#15 |
I Love custom Turbo kits
Drives: Limited BRZ
I only went the flathead route after using the spanner wrenches with all the force I could and still they lowered and a friend suggested he used to use it. I think the dirt might be the reason for them lowering.
Sent from my SAMSUNG-SM-N900A using Tapatalk
#16 |
Drives: 2015 brz
#17 |
Drives: '15 Halo FR-S
Check out fortune autos video on YouTube about setting up their coils. They specifically mention using a flathead and hammer to get them good and tight.
#18 |
Drives: 2015 brz
#19 |
#20 | |
Drives: 2015 brz
![]() P.s. I'm an ASE certified mechanic and that isn't my career... |
#21 |
Drives: 2015 BRZ
Do you have any sort of bearing between the spring and perch at either end? Springs torque when they compress, and if there's nothing to let the spring rotate at one end, it could be rotating the spring perch.
#22 | |
Drives: BRZ / MX5 / S4
What actually tipped me off is that there was a lot of slack in the spring (basically not preloaded at all). I remember when I installed them, with the standard Tein preload the springs didnt have any slack. |
| The Following User Says Thank You to superleggera For This Useful Post: | Sportsguy83 (07-21-2015) |
#23 |
Drives: Scion FRS
I sort of had this issue when I first installed them but only with the fronts. They lowered themselves until it maxed out. Then i realized I did not tighten them enough even thought I thought I did. I used the Tein Keys and used a socket wrench where it had that square hole to get more leverage and turned it until it would not move and now they have not moved at all even after ample track days.
| The Following User Says Thank You to babykwiss For This Useful Post: | Sportsguy83 (07-21-2015) |
#24 | |
Drives: Limited BRZ
| The Following User Says Thank You to Sportsguy83 For This Useful Post: | CSG Mike (07-22-2015) |
#25 |
Bilge monkey
Drives: '13 BRZ, 82 starlet
it amazes me that Tein is considered a quality product. After seeing how quickly their springs sag, i was turned off for life.
sorry you're having this problem man. you could drill/tap your adjustment perch, and put a setscrew in to jam the nut into the thread, most other companies use this method. or a collar clamp would work (look on mcmaster.com for collar clamps) |
| The Following 2 Users Say Thank You to Sammakko For This Useful Post: | a_dee (07-25-2015), Sportsguy83 (07-22-2015) |
#26 | |
Drives: Limited BRZ
| The Following User Says Thank You to Sportsguy83 For This Useful Post: | superleggera (07-22-2015) |
#27 |
Bilge monkey
#28 | |
Drives: Many
A radial bearing setup that allows the spring to rotate independently is the fix. Tapered threaded bodies all seem to do this, which is why you have to lock the collars down so tight. |
| The Following User Says Thank You to e1_griego For This Useful Post: | GSpeed (07-22-2015) |
| Tein Street flex | JM'sFR-S562 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 05-09-2015 11:04 AM |
| Tein Street Flex installation Help | eguzman6 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 02-08-2015 03:08 PM |
| WTB - Tein Street Flex and some LCA's | Sugi | Want-To-Buy Requests | 1 | 01-25-2015 03:12 PM |
| WTB - Tein Street Flex and some LCA's | Sugi | Want-To-Buy Requests | 1 | 01-25-2015 12:40 AM |
| 25% Off Tein Street Flex's!!! | RallySport Direct | Brakes, Suspension, Chassis | 0 | 12-31-2014 04:52 PM |
