Old 07-26-2015, 09:41 AM   #15
stevesnj
stevesnj's Avatar
Mine is ice cold. I set to recirculate and upper and foot vents. If I turn off recirculate it will use the outside hot air and just can't cool as well. But lately I just drive windows down. Used the A/C maybe twice with windows up.
My 2016 Build thread
Old 07-26-2015, 11:24 AM   #16
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Do your ears hang low, do they wobble to and fro, can you tie them in a knot, can you tie them in a bow...
The Following 2 Users Say Thank You to EAGLE5 For This Useful Post:
AznBRZer (07-28-2015), Ultramaroon (07-26-2015)
Old 07-26-2015, 01:02 PM   #17
WNDSRFR
Drives: FR-S,GTI
Same here. Here are my normal settings. OK today is the coolest it's been in quite awhile but I use the same setting when it's 97 degrees.
What color is your car? Mine is silver (Argento). Of course if your car is black then tough luck. Black looks really nice when it's clean but it has it's issues.
Also, if the car is parked in the sun then whenever you start it, run it with the windows open for a minute to release the built up heat. Trying to let the aircon deal with it is not going to work.
Old 07-26-2015, 06:44 PM   #18
pantdino
Drives: Firestorm 2013 FR-S
Originally Posted by BaBaFlyingSheep View Post
I have the same issue, went to the dealership where they have stuck a temp probe into the vents. Temp range was like 46F to 52F and kept fluctuating back and forth.
Dealership said it was within tolerance of 10 degrees, saying there's a lot of factors that the sensor will go on and off, or maybe he just didn't want to fix it.
But yea, anything fluctuation past 3 degrees F is something you can feel.
52 is not cold enough. IIRC you should see low 40's at the vent. Google the question and see what you come up with.
I park my car in the shade, use reflective window shades, and put the windows down a couple inches here in So Cal and don't have a problem with it getting too hot inside. But, as was said, if it is super hot inside open both doors fully and start the AC to get the superheated air out and the AC down to temp before you get in.
1995 BMW M3, 1973 DeTomaso Pantera, 1972 Dino 246GT, 1964 Fiat-Abarth 1000TC vintage racer
pantdino is offline   Reply With Quote
Old 07-27-2015, 12:41 AM   #19
BaBaFlyingSheep
Drives: 2015 BRZ Ltd 6MT
I agree, my car isn't blowing cold enough, that's why I took it to the dealership. The temps were with recirculation on.
Can't seem to come up with anything on Google, most people only talk about the temp they set it at, not the actual temp coming out of the vents.
If you have a link for actual temps, or know the actual range of what the FR-S and BRZ should be blowing, that would be really helpful.
BaBaFlyingSheep is offline   Reply With Quote
Old 07-28-2015, 02:30 PM   #20
billwot
Drives: '11 Cayman , '14 Camry, '11 Tacoma
Temp at the vent should be 40-42F, even with ambient temps in the high 90s.
billwot is offline   Reply With Quote
Old 07-28-2015, 02:51 PM   #21
Jesse36m3
Jesse36m3's Avatar
Drives: JDL Turbo BRZ
Oh she blows.
Nice and cold.
Haven't had any problems yet in my '13 ~ 41k miles.
Jesse36m3 is offline   Reply With Quote
Old 07-28-2015, 03:07 PM   #22
86Tony
Drives: 2015 AOZORA EDITION
My ac is freezing gotta raise my temp up here and there
86Tony is offline   Reply With Quote
Old 07-28-2015, 03:30 PM   #23
Tgionet
SPACESHIP
Tgionet's Avatar
Drives: BRZ Ltd 6MT WRB
I leave it on auto at 65 and the vents blow cold enough to numb my hands
Tgionet is offline   Reply With Quote
Old 07-28-2015, 03:35 PM   #24
sprintertrueno86
sprintertrueno86's Avatar
Drives: 2018 BMW M2
Mine is never cold even on lowest setting, just cool air.
sprintertrueno86 is offline   Reply With Quote
Old 07-28-2015, 03:57 PM   #25
stevesnj
stevesnj's Avatar
Here's the service manual pic troubleshooting chart for the A/C
Old 07-28-2015, 04:48 PM   #26
stevesnj
stevesnj's Avatar
I also got this off of AutoZone website. Should be a general idea of how Outside Humidity and Air Temps translate to interior cooling temps.
The Following 2 Users Say Thank You to stevesnj For This Useful Post:
BaBaFlyingSheep (07-31-2015), frs23 (07-31-2015)
Old 07-29-2015, 04:42 PM   #27
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
I found that the accessories belt will sometimes slip, not all the time, causing the AC to not not blow cold intermittently. Something worth checking. Also when this slippage happens the idle mayb dip suddenly.
Intent > Content
Old 07-29-2015, 07:16 PM   #28
Regalo
Drives: Toyobaru 86
Send a message via AIM to Regalo Send a message via Yahoo to Regalo
My AC blows cold air very inconsistently. Sometimes I may as well just roll down my windows. I took it to the dealership twice and they haven't found anything wrong yet. But I wonder is it normal for the AC compressor clutch to engage on and off? I've done various searches and haven't found solutions yet but I found a video of someone overriding the fuse box and the AC clutch started to engage. Any thoughts on this?
Regalo is offline   Reply With Quote
The Following User Says Thank You to Regalo For This Useful Post:
solidONE (07-29-2015)
How Blow Off Valves Work ATSAaron Forced Induction 47 07-16-2014 06:38 PM
**Visconti Tuning Vortech ProCharger Spring Blow-Out Sale** Rich@ViscontiTuning Forced Induction 133 05-10-2013 01:31 PM
XXR 527 18X8.75 35 OFFSET - GOLD FINISH - BLOW-OUT-PRICES!!~!~! MIKE@MRTIRESOLUTIONS Wheels and Tires 1 12-12-2012 12:57 PM
Volk Racing/Gram Lights blow out sale Stav Canada Classifieds 9 11-30-2012 04:40 PM
***CUSCO COILOVERS BLOW OUT PRICING*** genometuning Brakes, Suspension, Chassis 11 10-23-2012 05:54 PM
