Old 07-20-2015, 08:02 PM   #15
customyota
Drives: WRB BRZ
Originally Posted by Chimera View Post
Yes, you could do this. Be careful to not over gain one however.
basically you're making a poor mans active setup.
However, using the eq on your Hu should allow you to do the same thing. I have my 10k on my HU set to 1 tick down, something like -2.5db
Cool thanks. My eq is bottomed out for the highs just to make it tolerable, and since I'm not bridging anymore, I figured I might as well try to use those other two channels for something. Hopefully this will give me a little more control. Thanks for the help!
Sent from my Nexus 6 using Tapatalk
customyota is offline   Reply With Quote
Old 07-20-2015, 11:04 PM   #16
Chimera
Drives: FRS
On the topic of gain on the ktp 445u recommends no higher than the 9oclock position for speaker level inputs. Exceeding that could lead to noise
Old 07-20-2015, 11:09 PM   #17
Chimera
Drives: FRS
I did some brush up on passive crossovers. This may not work as I think the crossover expects load and the amps line level inputs are something like 10k ohms. You may actually need a active cross over to do what you are looking to do
Old 07-21-2015, 10:30 AM   #18
customyota
Drives: WRB BRZ
You're right, I didn't think about the amp's impedance. Well that's why I wanted that second opinion. I guess it's going to be full active then, anyone have suggestions on a crossover that has band pass capabilities? There doesn't seem to be a lot of choices on Crutchfield, or any of my normal shopping sites.
Old 07-21-2015, 10:32 AM   #19
customyota
Drives: WRB BRZ
Old 07-21-2015, 11:12 AM   #20
Chimera
Drives: FRS
because I am curious, what audio source are you using for listening?
Old 07-21-2015, 02:31 PM   #21
customyota
Drives: WRB BRZ
Primarily Bluetooth, but I've tried the auxiliary cable and fm as well, since I've had issues with Bluetooth sound quality in the past.
Old 07-21-2015, 02:37 PM   #22
customyota
Drives: WRB BRZ
I'm thinking that this is a crossover issue. Some music, particularly pop with female vocals, is very shrill, while other stuff, like rock is muddied because all the highs are eq'd out. I used a tone generator to see how low my tweeters are playing, and they're getting a fair amount of signal around 1k, so it seems like I'm probably getting resonance in the tweeters. I opened up the crossovers, and looking at the components, it looks like they're simple 6db crossovers, so I'm thinking a decent active crossover will help me out.
Stock Tweeters Available pd Audio/Visual, Electronics, Infotainment, NAV 0 07-31-2013 10:04 PM
New CDT ES-620 6.5" with crossovers + tweeters vinh Audio/Visual, Electronics, Infotainment, NAV 0 07-01-2013 11:52 PM
Need help on tweeters djliquidsteele Electronics | Audio | NAV | Infotainment 3 05-17-2013 08:13 PM
Tweeters that will drop in? SteveGrillo Electronics | Audio | NAV | Infotainment 13 02-18-2013 07:17 PM
