Old 07-08-2015, 06:43 PM   #1
Ethan Wagner
Drives: Ultramarine frs
scion frs oft problems please help
I just installed the open flash tablet and I'm having some issues. First off my car is the automatic and it will no longer auto rev match and it will change gear for me when I hit redline in manual mode. Also my check engine light is on and I'm running the stage 2 uel tune. Does anyone know what's going on?
Ethan Wagner is offline   Reply With Quote
Old 07-08-2015, 06:47 PM   #2
mikool
mikool's Avatar
Drives: 14' Firestorm FR-S
What mods do you have on your car when you did the install?
Also if you're using the correct tune, then perhaps something happened in the installation. Try flashing back to stock, see if it's fixed, then reflash the tune you wanted.
mikool is offline   Reply With Quote
Old 07-08-2015, 06:48 PM   #3
D_Thissen
D_Thissen's Avatar
What code is it?
Old 07-08-2015, 06:48 PM   #4
Rota
Rota's Avatar
Drives: 2015 Series.Blue BRZ
You'll likely find more info in the Software Tuning forum.
Rota is offline   Reply With Quote
The Following User Says Thank You to Rota For This Useful Post:
WhiteFRS69 (07-08-2015)
Old 07-08-2015, 06:52 PM   #5
WhiteFRS69
WhiteFRS69's Avatar
Drives: 2014 Scion FRS
http://www.ft86club.com/forums/forumdisplay.php?f=88
Old 07-08-2015, 06:54 PM   #6
Ethan Wagner
I have tomei uel, invidia n1, Tanabe actress front pipe, and tomei overpipe
Old 07-08-2015, 06:56 PM   #7
Ethan Wagner
How do you reflash back to stock?
Old 07-08-2015, 07:12 PM   #8
Ethan Wagner
Originally Posted by D_Thissen View Post
What code is it?
Its a p0700 code and it was caused by the oft that's why my transmission is acting weird
Old 07-08-2015, 07:14 PM   #9
D_Thissen
D_Thissen's Avatar
Plug in OFT to the OBD2 port, then go to tune, then write, you should see your stock rom in the first slot. Also make sure you do not use any of the cars electrics (windows/lights) when you're flashing the rom.
Old 07-08-2015, 10:08 PM   #10
Ethan Wagner
Ok I'll try that, I'll let you know if it works
Old 07-08-2015, 10:28 PM   #11
Tromatic
Youtube has utterly destroyed the ability to both read and write user manuals.
Or open or close the doors during the flash.
ETA: I get transmission related CEL if I disconnect the OFT or OBD dongle with the ignition (power) on.
The Following 4 Users Say Thank You to Tromatic For This Useful Post:
Chimera (07-09-2015), Tcoat (07-09-2015), Thedishdoc (03-26-2019), tyrantcf (07-08-2015)
Old 07-08-2015, 10:54 PM   #12
D_Thissen
D_Thissen's Avatar
Sounds good. Yeah by anything electric, I mean anything and everything in the car (Doors/Windows/Lights/Horn/HVAC/Radio/Gas/Brake/Clutch).
Old 07-08-2015, 11:02 PM   #13
Ethan Wagner
i just tried it and it didn't work the ecu is back to original file but it's still not rev matching!
Old 07-08-2015, 11:06 PM   #14
D_Thissen
D_Thissen's Avatar
I'd take it to the dealership and play dumb. I don't think the OFT had anything to do with it though. Maybe just a coincidence that the light came on at the same time.
Scion Canada warranty problems UMB FR-S CANADA 14 07-08-2015 10:44 AM
Dealer/Scion problems rucfj159 Scion FR-S / Toyota 86 GT86 General Forum 34 03-19-2015 09:24 PM
ACT 6 Pug Problems, anyone have it like me? kombatlion Engine, Exhaust, Transmission 12 08-06-2014 11:30 AM
Transmission problems, oil leaks and detonation problems.. turboviper Issues | Warranty | Recalls / TSB 4 06-18-2014 04:01 PM
Do you think this car is going to have some problems? Huss Scion FR-S / Toyota 86 GT86 General Forum 45 03-21-2012 01:48 PM
