Old 07-13-2015, 08:39 AM   #15
TMF
TMF's Avatar
Drives: '14 FRS TT5
Originally Posted by Jawnathin View Post
Off topic from the thread, but since I messed up...
Wrong way -
Right way -
I'm bumping this one up from the dead...do you mind re-uploading these pics? I'm doing the install this week and want to make sure I assemble the rears properly.
Thanks!
TMF is offline   Reply With Quote
Old 07-24-2015, 10:23 AM   #16
TMF
TMF's Avatar
Drives: '14 FRS TT5
Thanks!
Well in case anyone ends up needing this for future reference...here is a picture of the correct way to orient the rear spring perch:
And I ordered a 31/64th drill bit from Amazon to drill out the rear top hats, and it worked perfectly.
Old 07-24-2015, 09:46 PM   #17
burdickjp
Drives: 2013 ultramarine Scion FR-S
If you're ordering a drill, why not just order the 12mm drill?
burdickjp is offline   Reply With Quote
Old 07-24-2015, 10:56 PM   #18
TMF
TMF's Avatar
Drives: '14 FRS TT5
Find me a 12mm drill bit that can drill metal and I'd buy it. Couldn't find one easily when I was searching.
Old 07-25-2015, 12:18 AM   #19
burdickjp
I actually get a lot of my machine tool consumables from Amazon because of the free shipping. It was a bit easier when they had Amazon Supply, but you can still find stuff on the normal site.
High Speed Steel should be all you need. I prefer screw machine length drills because they're stiffer than jobber length. I've had good luck with the brand YG-1.
Here's the screw machine length version: http://amzn.com/B009NND9JO
If 102 mm isn't long enough, here's the jobber length version: https://amzn.com/B009NNO2PY
Old 07-25-2015, 12:22 AM   #20
vroom4
Wow you guys are over thinking this...a Hf drill bit will work just fine for the task....hell, you can return it when you're done haha
vroom4 is offline   Reply With Quote
Old 07-25-2015, 09:28 AM   #21
burdickjp
I'm of the mind that you use the right tool for the job. If Koni specifies a 12 mm drill, there's a reason.
It helps that my shop is entirely metric.
Koni Yellow Whoes :( feldy Suspension | Chassis | Brakes -- Sponsored by 949 Racing 30 05-21-2014 11:02 AM
WTB: Koni yellow struts and RCE yellow springs nlowell Brakes, Suspension, Chassis 2 05-20-2014 03:10 PM
koni yellow question sweeney208 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 02-03-2014 08:09 PM
FS: RCE Yellow, Koni struts and pre cut housing for Koni's. Dinko Brakes, Suspension, Chassis 21 12-16-2013 10:32 AM
-Sold- FS: ASSEMBLED Koni Yellow + RCE Yellow combo; lightly used! OrbitalEllipses Mid-Atlantic 21 06-14-2013 12:10 PM
