CANADA Canada
Old 07-22-2015, 05:27 PM   #9255
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
Originally Posted by Pbrown View Post
Will I have an easier time passing emissions, if on the day of the test my tank is full of E85 and tuned as such ( OFT )?
If you have the CEL turned off for cat efficiency, your car will show "NOT READY" for those sensors. That will most likely fail you right there. Better bet is to drive around like crazy and hope the CEL isn't up on the dash
Sent from my A0001 using Tapatalk
drewbot is offline   Reply With Quote
Old 07-22-2015, 05:55 PM   #9256
driftops
Originally Posted by Ft86Chris View Post
We usually meet up on fridays, what end of town will you be in and for how long?
I'm staying near downtown.
Don't really know anyone here, so I'd be down for anything.
driftops is offline   Reply With Quote
Old 07-22-2015, 07:14 PM   #9257
pushrod
Benched 86lb
pushrod's Avatar
Drives: Ultramarine FR-S
Originally Posted by AznKirby View Post
I'm just teasing. Heh.
I'm still jealous that I haven't been out to Calabogie this year. Ugh.
How is it for you this season? Beaten any PB times yet?
Hoppefully I'll be soon though
Heh, haven't done any timing yet. I'll be there Friday but that might be pretty much it for the year, my tires are really worn out.
pushrod is offline   Reply With Quote
Old 07-22-2015, 07:33 PM   #9258
roddy
roddy's Avatar
Drives: '13 Ultramarine
The rule is every 7 years, right? ( for newer vehicles )
I think it is after the first 7 years, then every 2 years after that.
Old 07-22-2015, 09:24 PM   #9259
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
Originally Posted by UMB FR-S View Post
I don't think anyone stocks it locally but you can probably talk to Andre ( @Slick ) from slick auto to get it for you or you can order online. http://www.slickautosolutions.com/ his shop contact info can be found there he is a member of the group and cateres to the FRS crowd pretty well
Thanks, I can bring in the Perrin ones within a few days to a week depending when I am picking up in Ogdensburg. Perrin plate holder is $120, not on my site though. Feel free to call me at the shop 613-763-0011.
Slick is offline   Reply With Quote
Old 07-22-2015, 09:34 PM   #9260
86gt?
86gt?'s Avatar
Drives: asphalt 86
Originally Posted by jvincent View Post
I'll be there on Friday. What part of town do you live?
Barrhaven but I can get picked up wherever is convenient for you. Just don't wan't to ask a buddy to pick me up in Calabogie if I don't need too.
86gt? is offline   Reply With Quote
Old 07-23-2015, 07:53 AM   #9261
Pbrown
Drives: 2013 Scion FRS Raven
That's very interesting. The only CEL I get right now is because I have no TPMS sensors on my summer tires. Comes on after about 23 km's. I believe the O2 sensor has been by-passed because of the catless header on the car. I was thinking because the car still has one catalytic converter that by using the cleanest fuel possible I could squeak out a pass if no CEL's were present on the dash.
Pbrown is offline   Reply With Quote
Old 07-23-2015, 09:09 AM   #9262
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Unfortunately there are 2 O2 sensors in the car. It's the one closest to the header that will throw a cat efficiency CEL. There are a few people running catless without this tuned out, but I believe the car throws the CEL intermittently.....
Old 07-23-2015, 09:23 AM   #9263
jvincent
jvincent's Avatar
Just confirming, you mean drop off in Barrhaven, correct?
Assuming yes, that should be no problem. I'm downtown, so it's just a quick detour south.
Old 07-23-2015, 10:12 AM   #9264
ymboc
ymboc's Avatar
Err... it's typically the one *after* the cat that's responsible for detecting cat efficiency.
If the second O2 sensor is still present (and not removed completely) you could try using one or two drilled-out sparkplug defoulers to pull the second O2 sensor out of the exhaust stream enough that it will generate the kind of waveform (flat) the ECU is expecting to see.
ymboc is offline   Reply With Quote
Old 07-23-2015, 10:44 AM   #9265
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
I never said the pre-cat O2 was the one....but now that I look at the drawings, the post-cat O2 is closer
Old 07-23-2015, 06:01 PM   #9266
roddy
roddy's Avatar
IIRC, you are allowed 1 "not ready" from the computer. If one O2 sensor is shut off in the tune, you should be ok. My Mustang has 4 O2 sensors (2 before and 2 after the cats), and in many tunes, the rear 2 are shut off. That would cause a fail with that car. I expected that with the Mustang, but got one for the EGR system instead...still passed. The type of fuel used won't have any bearing on the test results. They don't use the sniffer anymore...just plug a computer into the OBD port.
A check engine light would be an automatic fail. They wouldn't even bother to hook it up. Thankfully, the warning light for tire pressure is separate from the Check Engine Light.
Old 07-23-2015, 10:44 PM   #9267
86gt?
86gt?'s Avatar
Drives: asphalt 86
I live in Barrhaven but was saying I could easily get a ride from say Ikea so you wouldn't have to go out of your way. But either way thanks for the lift and I will see you tomorrow night!
Old 07-23-2015, 10:51 PM   #9268
AznKirby
Are you 20/20?
AznKirby's Avatar
Drives: Hopes and dreams
Makes me glad I live in Quebec! No emissions
2014 FR-S Monogram
2005 Acura RSX Type-S
IG: @MonKehC
