Old 07-22-2015, 07:20 AM   #29
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
Something like [ame="http://www.amazon.com/Thrust-Needle-Roller-60x85x5-Bearings/dp/B00KDPN0TK/ref=sr_1_4?s=industrial&ie=UTF8&qid=1437563977&sr= 1-4&keywords=60mm+needle+bearing"]this[/ame] may solve the problem for good, you shouldn't have to lock down the perches insanely tight.
GSpeed is offline   Reply With Quote
The Following User Says Thank You to GSpeed For This Useful Post:
Sportsguy83 (07-22-2015)
Old 07-22-2015, 08:12 AM   #30
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by PST View Post
Do you have any sort of bearing between the spring and perch at either end? Springs torque when they compress, and if there's nothing to let the spring rotate at one end, it could be rotating the spring perch.
This are the Tein SF. It seems there's just a big flat washer at the bottom ring..
Old 07-22-2015, 08:14 AM   #31
Sportsguy83
Drives: Limited BRZ
Originally Posted by Sammakko View Post
by the way, do you know Erick Mahle?
The name sounds familiar, but don't think so.
Old 07-22-2015, 08:32 AM   #32
superleggera
superleggera's Avatar
Drives: BRZ / MX5 / S4
Shouldnt it still be able to spin at the top?
superleggera is offline   Reply With Quote
Old 07-22-2015, 08:33 AM   #33
superleggera
This is my first time using them, might be the last.
Same here, I might be looking for someone better after this winter.
The Following User Says Thank You to superleggera For This Useful Post:
Old 07-22-2015, 08:34 AM   #34
Sportsguy83
Drives: Limited BRZ
Yes, it definitely spins at the top.
Old 07-22-2015, 04:26 PM   #35
e1_griego
e1_griego's Avatar
Drives: Many
Something like this may solve the problem for good, you shouldn't have to lock down the perches insanely tight.
I've found that torringtons that are exposed like that usually don't hold up to the elements in the long term.
TechnoToyTuning sells this: https://technotoytuning.com/universa...-25-id-springs
or fortune auto sells these: http://www.frsport.com/Radial-Bearin...-_p_64223.html
Or Raceseng sells these:
http://www.frsport.com/Spring-Perch-..._p_281118.html
e1_griego is offline   Reply With Quote
The Following User Says Thank You to e1_griego For This Useful Post:
Hyper4mance2k (07-23-2015)
Old 07-22-2015, 05:26 PM   #36
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
Looking back, I've only ever run them on track cars that were taken apart regularly. I could certainly see long term usage on the street causing issues. Thanks for adding those options.
Jake
Old 07-23-2015, 12:29 PM   #37
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
that sounds dangerous as fuq. if it is lowering itself then that means the coilover is spinning clockwise while driving?
Old 07-23-2015, 01:00 PM   #38
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
How much preload do you have on the springs? Really don't see how the collars can move in relation to the threaded body once the collars are locked into position. If it's so tight that you have trouble loosening how do you suppose it's lowering on it's own?
Springs do tend to sag over time. Also, right after installation it will sit a few mm higher than it would after the springs "settle". Maybe that's the problem? The ride height is not truly 'set' until you've loaded and unloaded several cycles after installation.
Old 07-23-2015, 01:13 PM   #39
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
T0's
Old 07-23-2015, 01:48 PM   #40
Sportsguy83
Drives: Limited BRZ
Originally Posted by cdrazic93 View Post
T0's
No camber plate no care..
The Following User Says Thank You to Sportsguy83 For This Useful Post:
CSG Mike (07-23-2015)
Old 07-23-2015, 01:50 PM   #41
Sportsguy83
Drives: Limited BRZ
I didn't touch the preload. They are recommended from Tein to leave as they come unless you know what you're doing.
The suspension is not lowering a few mm, it's lowering from about 1 inch of threads all the way to the bottom.
Sucks that I won't know if it worked until I check again in a few months.
Old 07-23-2015, 01:57 PM   #42
solidONE
solidONE's Avatar
Pictures will definitely help. Before and after they lower themselves. Also If it is un-threading itself then basically you have no preload and when the shock is fully extended (car jacked up and wheels in full droop) you'd have a gap between the top of the coil and the perch thing above it. I still don't see how it's going to be unthreading itself on the shock body...
If it's the collar that locks the lower 'cup' in position, then somehow that collar is not doing it's job and allowing the shock body to rotate threading into the 'cup'. Might want to call Tein and complain to them. Maybe they already know of this problem and have a solution.
The Following User Says Thank You to solidONE For This Useful Post:
Sportsguy83 (07-23-2015)
Tein Street flex JM'sFR-S562 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 05-09-2015 11:04 AM
Tein Street Flex installation Help eguzman6 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 02-08-2015 03:08 PM
WTB - Tein Street Flex and some LCA's Sugi Want-To-Buy Requests 1 01-25-2015 03:12 PM
WTB - Tein Street Flex and some LCA's Sugi Want-To-Buy Requests 1 01-25-2015 12:40 AM
25% Off Tein Street Flex's!!! RallySport Direct Brakes, Suspension, Chassis 0 12-31-2014 04:52 PM
