Old 07-23-2015, 01:59 AM   #1
Drift-Office
Drift-Office's Avatar
Drives: AE86 / FRS / FC3S / GC8 / S14 / R32
Drift-Office : Gruppe-S UEL Installed & Tuned!
Preface : “Which is the Tomei UEL and which is the Gruppe-S UEL header?” That's the only question on everyone's mind. The answer : DOES IT MATTER?! (For the answer, please read onwards...)
Some months back while we were on the topic of the ACE headers with our counterparts in Taiwan, I was asked if we would be interested in doing remote tunes (non E-Tunes) on UEL headers that were specifically, of a certain sort. As they started to describe these headers with their 4-1 collector design, honed runners and surfaced flanges, I had the suspicion that they were actually describing the TOMEI setup that we've been pumping out as of late. A quick picture also confirmed that it was indeed a UEL offering, very close in design with the above-mentioned. That said, there was really very little in the way of discernible differences that we saw, sans the “Tomei” stamp on the flange surface as well as the tacked on name plate that we were accustomed to seeing.
As you can see from the pictures, the quality of construction is top notch. Note that these aren't KNOCK-OFFs as some have described them to be. They're “white boxed” versions of the TOMEI offering. They are in fact, manufactured from the very same machinery used to make the TOMEI headers - there's no variation in material quality, construction but there's a ever so SLIGHT change in design (runner angles) to elude from infringing on IP or exclusivity I suppose. All this comes with a reduction in cost while still being able to attain in this case, the best out of the box results thus far!
As far as installation goes, there's really nothing to talk about. It was fitted without a sweat, process was as expected and flawless.
Enter Gruppe-S : the company isn't new, but I certainly remember them from when we first started our run @ Formula D in 2007. They had reached out to see what our thoughts were and I had told them that we've already since tuned some of them overseas with stella results. I was confident that we could do the same here especially with our 92 Octane gas. Within a few short weeks, I had purchased one for evaluation and here are the results...
Vehicle : 6MT 2015 BRZ
Fuel : 92 Octane Gas
Mods : AVO Dry Panel Filter, Gruppe-S UEL, TRD Exhaust
Name:  Baseline & Header.jpg
Given the filter and the exhaust, I wasn't surprised to see the slightly higher baseline number @ 173, but I will certainly say it's the 2nd highest I've ever seen so far in the 150+ twins that we've dyno tuned thus far. They're typically @ 167, and with the UEL header installed, there's a decent gain but unless you have a custom calibration, you won't otherwise be able to optimize the combination of hardware to it's fullest potential.
Which brings us to our results...
So when you ask which of these two is that of the Gruppe-S, the answer is Run #12. For all intents and purposes as you can see, there’s really zero difference in overall performance after the custom calibration is complete. The other dyno run is that of a Tomei UEL on 2014 86, also with an AVO filter as well as a stock exhaust. Both tunes were conducted within 3 days of each other in the heat wave that we've just experienced. Dyno cell ambient temperatures were both well into the high 80s when we started the tuning process.
Name:  92 Octane Results.jpg
In comparison, I've elected to post up the 6AT 92 Octane results of the Gruppe-S UEL as well, also with an AVO dry panel filter and with a stock exhaust. (I've since done an AT and another MT.) Results are pretty much in line with what we'd expect from a properly tuned setup. So is the Gruppe-S UEL better than the Tomei UEL? Hardly, and that's to be expected. But is it just as good? Every bit so.
Cheers!
Bob @ Drift-Office, LLC
Drift-Office is offline   Reply With Quote
The Following 46 Users Say Thank You to Drift-Office For This Useful Post:
2JZ-GTE (07-23-2015), 6spd (11-14-2015), Alex86em1 (07-30-2015), bedabi (07-23-2015), Bergen23 (07-23-2015), breadcrumbz (07-23-2015), brz604 (07-23-2015), Calum (07-23-2015), conedodging (07-23-2015), Cross (09-16-2015), CxG (03-29-2018), DAEMANO (07-23-2015), dubaar (02-23-2016), D_Thissen (07-23-2015), Fastbrew (07-28-2015), finch1750 (10-26-2015), FR-Ser_Vo (02-02-2016), FRSBRZGT86FAN (10-27-2015), GeoFRS (07-24-2015), Gruppe-s (07-23-2015), Hyper4mance2k (07-23-2015), ichitaka05 (07-29-2015), JEDI (07-29-2015), JohnJuan (09-04-2015), jpky16 (09-10-2015), kayoh (07-23-2015), Keenercarguy (05-10-2016), mikool (07-23-2015), nunonuna (07-23-2015), NWFRS (08-06-2015), P@ul (07-23-2015), Pat (07-23-2015), Plxdjake89 (11-17-2015), raven1231 (07-23-2015), scioneric (07-23-2015), shifter907 (07-23-2015), soulreapersteve (07-23-2015), SPCorBUST (10-26-2015), Strife26 (11-05-2015), ThatAsianBradah (02-09-2018), TofuJoe (06-02-2018), WallsAndFoundations (07-23-2015), Wayno (10-26-2015), Wepeel (07-29-2015), WhiteFRS69 (07-23-2015), YMAA (07-23-2015)
Old 07-23-2015, 02:06 AM   #2
Drift-Office
Sorry for the delay, first video was accidentally deleted. Here's a 6AT with a CORSA exhaust, 6MT to follow soon!
