day...it was best day ever lol
I double checked my bolts the other day too, everything was nice and snug! |
#95 |
I have double checked for leaks on mine, and nothing has changed! The swoosh/air/brustle sound is normal!
#96 |
Drives: Firestorm FR-S
It sound a bit difference after the tune from Driftoffice. I love the noise now
#97 |
Drives: 2015 BRZ CWP
Offical Gruppe-S UEL Header Install & Review Thread
I wrapped mine and the noise I'm getting is at the catless front pipe. Going to swap with a resonated catless front pipe to see if it quiets it down. just got tuned yesterday and the torque curve is so flat!
Dyno chart in this thread. http://www.ft86club.com/forums/showp...&postcount=126 Sent from my iPhone using Tapatalk Last edited by byun; 08-18-2015 at 05:21 PM. |
#98 |
Drives: whiteout scion frs
It looks like a knock off tomei in my opinion
| Tags |
| gruppe, gruppes, header, uel, unequal length |
| DIY X REVIEW: CNT UEL HEADER INSTALL | adamg | Engine, Exhaust, Transmission | 73 | 07-27-2023 09:58 AM |
| P&L Header install, review and impressions | D K | Engine, Exhaust, Transmission | 54 | 05-30-2019 12:35 AM |
| Top Speed EL Header Review, Install, and Pictures | tomaszjanczak | Engine, Exhaust, Transmission | 0 | 10-11-2014 07:27 PM |
| Vortech Offical Owner Thread | cjsporl1996 | Forced Induction | 2 | 03-27-2014 12:50 AM |
| **Offical 213/323/626/818 owners thread** | mr. slim | Southern California | 71 | 10-07-2013 12:58 PM |
