Old 07-13-2015, 12:28 PM   #9003
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
How did it go @fenton @Robftss
Installed Mods:
Old 07-13-2015, 12:28 PM   #9004
Sojhinn
Sojhinn's Avatar
Also @Gums please tell you are installed
Installed Mods:
Old 07-13-2015, 12:30 PM   #9005
fenton
I don't think the kit i got sent has the taps and i'm not comfortable with soldering. I will probably just wait for Rob to get back from vacation to install it.
I have a laptop with a console connection so i dont need the adapter. I didnt know if the installation would be different because this unit is different than what everyone else got.
fenton is offline   Reply With Quote
Old 07-13-2015, 04:07 PM   #9006
SOAZ
Drives: pinto
Originally Posted by murselyfe View Post
Haha... yeah... I think I've been on the list for almost a year and it just happened to have come at not the best time.
However... selling it may bring about ragrets.
If you install it, you wont ever uninstall it. It's the meth of engine mods. Cheaper and less powerful than the other FI options, but EVERY bit as addictive.
SOAZ is offline   Reply With Quote
Old 07-13-2015, 08:18 PM   #9007
dtek
Drives: 86 A00I
Yep, he is and so am I. Excellent instruction video btw.
The RHD version goes basically the same... however were I to do it again I'd run some of the Procede harness cables differently, ie, adjusting length where one or two are too long, and not having the 5v signal wire sheathed with the ECU tap wires.
We both soldered rather than tapped, and although yes it's more time consuming, the peace of mind is worth it (IMO). Added secure dedicated connectors on all wires also to make it an easy unplug job if needed.
For a future release, a piggyback connector arrangement that inserts between the OEM ECU harness plug, and the ECU itself (with the two new wire outputs) would be truly ideal.
Also, FYI for any future user's info, to change maps you only need to have the system on, the laptop connected, and then simply select a different map. That wasn't really clear to me until I tried it, and I couldn't find that instruction online anywhere. You'll see it indicating progress of the new map upload in the software bottom bar.
Sidenote: my fuel consumption with procede seems to have taken a 10-15% hit, but makes sense coz the boosts are being stuffed into the engine more often.
dtek is offline   Reply With Quote
Old 07-14-2015, 12:51 AM   #9008
Gums
Drives: SWP BRZ
All up and running, many many thanks to Sojhinn and Dtec for all the help.
RHD is a little different, luckily the ECU wires are the same colours, although reversed compared to LHD. As Dtec mentioned, I removed the 5v signal wire from the sheath with the ECU tap wires.
Mounted the Procede with velcro to the back of the drivers knee airbag and added connectors to most wires. Ended up removing the stereo jacks.
Bought a Grimmspeed strut bar to support under bonnet cables and added 30A Anderson connectors for the 12v power cables. Also ran the AUX signal wire in the same shrink wrap as it was a fraction short and easier to remove this way.
Moved the starter battery so I could have the dump batteries just that bit closer for heavier/shorter set of dump cables. Still have some adjustments to do to the battery hold down which I'll do when upgrading the start battery.
Gums is offline   Reply With Quote
Old 07-14-2015, 01:18 AM   #9009
Gums
Drives: SWP BRZ
Driving Impressions
Loved the origional kit.
This new version is so much better. Definitely agree with the larger engine comments. Running Sojhinn's V2 procede tune, like how I can cruise at 110k without engaging, though find excuses to engage anyway.
Old 07-14-2015, 10:49 AM   #9010
LucidMomentum
No Money, No Problems
LucidMomentum's Avatar
What connectors did you use for the Procede wiring?
For reference, did you also use Anderson connectors or did you use something else? I'm curious because it seems that having a set of connectors handy to wire up to everything when I get my kit would make the install a bit easier than if I were to just use taps or crimp connectors.
Did you guys have any trouble getting the connectors through the firewall?
Old 07-14-2015, 09:01 PM   #9011
Gums
Drives: SWP BRZ
For the procede ECU wiring I used a 2 Pin Miniature Nylon MOLEX-Type Connector although any small 2 pin locking plug would suffice.
All other procede connections were made with un-insulated male and female spade terminals which were seperately insulated after soldering with HD srink wrap.
The only Anderson connectors I added were on the start battery to controller cables. As I'm RHD these cables are much longer and I wanted the flexability of being able to seperate most of the cable from the controller. Used small 30A ones for this. If my BRZ was LHD I wouldn't have bothered.
No, plenty of room using the sound tube hole. Easier if you push something through from the footwell, tape the leads to this and carefully pull them through. I enclosed all these wires in a fully taped cable tube for the under bonnet area. Held it in place with self adhesive cable tie holders.
Old 07-15-2015, 10:40 AM   #9012
LucidMomentum
Thanks for the advice! Sounds like it's worth it just for ease of mind.
Old 07-15-2015, 09:16 PM   #9013
murselyfe
murselyfe's Avatar
Drives: It's black.
Full throttle Electric Supercharger Build Thread
Oops.
Moved.
2013 Subaru BRZ Limited- Crystal Black Silica
murselyfe is offline   Reply With Quote
Old 07-15-2015, 09:33 PM   #9014
Sojhinn
Sojhinn's Avatar
Who here is in SoCal and waiting for their Phantom ESC kit?
Get at me.
Wow.
Installed Mods:
Old 07-15-2015, 09:50 PM   #9015
raven1231
Wow.
Am I missing something?
Old 07-15-2015, 09:55 PM   #9016
Sojhinn
Sojhinn's Avatar
He's selling it (I'm assuming) and I'm guessing someone on the wait list is going to be happy. So wow.
Installed Mods:
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
