Old 07-16-2015, 08:19 AM   #337
nexusatm
nexusatm's Avatar
Drives: GT86
Hello ��, if I install Cusco final gear 4.566 in AT will it work correctly or I must correct rom? If need to correct how I can do it?
Thx
nexusatm is offline   Reply With Quote
Old 07-16-2015, 09:01 AM   #338
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Thx
It's nothing to do with engine.
You really need a 4.88 to make it worthwhile on AT.
Or just get UEL headers and a decent tune and you have a very drivable power band.
Old 07-16-2015, 09:18 AM   #339
nexusatm
nexusatm's Avatar
Drives: GT86
I have st2 el on my car) Final gear 4.566 i bought for my self, i have MT. But want to sell it to guy with AT. Need money for a turbo))) I afraid that this guy will take a problem with 4.556 . Many people tell me about trasmisson brains gone to crazy due 4.566
Old 07-16-2015, 09:27 AM   #340
Wayno
Wayno's Avatar
I don't know personally. The transmission will still rev match because the ratios are exactly the same. It's not really any different than adding a turbo - both are just more torque at the wheels. Nothing to do with ecu though, except perhaps need to update gear determination threshold which is likely only for dash.
Old 07-16-2015, 01:18 PM   #341
xsnapshot
Fast enough
Drives: 2013 Subaru BRZ AT
This will be my next mod, before I go supercharged even.
I found a reputable shop that will do all the work for $350 if I bring them the parts. So...not too bad IMO.
I've debated a lot on 4.55 vs 4.88 and have pretty much settled on 4.88. Why not?
Wayno, do you have the AT with 4.88's?
xsnapshot is offline   Reply With Quote
Old 07-16-2015, 08:15 PM   #342
steve99
Drives: FT86
Hmmm its possible it could upset auto trans. The wheel sensors appear to be used for speed sensing as when you change final drive diff ratio speed still reads correctly.
Dont know if auto trans has other sensors in trans that sense rotational speed ect that manuall does not if so it may get upset as you suggest.
best to find someone who has changed final drive in auto maybe post in engine exhaust transmission thread
Old 07-19-2015, 04:57 PM   #343
el-92
el-92's Avatar
Drives: 2014 ASPHALT FR-S MT
quick question if your going to dyno tune the car whats the quickest way for it to learn fuel trims and adjust everything.. is there a way to turn off closed loop and run open loop all the time still in the process of learning all this.
thanks
el-92 is offline   Reply With Quote
Old 07-19-2015, 06:45 PM   #344
steve99
Drives: FT86
thanks
do 2 or 3 of light steady throttle or so 2000-7000 rpm runs in 2nd or 3rd
ie slowly let the rpm climb your attempting to keep the ecu in closed loop during the process.
see flashing reset learning link below.
Old 07-20-2015, 11:34 AM   #345
nexusatm
nexusatm's Avatar
Drives: GT86
Hello, are you know about course of direct injection crash?
Old 07-20-2015, 01:46 PM   #346
iConformed
Hey all, just flashed the Stage 2 UEL e85 tune for the first time. I followed the instructions for flashing, it's been 40 miles since flashing and I'm still getting a CEL (Never had one before). I'm still driving below 3.5k, the fuel trims look fine though.
Should I unplug battery/fuse to reset ECU? I searched around and couldn't find anything related so don't flame me if this has been covered
Update: CEL went away, all is good and I'm loving the e85 tune!
iConformed is offline   Reply With Quote
Old 07-20-2015, 05:38 PM   #347
steve99
Drives: FT86
If you have auto transmission it was probably P0700, you can read it with oft.
This happens a lot during flashing as ecu and auto trans computer loose communications, it goes away after a couple of drive cycles or you can reset it with an obd scan tool or similar.
Old 07-20-2015, 11:36 PM   #348
el-92
el-92's Avatar
So that's the quickest way OK thanks steve99. another thing say I zero out the closed loop fueling . won't that make it run open loop all the time that's what I read up on the ROM raider page and if closed loop isn't there won't the map just reach the target of the open loop fueling and be good to go ? Instead of learning fuel trims all the time .Which is what makes the flashes slow
Old 07-20-2015, 11:43 PM   #349
steve99
Drives: FT86
If you maf scaling is good your long term fuel trims will be low like less than 5% so fuel trim learning is very quick or not needed
and it wont be knocking if tune is good, most tunes will set IAM to 1 initial to avoid waiting for IAM to get to 1 .
Old 07-21-2015, 01:29 PM   #350
el-92
el-92's Avatar
My ltft is around 2.35% from what I saw in the morning when driving.. Ima do a datalog later today during lunch break and upload it tonight.
Sent from my Nexus 6 using Tapatalk
WTB: Open Flash Tablet TOZER Canada Classifieds 3 07-05-2015 08:13 PM
Open Flash Header & Open Flash Tablet Calavera Engine, Exhaust, Bolt-Ons 9 05-11-2015 09:27 PM
FS: open flash headers / open flash tablet - SOLD alanhung85 Canada Classifieds 12 02-10-2015 03:08 PM
FS: Open Flash Tablet (OFT) mex2309 Engine, Exhaust, Bolt-Ons 1 10-29-2014 03:49 PM
Open flash tablet. cooldandani Scion FR-S / Toyota 86 GT86 General Forum 1 02-22-2014 08:14 PM
