Old 07-14-2015, 01:11 PM   #15
WGMGR
Drives: WRB Limit BRZ 2015
Build a spec Miata, cheaper than an 86 and over 5 seconds a lap quicker than a stock BRZ around Laguna Seca and a huge community and aftermarket available.
And then you can actually go race it for a season or two with the money you saved from not buying a Toyobaru.
Would be the smart thing but i want a car i like, and nothing against the miata, i just dont like it. I already own a brz
WGMGR is offline   Reply With Quote
Old 07-14-2015, 01:12 PM   #16
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Originally Posted by MaximeT View Post
I dunno much about miata, 5 seconds with same tires on both cars ?
Who said anything about the same tires? We're talking about building a racecar aren't we? Sure you can go faster with an 86 if you spend some money on modding it, you'll also go faster with a C5 or C6 Corvette and even faster with a 911 or GTR. But for less than $20k you'll have a car that's faster than the >$20k you'd spend on a used 86, not to mention the cost of building the 86 to match.
And racecar
This is a few years old, this past year some of the legal guys were dipping into the 1:45 range, the illegal guys were well into 1:45. And to be clear, spec miata has the motors sealed to factory specs, we're talking about a car with ~130 horses at the crank, non-adjustable bilsteins, roll cage and sticky rubber being 5 seconds faster than Randy Pobst with a stock BRZ being timed by a magazine. With a good turbo build and some money on a high quality damper spring combo an old p.o.s. Miata would be wicked fast, might be able to get under 1:40 with balls of steel? Mclaren P1 and Porsche 918 are right around 1:30?
[ame="https://www.youtube.com/watch?v=QuVeqR5Ke54"]Laguna Seca Track Record Lap -- Sealed Spec Miata - YouTube[/ame]
Then why ask? Go build your racecar BRZ, you won't be the first and you most certainly won't be the last, go have fun.
And if you 'like' the Lotus more then save up for the Lotus, see if you can test drive one before you commit to not working on the BRZ.
ineedyourdiddly
Old 07-14-2015, 01:19 PM   #17
MaximeT
MaximeT's Avatar
Drives: GT86-ACE-JRZ-RPF1-Essex
FT86 laptimes on stock tires means nothing to me. Even with a good driver.
Spec Miata looks like a good car.
That's the rookie car in iRacing. It works fine.
JRZ 12-32 | ACE 350 | Delicious Tuning | RPF1 | Essex Sprint | SPL | Powerflex | My Car
MaximeT is offline   Reply With Quote
Oil filter threading stripped davtbaum Issues | Warranty | Recalls / TSB 53 06-03-2017 01:10 PM
HELP! Lug nut and wheel stud stripped! jaydee_do_work Scion FR-S / Toyota 86 GT86 General Forum 17 07-26-2015 01:50 PM
Wheel bolt stripped 2pointSLOW86 Issues | Warranty | Recalls / TSB 23 10-13-2014 02:29 AM
Have you stripped some weight off your FRS? gt8613 Scion FR-S / Toyota 86 GT86 General Forum 39 08-20-2013 02:11 PM
86 platform so good that new Supra and Z4 may use it 7shades Scion FR-S / Toyota 86 GT86 General Forum 20 02-12-2013 12:10 PM
