| View Poll Results: What weight oil do you run for track days? | |||
| 0W-20 |
98 | 40.66% |
| 5W-20 |
12 | 4.98% |
| 0W-30 |
21 | 8.71% |
| 5w-30 |
76 | 31.54% |
| 10W-30 |
7 | 2.90% |
| 0W-40 |
16 | 6.64% |
| Other |
11 | 4.56% |
| Voters: 241. You may not vote on this poll | |||
#43 | |
Drives: Neptune GR86
Viscosity grade SAE J 300 0W-20 Density at 20°C (68°F) ASTM D1298 0.838 Viscosity at 40°C (104°F) ASTM D445 48.6 mm²/s Viscosity at 100°C (212°F) ASTM D445 8.8 mm²/s HTHS viscosity at 150°C (302°F) ASTM D4741 2.7 mPa.s Viscosity index ASTM D2270 162 Pour point ASTM D97 < -50°C / < -58°F Flash point ASTM D92 238°C / 460.4°F Sulfated ash ASTM D874 0.8% weight TBN ASTM D2896 8.4 mg KOH/g Colder
#44 |
Drives: 2004 Subaru Forester 2.5XT
The colder oil is thinner at 100C, but it doesn't list the HTHS. It also has a very high Viscosity Index which usually points to better quality base stocks. I'm guessing that it has at least some esters in it or is even predominately ester based.
Neither one appears to be very thick though (e.g. thinner than Red Line) and the visocisty is right in the middle with the hotter oil being very slightly thicker. Not sure if that little of a difference in viscosity is attributable to the actual thickness at 100C, but maybe the oil formulation itself. The other thing about a high Viscosity Index is that high VI oils are supposed to have less viscosity change. Under hard use, a lower VI oil could thicken up quite a bit due to oxidation. This can be seen with used oil analysis, especially if you use a lab that tests for oxidation. I'm guessing the cooler one is pricier. Is it a Euro oil or Eneos Sustina? Last edited by bluesubie; 07-01-2015 at 10:13 AM. |
#45 | |
![]() ![]() http://www.penriteoil.com.au/pis_pdf...MAY%202012.pdf |
| The Following User Says Thank You to bluesubie For This Useful Post: | IBill4You (07-01-2015) |
#46 |
Drives: Fast
http://www.speedtalk.com/forum/viewt...hp?f=1&t=31363
Good read on oil temps. Pennzoil Ultra looks pretty good. |
#47 | |
#48 | |
Drives: 2015 Subaru BRZ
#49 |
#50 |
| Scratches from Window Usage? | DieselxIndustry | Issues | Warranty | Recalls / TSB | 27 | 03-08-2015 08:03 PM |
| Help: keyless access trunk usage | ohtheantics | BRZ First-Gen (2012+) — General Topics | 13 | 09-07-2013 02:17 AM |
| Track Day: Upcoming Joey G Open Track Day for ADVANCED Drivers, Aug 20 NJMP Lightning | AZP Installs | NY / NJ / CT / PA | 11 | 08-20-2012 11:31 PM |
| Stock tires usage in winter? | ft86Fan | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 22 | 07-13-2012 09:38 AM |
