Old 05-31-2012, 04:43 PM   #15
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
Anyone know if the larger OEM Subaru chrome tips will bolt on without cutting?
http://www.japanparts.com/db/parts_d...=26&submit.y=1
Old 05-31-2012, 04:47 PM   #16
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Yup, if you can get a hold of them they'll just slip right on like the stock US pair.
The Following 3 Users Say Thank You to Draco-REX For This Useful Post:
makalaka (06-03-2012), switchlanez (05-31-2012), wheeladdict (06-25-2012)
Old 06-04-2012, 12:40 PM   #17
arkybrz
Drives: '11 WRX DGM Ltd., '13 BRZ SSM Ltd.
Originally Posted by skoodge View Post
EDIT: If anyone can provide a way to get that bolt out and the tip off, please let me know, I don't exactly feel safe driving around with a broken bolt holding on my exhaust tip. Thanks!
Get a set of bolt remover drill bits from Sears and it should come out no problem. I've had to use them before with a bolt that snapped off on my '02 WRX. Worked like a charm.
http://www.sears.com/shc/s/p_10153_1...51000P?cw=true
arkybrz is offline   Reply With Quote
The Following 2 Users Say Thank You to arkybrz For This Useful Post:
Dadhawk (06-04-2012), EvoXDD (07-12-2012)
Old 06-07-2012, 09:37 AM   #18
BillY2KFRC
Drives: 2003 Corvette Z06, ECS Dry Sump 427
Very sweet, I'm psyched that it's such an easy mod. Can somebody confirm that "Tail Pipe Cutter" is just poor engrish translation for Tail Pipe COVER? I would hate to order and receive a big pair of scissors or something, lol.
2003 Corvette Z06 - Dry Sump LS7 built by East Coast Supercharging
560rwhp & 549rwtq 10.8@134
2013 Subaru BRZ Limited - WRB, 6MT, PTuning Header, Motriv OP & FP, Perrin Res. Catback, Toms Tail Lights, Sprint Springs, Rays 57DR Wheels, 186rwhp
BillY2KFRC is offline   Reply With Quote
Old 06-24-2012, 06:31 PM   #19
eriktherod
Drives: 2013 Scion FR-S Firestorm Red MT
I had my stupid bolts break just like skoodge's, will have to get a drill and extractor bit from the shop tomorrow.. ugh just annoying. They didn't use stainless bolts on the exhaust and they seize up EASY.
eriktherod is offline   Reply With Quote
Old 06-25-2012, 01:07 AM   #20
Smudgeous
Smudgeous's Avatar
Drives: 2013 WRB 6MT BRZ Ltd.
That sucks to hear, man. Mine came off with an adjustable wrench without any real issues (a bit seized, but just kept gradually increasing the pressure I applied). I was at first unsure as to how they were attached to exhaust pipe and scratched it up during removal, but then figured it really won't matter at all since they're being covered back up anyway :P
Smudgeous is offline   Reply With Quote
Old 06-25-2012, 01:14 AM   #21
eriktherod
Yeah, what pisses me off about it is.. this car is a little over two weeks old. The fact that I'm already able to break bolt heads is stupid, they couldn't have used stainless bolts for those... meh.
Old 07-12-2012, 10:28 AM   #22
EvoXDD
Trident Motorsports Owner
Drives: DGM. DD for my EvoX
mine came off with ease. almost finger loose to be begin with. the fact they broke is because they are a very low grade bolt not meant to be heated that hot, so word of advice....stop beating up your baby so hard lol i j/k
EvoXDD is offline   Reply With Quote
The Following User Says Thank You to EvoXDD For This Useful Post:
cmspooner (07-31-2012)
Old 07-19-2012, 04:05 PM   #23
Phaedrus29
Phaedrus29's Avatar
Drives: 2013 Subaru BRZ
Recently finished installing temporary tips to replace the yucky factory ones. Here are a couple quick pics:
You may be able to tell from the pics that the tips aren't quite centered evenly...I'll try to adjust it a bit but it just might be impossible to get them perfect. If you are somewhat OCD like me you might not be happy...but as a temp fix I think this is pretty good over stock.
I installed DC Sports tips which I THINK are model EX-1013. I say "I THINK" because I found that many of the DC Sports tips were mislabeled. Numerous cases in different stores of these tips with identical labels but clearly different parts. SO if you do go this route make sure to carefully examine the tips to make sure they match (and are the correct specs).
Here's a pic of the label (again though, this might not actually be the EX-1013 because I found multiple others with the identical EX-1013 label that look different):
This is what the inside looks like...the other EX-1013 I tried out (and returned because it didn't fit as well) had a larger diameter middle-opening:
Here is a pic showing one of the bolts...you can see this version has nuts affixed to the tip...the EX-1013 I returned that didn't fit as well and was less secure didn't have these nuts at all. So that's one thing to look for...you probably want the nut:
I found this brand of tips for sale at both Pep Boys and Advance Auto Parts. Let me know if you have questions.
[Also, I had no problem at all removing the bolts on the factory tips. I'd advise using a ratchet to make sure you are turning the right way, since maybe that's why people had issues! ]
Phaedrus29 is offline   Reply With Quote
The Following 6 Users Say Thank You to Phaedrus29 For This Useful Post:
avusblue (07-28-2012), Clembo (03-14-2013), Imti (07-28-2012), reeves (08-05-2012), TennisHsu (08-12-2012), tonystewart (07-22-2012)
Old 07-19-2012, 09:53 PM   #24
RandomHero
SW5 Driver
RandomHero's Avatar
Drives: Asphalt FRS
What is the pipe diameter?
RandomHero is offline   Reply With Quote
Old 07-21-2012, 01:08 PM   #25
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
2.25"
Thank You Phaedrus29
tonystewart is offline   Reply With Quote
The Following User Says Thank You to tonystewart For This Useful Post:
RandomHero (07-23-2012)
Old 07-22-2012, 06:54 PM   #26
Phaedrus29
Phaedrus29's Avatar
You're very welcome. A couple more pics today after I worked on evening them out a bit:
The Following 3 Users Say Thank You to Phaedrus29 For This Useful Post:
Imti (07-29-2012), RandomHero (07-23-2012), TRD_86 (08-03-2012)
Old 07-22-2012, 07:37 PM   #27
n7011n
Drives: 2013 GBS BRZ Limited 5MT
Here are a few pics of the JDM exhaust tips compared to the aftermarket tips I had installed.
n7011n is offline   Reply With Quote
The Following 2 Users Say Thank You to n7011n For This Useful Post:
nocurfew (07-31-2012), SuperDave (08-04-2012)
Old 07-22-2012, 09:55 PM   #28
tonystewart
They are all quite nice! The ovals do an outstanding job of filling the area
T1R exhaust for the FRS/BRZ ! AJ PwR Engine, Exhaust, Transmission 57 06-22-2013 10:39 PM
AVO Exhaust Blaaaack-BRZ Engine, Exhaust, Transmission 22 10-16-2012 11:28 PM
HKS Exhaust 01s0uljah Engine, Exhaust, Transmission 1 05-18-2012 09:15 AM
Removal of Radio/Infotainment Unit Captain Snooze Electronics | Audio | NAV | Infotainment 6 03-20-2012 07:46 AM
ft 86 exhaust dalli Scion FR-S / Toyota 86 GT86 General Forum 11 09-08-2010 10:16 PM
