Old 07-19-2015, 12:30 PM   #449
drambo136
drambo136's Avatar
Drives: 2013 Hot Lava
So I've had my turbo for roughly 5k miles. I have the k&n air filter on there and its already torn up from the a/c line. Has anyone found a good alternative?
Sent from my SAMSUNG-SM-N900A using Tapatalk
drambo136 is offline   Reply With Quote
Old 07-19-2015, 12:36 PM   #450
xxscaxx
Drives: 2013 SWP BRZ
Seems like overboost is a common factor here...since I am also overboosting on my EBCS.
@drambo136 - have you tried repositioning it? Mine clears the ABS. It does sit slightly on the washer fluid neck though, but just barely.
xxscaxx is offline   Reply With Quote
Old 07-19-2015, 12:37 PM   #451
drambo136
drambo136's Avatar
Go sprung weight. U can't go wrong other than u can't adjust much
Old 07-19-2015, 12:41 PM   #452
xxscaxx
i'm still overboosting on wastegate pressure. And I have my tune set up for flex fuel and boost based on ethanol. All of that goes out the window if I run WG pressure.
Old 07-19-2015, 12:44 PM   #453
drambo136
drambo136's Avatar
Ohhhh lol wasn't aware it was based off ethanol %. I wanna do that so bad lol. I know u probably already checked it but is the other port on the WG still blocked off. I was overboosting at one point and it was because the bolt came a little loose
Old 07-19-2015, 01:18 PM   #454
xxscaxx
the top port is VTA, the rest are all sealed besides the one that goes to the EBCS. But I will double check, thanks
Old 07-19-2015, 03:08 PM   #455
erok81
Drives: 2015 BRZ
I gave up on mine. I was going to try just running the wastegate spring with the EBCS unhooked but I get a dtc for the purge valve. I just make sure I don't floor it and don't rev past 5k. Really sweet for a turbo kit. Haha.
Running like they suggested with the boost creep, I get knock and my iam never goes above 0.7x ok either high or low boost. And my afr is mid 12's on 91.
I'm going to call it a $1000 dollar loss and take it somewhere locally for the tune. Well 650 since I'd have to buy the license wherever I take it.
erok81 is offline   Reply With Quote
Old 07-19-2015, 10:05 PM   #456
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Originally Posted by JDLAutoDesign View Post
We have a loca BRZ in today so we will have come up with something for the oil cooler
I know it's only a little over a week since posted... but any updates on this?
Trying to wait on ordering a cooler to see how this turns out.
Old 07-20-2015, 08:35 AM   #457
nelsmar
was the advance multiplier drop from being in boost or during partial throttle non boost conditions? (it makes a difference). mid 12's AFR is definitely not good. Which BOV revision do you have? (Where is the BOV located).
My flickr - Canibeat
Local magazine scout
Old 07-20-2015, 08:55 AM   #458
drambo136
drambo136's Avatar
Idk maybe I have a different filter than you all cuz mine hits everything
Old 07-20-2015, 11:56 AM   #459
JDLAutoDesign
JDLAutoDesign's Avatar
Drives: 13 FRS
We did see photos below. We are currently having our machine shop make the brackets
These brackets will include air guides
JDLAutoDesign is offline   Reply With Quote
The Following 3 Users Say Thank You to JDLAutoDesign For This Useful Post:
Andrew025 (07-20-2015), kch (07-20-2015), Rybot (07-20-2015)
Old 07-20-2015, 01:45 PM   #460
erok81
Drives: 2015 BRZ
I also did a log of just cruising - the multiplier there was 0.73 the entire time. Shortly after I did the pulls.
My high boost pull started at 0.71 and looks like it dropped to 0.67 once I built boost. AFR's never dropped below 12. Average the pull was 12.3.
Low boost showed 0.71 multiple the entire time. AFR's were high 11.9x to low 12.1.
BOV is on the driver side.
Old 07-21-2015, 01:27 AM   #461
erok81
Drives: 2015 BRZ
Post once you have the brackets and ducting made. I'm curious what it looks like. I think the way it is currently mounted with air flow coming in the fog hole and out the fender liner (I haven't made the back vent yet) would work better. But that set up looks like it has some room behind for exiting air. Depending how the front air ducts go.
Also will you offer any upgrades for those who got the kit before the new mounting? I'm still on the fence if I want it the new way or the old way.
Old 07-21-2015, 07:19 PM   #462
JDLAutoDesign
Drives: 13 FRS
We are already sending you a set
The Following User Says Thank You to JDLAutoDesign For This Useful Post:
erok81 (07-21-2015)
HKS Supercharger owners thread wbradley Forced Induction 1054 10-26-2024 01:18 PM
P&L Turbo kit Owners thread Hawaiian Forced Induction 73 07-07-2018 02:31 AM
To Greddy Turbo Owners (or SBD/Zage Turbo).... Melted Radiator Fans? General Opinion? xuimod Forced Induction 106 09-01-2016 07:33 PM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 12:58 PM
P&L Turbo Owners Topic Thread GTB/ZR-1 Forced Induction 4 09-01-2013 06:27 PM
