Old 07-09-2015, 03:38 PM   #1
megamarines
megamarines's Avatar
Drives: 2015 FR-S RS 1.0
Send a message via AIM to megamarines
NA Injector Upgrade?
Hey guys, so I decided on building my motor decently and keep it NA for a while until the warranty dies on me. I do have some questions and ideas, though.
My goal before doing any forced induction would be pulleys, bigger throttle body, maybe a bigger intake manifold, header, radiator, oil cooler, and full exhaust. Obviously if custom tuned, would 400-550cc injectors be too much? I want to maximize efficiency of the motor, but was wondering if injectors would help me with more power if I wanna go beyond the standard 210 of NA.
I rarely work with injectors, but I figured it's worth asking. Any help or details would be great.
megamarines is offline   Reply With Quote
Old 07-09-2015, 03:44 PM   #2
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
You shouldn't need to upgrade injectors for N/A power at all. Even when running E85.
Old 07-09-2015, 03:48 PM   #3
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Not really, the stock injectors are fine upto about where avo's turbo kit can get you on low-ish psi. ~260whp. So far i havent seen anyone crack 215 to the wheels NA yet. Hopefully that ultimate NA thread will shine through
Old 07-09-2015, 03:55 PM   #4
DustinS
DustinS's Avatar
Stock injectors are good past that on pump gas. 300whp+?
Old 07-09-2015, 04:09 PM   #5
megamarines
So it's not worth at all? Would there be any upsides to going with a bigger size or even a basic fuel pump upgrade?
Old 07-09-2015, 04:24 PM   #6
DustinS
DustinS's Avatar
You get to spend money...?
I don't think there is. Not until you go FI. Replacing the pump isn't the easiest thing in the world.
Old 07-09-2015, 04:44 PM   #7
megamarines
Well I'm not looking to /burn/ money, but looking to squeeze out any additional power if I can. If it doesn't help at all then it's really not worth it. I do appreciate the help, though thank you.
Old 07-09-2015, 05:48 PM   #8
Kodename47
Kodename47's Avatar
Drives: UK GT86
The car's not down on power due to not being able rich enough. Plus don't forget you have both sets of injectors. You could run almost 100% of the time DI on a NA car without issue. The DI gives you a lot of fueling headroom.
.: Stealth 86 :.
Kodename 47 DJ:
Old 07-09-2015, 06:25 PM   #9
CSG Mike
CSG Mike's Avatar
There's zero reason to upgrade injectors on a NA car, unless you're doing a V8 swap, or something...
Old 07-09-2015, 10:28 PM   #10
zkv476
zkv476's Avatar
Drives: 2014 SWP BRZ, MT
Injectors are one of those things that allow for more power headroom but provide zero additional power by themselves. Think stuff like axles, forged pistons, rods, valve springs (not counting changed CR and stuff like that.)
The answer is racecar. Always.
zkv476 is offline   Reply With Quote
Old 07-09-2015, 10:52 PM   #11
swarb
Out of all the stuff you named, only header, oil cooler, and full exhaust is actually needed to make more power. The rest is pretty useless or is not even out yet.
Old 07-09-2015, 10:57 PM   #12
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
You really only need to upgrade injectors if they're maxing out or close to it.
You don't get more power by dumping more fuel in than required.
Old 07-10-2015, 03:02 AM   #13
MaximeT
MaximeT's Avatar
Drives: GT86-ACE-JRZ-RPF1-Essex
To make power, you need more air, not more fuel.
Like swarb said, header is what you need.
JRZ 12-32 | ACE 350 | Delicious Tuning | RPF1 | Essex Sprint | SPL | Powerflex | My Car
MaximeT is offline   Reply With Quote
Old 07-10-2015, 03:14 AM   #14
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
How does an oil cooler make more power?
Carlitoz3 is offline   Reply With Quote
after market fuel injector upgrade BRZ888 Forced Induction 4 02-24-2015 06:38 PM
wtb injector aem wideband kcam86 Want-To-Buy Requests 0 04-13-2014 08:46 PM
