Old 07-23-2015, 02:20 PM   #43
Streetthrowback
Drives: 2015 brz
I love tein, been using them for 12 years never had a problem
Streetthrowback is offline   Reply With Quote
Old 07-23-2015, 02:53 PM   #44
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by solidONE View Post
Pictures will definitely help. Before and after they lower themselves. Also If it is un-threading itself then basically you have no preload and when the shock is fully extended (car jacked up and wheels in full droop) you'd have a gap between the top of the coil and the perch thing above it. I still don't see how it's going to be unthreading itself on the shock body...
If it's the collar that locks the lower 'cup' in position, then somehow that collar is not doing it's job and allowing the shock body to rotate threading into the 'cup'. Might want to call Tein and complain to them. Maybe they already know of this problem and have a solution.
Hmmm.... the spring on the right side, I can move it up and down with my hand, it's loose in between the locking ring and the top of the coil... So maybe my pre-load got fucked? I've never touched it, but I noticed that when I removed the tire Tuesday.
Old 07-23-2015, 03:34 PM   #45
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Yeah... that's not good. lol You need to check and redo all of them. Typically the suggested preload for these types of coilovers is about 3mm. Assuming the thread pitch is 1.5, it will be 2 turns on the collar after it's threaded up to and against the spring before compressing the spring. Those collars are not doing their jobs. ]My best guess is that the locking collars weren't tight enough. Call Tein.
The Following User Says Thank You to solidONE For This Useful Post:
Sportsguy83 (07-23-2015)
Old 07-23-2015, 03:37 PM   #46
Sportsguy83
Drives: Limited BRZ
Thanks. I called and I'm waiting for them to send me the manual... can't believe they are not available for download
Old 07-23-2015, 03:42 PM   #47
solidONE
solidONE's Avatar
hope you get that sorted out soon.
Old 07-23-2015, 04:41 PM   #48
babykwiss
Drives: Scion FRS
I know a TON of guys locally running the same setup and we never had an issue other than my self which was a complete install issue. You definitely have not tighten the fronts enough therefore causing it to probably lower it self when you turn. It would not be so bad if the front was not Mcpherson but due to it turning, if it is not tight enough it will move.
babykwiss is offline   Reply With Quote
Old 07-23-2015, 04:55 PM   #49
CSG Mike
CSG Mike's Avatar
If the actual locking collars are turning, then you will lose preload. If the entire damper is turning on the bottom mounting assembly, then you will only lose height.
Old 07-23-2015, 04:55 PM   #50
CSG Mike
CSG Mike's Avatar
It's probably going to be in Japanese :p
Hyper4mance2k (07-23-2015), Sportsguy83 (07-23-2015)
Old 07-23-2015, 09:00 PM   #51
superleggera
superleggera's Avatar
Drives: BRZ / MX5 / S4
So that's how I noticed it the other day... maybe the ride height was fine, but I had tons of slack in the spring. When I originally installed it, the preload didn't allow the spring to move (perhaps I didn't have the collars for the preload tight enough... like Sportsguy83 I didn't touch it)
superleggera is offline   Reply With Quote
The Following User Says Thank You to superleggera For This Useful Post:
Old 07-23-2015, 09:02 PM   #52
superleggera
In the meantime, you can use this
http://www.ft86club.com/forums/showp...6&postcount=30
The Following 2 Users Say Thank You to superleggera For This Useful Post:
CSG Mike (07-23-2015), Sportsguy83 (07-23-2015)
Old 07-23-2015, 09:10 PM   #53
solidONE
solidONE's Avatar
It's also possible that the springs shortened over time causing the initial preload setting to be lost. So it's possible the collar for the spring didn't move at all.
Old 07-23-2015, 09:52 PM   #54
Sportsguy83
Drives: Limited BRZ
a few mm would be plausible but 1 inch?
Old 07-23-2015, 09:52 PM   #55
Sportsguy83
Drives: Limited BRZ
They were gracious enough to send them in English
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Old 07-23-2015, 10:08 PM   #56
solidONE
solidONE's Avatar
so there was an one inch gap between the spring and the upper perch thing? If that the case you know for sure it unthreaded. I doubt Tein use spring material that is that shitty and sag that much.
Tein Street flex JM'sFR-S562 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 05-09-2015 11:04 AM
Tein Street Flex installation Help eguzman6 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 02-08-2015 03:08 PM
WTB - Tein Street Flex and some LCA's Sugi Want-To-Buy Requests 1 01-25-2015 03:12 PM
WTB - Tein Street Flex and some LCA's Sugi Want-To-Buy Requests 1 01-25-2015 12:40 AM
25% Off Tein Street Flex's!!! RallySport Direct Brakes, Suspension, Chassis 0 12-31-2014 04:52 PM
