Old 07-29-2015, 06:44 PM   #85
Bergen23
Drives: '15 Halo FR-S
Originally Posted by JEDI View Post
^Correct
This is my uneducated understanding, rust is a product of the steel/material returning to it's natural state. Depending on the type of material, conditions, humidity etc. will determine how fast and when the process begins to take effect. Protective coatings, paint, and such just prolong the inevitable. Besides poor corrosion prevention practices this is why you see rust under paint.
Ding ding ding! Someone knows a thing or two about cathodic protection?
Although, an adequate coating, and a good CP system will delay the inevitable for a long, long time.
Bergen23 is offline   Reply With Quote
The Following User Says Thank You to Bergen23 For This Useful Post:
Strife26 (11-05-2015)
Old 07-29-2015, 07:40 PM   #86
drew_kar
drew_kar's Avatar
Drives: WRB Brz / SR S14
Came a day early!
drew_kar is offline   Reply With Quote
Old 07-29-2015, 08:58 PM   #87
kbye
kbye's Avatar
Drives: 2014 FR-S
Originally Posted by Wayno View Post
Ceramic is the only way to go.
It turns out PSR were the ones who requested that the slip retainer be moved above so that the headers don't require bash plate modification.
Did you coat the inside of the header as well? Does the slip joint fit back okay? I've read some people don't coat the slip joint area because the coating might be too thick to put back together.
kbye is offline   Reply With Quote
Old 07-30-2015, 03:55 AM   #88
Gruppe-s
Drives: Time-attack Scion Race car
i don't believe the guy coated the inside of the slip joint area for that exact reason. There should be no problems with corrosion there or the salt hitting that area. I can probably have them coat that area, it is just going to cost extra. The rough cost for the black Cerakote is going to be roughly $120 for the headers.
Gruppe-s is offline   Reply With Quote
Old 07-30-2015, 04:47 PM   #89
Vitamin-R
Vitamin-R's Avatar
Drives: 2013 Firestorm FR-S
Originally Posted by nunonuna View Post
Does anybody have some kind of hissing or wooshing kind of noise on throttle after this header installed??
I do too. It was driving me nuts thinking there was a leak somewhere, but after checking several times and not finding one I've gotten used to it. Still sounds awesome
Vitamin-R is offline   Reply With Quote
The Following 2 Users Say Thank You to Vitamin-R For This Useful Post:
nunonuna (07-30-2015), scioneric (07-30-2015)
Old 07-31-2015, 12:48 AM   #90
ajcarson11
Drives: 2013 Subaru BRZ Limited (Black)
I have the same sound. Just installed Gruppe-s UEL header yesterday, and I would describe the sound as less 'wooshy', and a bit more rough. Almost like a rasp, but at the same time, almost like sand flying around in the pipe. Kind of a gritty sound. It only happens on acceleration, and it just sounds out of place. It has a 'ticking' sound, but difficult to describe further. I've done some forum research, and I would say that this is normal. It looks like plugging the sound tube or adding header wrap may deaden the sound, but header wrap can subject the header to more heat over time, taking away from useful life. Just FWIW
ajcarson11 is offline   Reply With Quote
The Following User Says Thank You to ajcarson11 For This Useful Post:
Gruppe-s (07-31-2015)
Old 07-31-2015, 02:05 AM   #91
Vitamin-R
Vitamin-R's Avatar
I've gotten rid of the sound tube. I guess it's just the design. I can kinda see how you describe it as a rasp. It just sounds airy almost like my airbox isn't completely shut and sealed. As soon as I realized it's not actually leaking anywhere I accepted it haha.
The Following User Says Thank You to Vitamin-R For This Useful Post:
Old 07-31-2015, 07:49 AM   #92
Calum
That Guy
Drives: 2013 asphalt FRS MT
Where do you guys buy these from?
Old 07-31-2015, 08:58 AM   #93
nunonuna
nunonuna's Avatar
http://www.ft86club.com/forums/showthread.php?t=81839
You can call him or simply pm him.
nunonuna is offline   Reply With Quote
The Following 2 Users Say Thank You to nunonuna For This Useful Post:
Calum (07-31-2015), Gruppe-s (08-06-2015)
Old 08-12-2015, 01:56 PM   #94
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
I had a chance to drive through a tunnel the other day...it was best day ever lol
I double checked my bolts the other day too, everything was nice and snug!
The Following User Says Thank You to continuecrushing For This Useful Post:
Gruppe-s (08-17-2015)
Old 08-12-2015, 02:01 PM   #95
ajcarson11
I have double checked for leaks on mine, and nothing has changed! The swoosh/air/brustle sound is normal!
Old 08-12-2015, 04:27 PM   #96
scioneric
scioneric's Avatar
Drives: Firestorm FR-S
It sound a bit difference after the tune from Driftoffice. I love the noise now
scioneric is offline   Reply With Quote
The Following 2 Users Say Thank You to scioneric For This Useful Post:
Gruppe-s (08-17-2015), NWFRS (08-15-2015)
Old 08-12-2015, 05:42 PM   #97
byun
byun's Avatar
Drives: 2015 BRZ CWP
Offical Gruppe-S UEL Header Install & Review Thread
I wrapped mine and the noise I'm getting is at the catless front pipe. Going to swap with a resonated catless front pipe to see if it quiets it down. just got tuned yesterday and the torque curve is so flat!
Dyno chart in this thread.
http://www.ft86club.com/forums/showp...&postcount=126
byun is offline   Reply With Quote
Old 08-13-2015, 11:42 PM   #98
nor cal frs
nor cal frs's Avatar
Drives: whiteout scion frs
It looks like a knock off tomei in my opinion
nor cal frs is offline   Reply With Quote
gruppe, gruppes, header, uel, unequal length
DIY X REVIEW: CNT UEL HEADER INSTALL adamg Engine, Exhaust, Transmission 73 07-27-2023 10:58 AM
P&L Header install, review and impressions D K Engine, Exhaust, Transmission 54 05-30-2019 01:35 AM
Top Speed EL Header Review, Install, and Pictures tomaszjanczak Engine, Exhaust, Transmission 0 10-11-2014 08:27 PM
Vortech Offical Owner Thread cjsporl1996 Forced Induction 2 03-27-2014 01:50 AM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 01:58 PM
