Old 07-13-2015, 03:26 AM   #43
Gruppe-s
Drives: Time-attack Scion Race car
Originally Posted by SPCorBUST View Post
Yes, I do.
Yes, soon.
I don't have the baseline set yet though, but I will probably get a tune, then do a stock header swap later, do a couple passes just to see the number, then get a small tune adjustment and dyno again though.
Someone is testing them now, on both an automatic and manual. The results will be posted soon, so keep an eye out for it.
Gruppe-s is offline   Reply With Quote
The Following 3 Users Say Thank You to Gruppe-s For This Useful Post:
continuecrushing (07-13-2015), D_Thissen (07-15-2015), SPCorBUST (07-13-2015)
Old 07-15-2015, 05:44 PM   #44
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
So I've had several people at stoplights mention how badass the car sounds! And rev-matching sounds freaking awesome.
UEL is really the way to go haha.
The Following User Says Thank You to continuecrushing For This Useful Post:
eggncheese (07-16-2015)
Old 07-19-2015, 11:29 PM   #45
SPCorBUST
SPCorBUST's Avatar
A week late, but better than never. Current setup:
Jackson Racing Supercharger
Gruppe-S UEL Header
Perrin Foam Filter
Perrin 2.5 over pipe
Perrin 2.5 front pipe
Perrin 2.5 catback exhaust
Cold Start
[ame="https://www.youtube.com/watch?v=XGNCH73HjD8"]Gruppe-S UEL Header BRZ/FR-S/GT-86 Cold Start[/ame]
Warm Start Revs Rear
[ame="https://www.youtube.com/watch?v=ohopihXrv9c"]Gruppe-S UEL Header BRZ/FR-S/GT-86 Outside Rear[/ame]
Warm Start Revs Front
[ame="https://www.youtube.com/watch?v=UO6j_XdhIrg"]Gruppe-S UEL Header BRZ/FR-S/GT-86 Outside Front[/ame]
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
SPCorBUST is offline   Reply With Quote
The Following 7 Users Say Thank You to SPCorBUST For This Useful Post:
continuecrushing (07-20-2015), CSG Mike (07-20-2015), eggncheese (07-20-2015), JonAvalon (07-20-2015), Strife26 (11-05-2015), tinma (11-16-2015), WhiteFRS69 (07-22-2015)
Old 07-19-2015, 11:49 PM   #46
SPCorBUST
SPCorBUST's Avatar
Real quick difference on Tomei vs. Gruppe-S UEL besides the obvious stamping on the flange and the runner paths - the bridges are on the top of the header rather than on the bottom.
The benefit is that with the Tomei header, some customers have noted a tapping sound that comes from the bridges tapping against the undertray, but since those bridges are no longer there for the Gruppe-S, it may not produce that tapping sound. Nice change.
Tomei (picture from RallySport Direct)
Gruppe-S (from my build thread)
From my perspective, it looks like the flanges, collector, and shorter runners are the same, and the only difference is in the longer runners, for better or worse, who knows.
The Following 4 Users Say Thank You to SPCorBUST For This Useful Post:
D_Thissen (07-20-2015), eggncheese (07-20-2015), Gruppe-s (07-20-2015), Strife26 (11-05-2015)
Old 07-20-2015, 04:49 PM   #47
drew_kar
drew_kar's Avatar
Drives: WRB Brz / SR S14
Originally Posted by Gruppe-s View Post
1 year warranty. Over pipe is $125, order it same time as header and it ships free.
Pm sent.
drew_kar is offline   Reply With Quote
Old 07-20-2015, 07:04 PM   #48
Gruppe-s
PM replied
Old 07-20-2015, 10:03 PM   #49
PNW FRS
PNW FRS's Avatar
Make sure I didn't send you a WRX header please before you coat it.
Sorry for Noob question... but is coating the header to hide "bluing" (discoloration) from heat -- or -- protection against rust in wet environments -- or -- both?
2013 Asphalt / MT
Olympia, Washington
PNW FRS is offline   Reply With Quote
Old 07-20-2015, 10:12 PM   #50
RobertPaulson
Hisnamewasrobertpaulson
RobertPaulson's Avatar
Drives: 2017 Golf R
likely getting it ceramic coated to reduce the amount of heat that gets into the engine bay.
This is your life and it's ending one minute at a time.
RobertPaulson is offline   Reply With Quote
The Following User Says Thank You to RobertPaulson For This Useful Post:
Bergen23 (07-20-2015)
Old 07-20-2015, 10:16 PM   #51
Gruppe-s
It shouldn't rust, the material is stainless.
There are a bunch of different coatings available out there. I will do some research to get a price on aluminized coating, not sure about the heat protection, but it is resistant to high heat and excellent in regards to durability.
Old 07-20-2015, 11:14 PM   #52
PNW FRS
PNW FRS's Avatar
I'm no SS expert... but I've seen rust on some SS products... usually near welds and such. That said, never took a brush to it to see if it was surface rust or rust adhering to something metallic on the SS. I've also heard of SS not holding up great in salt-water-salt-air conditions (e.g., ss fittings on sailboats). Extreme conditions yes... just say'n. As far as heat protection.. that would be great if true (i.e., can be substantiated with test data). The engine bay can get pretty hot after prolonged hard driving, so anything that could mitigate that would be a plus.
Thanks for the feedback... was just curious.
2013 Asphalt / MT
Olympia, Washington
Old 07-20-2015, 11:17 PM   #53
Bergen23
Drives: '15 Halo FR-S
Generally, any metal exposed to the elements will rust without adequate protection. Ie: a coating and/or cathodic protection.
Bergen23 is offline   Reply With Quote
Old 07-21-2015, 12:18 AM   #54
Gruppe-s
I will get a header coated in the available coatings we have here and see if you are interested in them. I will offer them at cost to see if it helps with those headers exposed to more harsher conditions.
The Following User Says Thank You to Gruppe-s For This Useful Post:
Bergen23 (07-21-2015)
Old 07-21-2015, 12:34 PM   #55
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Heard a lot of good thing about this header (both quality & dyno).
Very temptin' to get one...
The Following 3 Users Say Thank You to ichitaka05 For This Useful Post:
Gruppe-s (07-21-2015), raven1231 (07-21-2015), RobertPaulson (07-22-2015)
Old 07-21-2015, 12:36 PM   #56
drew_kar
drew_kar's Avatar
I think it's the new go to header for people who don't want the ace, jdl 1k+ headers
gruppe, gruppes, header, uel, unequal length
DIY X REVIEW: CNT UEL HEADER INSTALL adamg Engine, Exhaust, Transmission 73 07-27-2023 09:58 AM
P&L Header install, review and impressions D K Engine, Exhaust, Transmission 54 05-30-2019 12:35 AM
Top Speed EL Header Review, Install, and Pictures tomaszjanczak Engine, Exhaust, Transmission 0 10-11-2014 07:27 PM
Vortech Offical Owner Thread cjsporl1996 Forced Induction 2 03-27-2014 12:50 AM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 12:58 PM
