-   Issues | Warranty | Recalls / TSB (https://www.ft86club.com/forums/forumdisplay.php?f=72)
-   -   Does you A/C blow cold? (https://www.ft86club.com/forums/showthread.php?t=34603)
boredom.is.me 04-24-2013 12:34 AM
Is it my car, or do they all not blow as cold as other cars? I would freeze in my family's cars: IS350, SC430, X6, 2012 Beetle, Range Rovers, Tacoma (big and little versions), FJ-Cruiser, etc..
This car just blows a cool breeze...hot compared to the others I listed. If it is something that doesn't sound normal, then I'll go compare it to others at the dealership.
Julio86 04-24-2013 12:54 AM
yeah bro i feel you on that one. my dad's '94 camry would blow colder air than my car :(
m.wood0213 04-24-2013 01:23 AM
mine isnt freezing but cold enough for now. We'll see when it faces Texas summers.
husker741 04-24-2013 01:25 AM
SC430, eh? I see there's at least one smart person in your family :happy0180:
My SC can burn the shit out of me, or freeze my nuts off. Love it.
feldy 04-24-2013 01:51 AM
I noticed around town it lags. Highway trips I was fine.
FT86Dubai 04-24-2013 02:51 AM
Me too, temperature here is about 105f in the afternoon and I feel the AC blows enough air at full fan speed (4) but its not that cold. If I rev the engine above 3k rpm it gets a little cooler but not still not cool enough. However, when driving in highways at about 60mph it gets very cold and I reduce the fan speed to 3 or 2. Btw my car has very dark tinted windows.
King Tut 04-24-2013 11:20 AM
Seems like the performance is not very good at idle or in stop and go traffic, but feels fine while moving at a decent pace. Wouldn't surprise me if this is a fuel mileage issue that you will see more and more often on new cars. The less the clutch on the A/C compressor engages the less fuel you waste during idle conditions.
boredom.is.me 04-25-2013 12:57 AM
So I'm glad I'm not the only, but at the same time, this saddens me.
husker741 04-25-2013 01:00 AM
The car barely has enough power to get out of its own way. You really think that will translate into also have it blow really cold air?
EAGLE5 04-25-2013 01:01 AM
Meh. It works fine. The car soaks a lot of heat on a hot day and takes awhile to get up to cooling. I'll put some tinted windows on.
boredom.is.me 04-25-2013 01:03 AM
Last time I checked, a Rav4 didn't have much power either, but it too freezed my ass off.
Kosmos 05-01-2013 12:09 PM
Mine blows cold air. But windows down is the way to go ;)
BaBaFlyingSheep 07-26-2015 03:35 AM
I have the same issue, went to the dealership where they have stuck a temp probe into the vents. Temp range was like 46F to 52F and kept fluctuating back and forth.
Dealership said it was within tolerance of 10 degrees, saying there's a lot of factors that the sensor will go on and off, or maybe he just didn't want to fix it.
But yea, anything fluctuation past 3 degrees F is something you can feel.
DieselDog 07-26-2015 03:59 AM
Mine works great. Though I did recover and recharge and adjusted the refrigerant amount using static pressures compared to the ambient temperature. A/C clutch cycles as it should. High side and low side pressures are perfect, again ambient temp makes a difference on what pressures you should have. Vent temp with A/C Max and doors open with an ambient of 90F I got 38F at the lowest and 44F at the highest for each compressor cycle.. Parked and at 1000 rpm.
Proper A/C performance testing is never at idle.
