Old 07-18-2015, 03:00 PM   #1
ChicagoNole
Drives: 2014 FR-S
Missing grommet rear wheel well?
Howdy folks!
This is my first post, so hello. Thank you for having me.
I just bought a new FRS last weekend..schwweeet!
Quick question, am I missing grommets (snap in) in the rear wheel well area? Seems odd that there are none there.
Link to photo:
https://www.dropbox.com/s/xbdknsr8fj...ommet.JPG?dl=0
There are 2 clearly empty holes. Do any of you have empty holes lol?
ChicagoNole is offline   Reply With Quote
Old 07-18-2015, 03:04 PM   #2
Kostamojen
All the cars come like that. I put some plugs in mine just because.
Old 07-18-2015, 03:20 PM   #3
ChicagoNole
Drives: 2014 FR-S
Thank you, I'll do the same.
Old 07-18-2015, 03:25 PM   #4
extrashaky
Drives: 2014 BRZ Limited
You're not missing anything. Those are the holes for mounting the Scion factory mug guards. If you buy a BRZ or don't order factory mud guards from Scion for an FR-S, you just have holes there.
Old 07-20-2015, 08:54 PM   #5
Zhangy
Drives: 2015 FRS
mine has it stock, why did you need to buy it...?
Zhangy is offline   Reply With Quote
Old 07-20-2015, 10:12 PM   #6
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Because #MURICA
Old 07-20-2015, 10:30 PM   #7
Only the Canadian's get stock mudguards, heated mirrors and no lowering springs on the RS1. I think they are trying to tell us something.
Old 07-20-2015, 10:31 PM   #8
Bergen23
Drives: '15 Halo FR-S
Being that you're a safety guy (from what I remember) I'm sure you cleared all that snow off your car before leaving the driveway
Bergen23 is offline   Reply With Quote
Old 07-20-2015, 10:33 PM   #9
UMMMMMM.....weeeeeell
Actually I was pulling into the laneway. Pulled in, decided to snow blow and backed up to the end.
Old 07-20-2015, 10:50 PM   #10
BlackJesus
Shut up baby, I know it
BlackJesus's Avatar
Drives: 2013 BRZ DMG
what kind of tires do you got on there? Did you lowered your car by any chance? what is it like in canada? Can i stay over for a few days? so many questions yet little time
BlackJesus is offline   Reply With Quote
Old 07-21-2015, 06:28 AM   #11
Any good snow tires (SNOW tires not "performance "snow tires). Lowered 1& 1/2 inches. Where I am much like Michigan only cleaner, nicer people (mostly nicer) and less guns. Sure. I have time.
Old 07-21-2015, 07:44 AM   #12
Sarlacc
/dev/null
Sarlacc's Avatar
Drives: Uphill
Old 07-21-2015, 11:11 AM   #13
BlackJesus
BlackJesus's Avatar
I bought some blizzaks which helped alot but I still get stuck often on stock height. I wanted to drop 1 inch on springs. Are you currently using coilover or springs? Ohio weather is like Satan's playground. Once month is could be snowing 10 inches @-20 degree the next could be a heat wave at @110 +
Old 07-21-2015, 11:30 AM   #14
Since I am directly across Lake Erie from Ohio we get much the same weather (in fact part of Ohio is actually north of me).
The trick for driving in deep snow is:
Turn off traction control - You will get stuck as soon as one wheel spins and it cuts power to the other.
Slow steady starts in 2nd gear - If you spin the tires and they dig in and turn the snow to ice you are done.
Don't panic and back off too much if the rear starts to swing a little - Once you are moving keep moving. The rear will only swing so far if you are gentle.
Shift with gentle clutch engagement at lower revs - No car will react well to sudden changes in snow.
Don't be timid - Pausing, hesitation or over reaction will get you stuck faster than anything else.
I live on a street that is rarely plowed and have smashed through snow that was 14+ inches deep and waved to the AWD drivers that were stuck while I did it.
BlackJesus (07-21-2015)
Missing clips on rear inner fender MikeyBatz Scion FR-S / Toyota 86 GT86 General Forum 8 04-19-2016 04:48 PM
Where is this grommet from? Weeber Scion FR-S / Toyota 86 GT86 General Forum 3 12-08-2013 12:15 AM
Missing fender screws in the back wheel well mechaghost BRZ First-Gen (2012+) — General Topics 22 09-24-2013 02:05 PM
Is my rear bumper missing some screws? smallfun Scion FR-S / Toyota 86 GT86 General Forum 26 05-29-2013 09:15 AM
Missing pegs in the wheel well? twodollarcuts Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-06-2012 10:53 AM