Cheers!
The Following User Says Thank You to Drift-Office For This Useful Post:
Gruppe-s (10-05-2015)
Old 07-23-2015, 02:21 AM   #3
DAEMANO
Time Traveller
Great job as ever Bob.
The Following 2 Users Say Thank You to DAEMANO For This Useful Post:
Drift-Office (07-23-2015), Gruppe-s (07-23-2015)
Old 07-23-2015, 09:05 AM   #4
AJ124
Drives: 13' Toyota GT86
Thank you for sharing these, did you see any cel without the tune?
AJ124 is offline   Reply With Quote
Old 07-23-2015, 12:14 PM   #5
P@ul
Apostle
P@ul's Avatar
Drives: JesusMobile
Tomei must be thrilled, LoL! This is way worse than the Megan / Cusco strut tower bar...
P@ul is offline   Reply With Quote
Old 07-23-2015, 12:45 PM   #6
scioneric
scioneric's Avatar
Drives: Firestorm FR-S
Thanks for your header Bob! Can't wait to see my tune next month.....
scioneric is offline   Reply With Quote
The Following User Says Thank You to scioneric For This Useful Post:
Old 07-23-2015, 03:12 PM   #7
DoomsdayJesus
In Autobahn withdrawl
DoomsdayJesus's Avatar
Drives: 2015 BRZ Limited Man., WRB
Just out of curiosity, does this have the same changes that were on the Tomei UEL that I got? I remember you saying it was different from previous installs.
Edit: Nope, just compared the photos. The runners are definitely straighter on this one. That may explain the minor difference.
DoomsdayJesus is offline   Reply With Quote
Old 07-23-2015, 03:37 PM   #8
mikool
mikool's Avatar
Drives: 14' Firestorm FR-S
This just insured that I will be getting one in a couple weeks.
mikool is offline   Reply With Quote
The Following User Says Thank You to mikool For This Useful Post:
Old 07-23-2015, 04:09 PM   #9
D_Thissen
D_Thissen's Avatar
I'm sold as well. I just wish our dollar wasn't craptacular right now lol
The Following 4 Users Say Thank You to D_Thissen For This Useful Post:
Calum (07-29-2015), GeoFRS (07-24-2015), KayC (07-23-2015), tinma (07-28-2015)
Old 07-23-2015, 05:06 PM   #10
scioneric
scioneric's Avatar
Our dollar may get lower this year
Old 07-28-2015, 05:54 PM   #11
icybrzzz
Drives: 2015 Scion frz
Very interested to see videos of this header in action!
icybrzzz is offline   Reply With Quote
Old 07-28-2015, 06:39 PM   #12
DAEMANO
Time Traveller
As Bob @Drift Office noted, "White Box (label)" is not the same as knock-off.
http://en.wikipedia.org/wiki/White-label_product
The Following User Says Thank You to DAEMANO For This Useful Post:
Drift-Office (07-29-2015)
Old 07-28-2015, 10:25 PM   #13
soundman414
Drives: 2014 Silver BRZ Limited
I apologize in advance for being a noob. But why is there such a dramatic difference between the MT and AT in the final dyno chart? Is the AT really that poor at transferring power to the wheels?
soundman414 is offline   Reply With Quote
The Following User Says Thank You to soundman414 For This Useful Post:
AREN (07-28-2015)
Old 07-29-2015, 02:27 AM   #14
Drift-Office
Oh hell. Totally forgot to upload that! Check back in 24 hours!
Basic drivetrain loss. Gear ratios are different, hence different results. It is not specific to the FRS, or GT86. It's commonplace in all MT vs AT variants.
Regards,
The Following 6 Users Say Thank You to Drift-Office For This Useful Post:
D_Thissen (07-29-2015), FRSBRZGT86FAN (02-01-2016), Gruppe-s (10-05-2015), scioneric (07-29-2015), StayPuft209 (04-29-2016), Strife26 (11-05-2015)
Drift-Office : JDL Header... TUNED! :) Drift-Office Engine, Exhaust, Transmission 50 01-12-2017 06:32 PM
Drift-Office : HKS EL Header Tuned! Drift-Office Engine, Exhaust, Transmission 84 05-05-2014 12:34 AM
Drift-Office : Rev Works UEL Header... Tuned! Drift-Office Engine, Exhaust, Transmission 21 11-05-2013 08:45 AM
Drift-Office : Vortech / HKS EL / Perrin / Greddy Installed & Tuned! Drift-Office Forced Induction 8 09-03-2013 06:20 PM
Drift-Office : Vortech / Perrin Combo Installed & Tuned! Drift-Office Forced Induction 44 08-06-2013 06:37 PM
