Old 07-29-2015, 06:29 PM   #15
Jayela
Drives: 2013 Nissan GT-R, 1985 Porsche 944
Hey guys, thanks for all the responses! I got just a bit lost, some people mention springs and camber. Might sound stupid but can I adjust camber on stock suspension? And for the springs, do I need to get some specific ones? I was thinking about getting a a bit shorter stiffer springs before coils (coils are a plan for probably next summer).
Can anyone please sum up what do I need to get those wheels on? I know camber will be beneficial for autocross and not afraid of it (as long as it's reasonable and performance oriented), so -2 sounds perfectly fine.
Thanks everyone!
Jayela is offline   Reply With Quote
Old 07-29-2015, 06:49 PM   #16
NLSP
NLSP's Avatar
Drives: 2014 Ultramarine FR-S
I ran my 17x9, +35 for a while on stock suspension with no issues. You can get a little more negative camber up front by purchasing OEM crash bolts that go in the upper slot. I think I got about -1.5 at the time, but it can vary a bit depending on each individual car. Rear camber is not adjustable unless you have aftermarket control arms.
Springs are not necessary to fit the wheels. I think it'd be a waste of money since you're planning to get coilovers in the future anyway. Save the money on springs to get the coilovers faster.
...or you can save even more money and just get good tires on the stock wheels. You'd be amazed at what tires alone can do, even in stock size. Something in the Extreme Summer category, such as Hankook RS3, Dunlop Z2 Star Spec, BFGoodrich Rival S, or Bridgestone Potenza RE-71R.
Also, if you actually want to improve/learn driving skill, don't go super wide and super sticky too fast. That'll just mask any driving mistakes and you won't be learning car control as much.
Old 07-29-2015, 06:51 PM   #17
asdf
Loading...████████] 99%
asdf's Avatar
Drives: #0517
Thanks everyone!
You will not be able to make any camber adjustments to oem suspension w/o any additional parts.
You can get camber bolts for the front-- find a good alignment person/shop and get them to dial in as much camber up front as possible w/ the bolts, keeping the toe straight (or adjust to whatever suits your taste). You won't be able/need to do anything to the rear if you're on completely stock suspension.
asdf is offline   Reply With Quote
Old 07-29-2015, 06:59 PM   #18
Jayela
Originally Posted by NLSP View Post
I ran my 17x9, +35 for a while on stock suspension with no issues. You can get a little more negative camber up front using the OEM crash bolts in the upper slot. I think I got about -1.5 at the time, but it can vary a bit depending on each individual car. Rear camber is not adjustable unless you have aftermarket control arms.
So I'll just go all-in next summer and get wheels, tires, coils and sway bars next summer and currently make do of whatever stock can offer. Thanks a lot!
Old 07-29-2015, 07:00 PM   #19
Jayela
Is it worth doing for stock and if I plan switching to coils for next season? Thanks!
Old 07-29-2015, 11:32 PM   #20
Mad_Mike
Mad_Mike's Avatar
Drives: 2013 Scion FRS firestorm
Yes, the bolts are only like $10. You can even use them on some coilovers depending on which ones you get.
Mad_Mike is offline   Reply With Quote
Old 07-29-2015, 11:54 PM   #21
Donbrz
Drives: 2015 Brz Blue Series
Thanks everyone!
17x9 +35 Is the perfect fit on stock. +38 high chance of rub on front strut. I have been running RPF1s 17 x 9 +35 with RE11a Have tracked 9 days, great handling.
Donbrz is offline   Reply With Quote
Old 07-30-2015, 12:26 AM   #22
timmydatooth
Drives: Scion Frs
Im thinking about getting 17x9 wheels for my frs. Is there really a big difference between +35 and +38? Used for daiky driving so whichever will give me more peace of mind with no rub
timmydatooth is offline   Reply With Quote
Old 07-30-2015, 12:50 AM   #23
lightdir
Drives: 2013 Raven FRS 6MT
running 17 x 9 +35 with 245/40/17 running -1 up front and -1.75 in the rear. I have had no rubbing issues and it has been 60k miles.
lightdir is offline   Reply With Quote
18" wheels on stock suspension echo419 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 20 07-17-2017 07:40 AM
Pic Request: 17x9 on stock suspension hmong337 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 53 02-23-2017 03:24 PM
+1 wheels, stock suspension? red_comet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 15 11-15-2013 09:05 PM
Perfect Wheels for Stock Suspension pcamaliga Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 05-12-2013 03:36 PM
Aftermarket wheels with stock suspension Thongpocket Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 01-24-2013 06:08 PM
