View Poll Results: What weight oil do you run for track days?
0W-20 98 40.66%
5W-20 12 4.98%
0W-30 21 8.71%
5w-30 76 31.54%
10W-30 7 2.90%
0W-40 16 6.64%
Other 11 4.56%
Voters: 241. You may not vote on this poll
Old 07-01-2015, 12:14 AM   #43
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Originally Posted by bluesubie View Post
It depends on the oil company.
Really it comes down to what information they provide and what they include on their product data sheets. Mobil1, Red Line, Motul, Amsoil, Pennzoil and a lot of others are good at posting their data sheets with the relevant information.
http://www.mobil.com/USA-English/Lub...l_1_5W-20.aspx
http://www.amsoil.com/lit/databulletins/g2880.pdf
Castrol doesn't list actual HTHS (data sheet only lists the minimum)
http://msdspds.castrol.com/bpglis/Fu...20US%20PDS.pdf
And data sheets are always changing. Oils can be reformulated and the viscosity may change. Although if it's an API certified oil, it has to be resubmitted for certification if it's reformulated.
I tried copying a viscosity chart above but it didn't work. Here's a link:
http://www.widman.biz/English/Tables/J300.html
Note that a 20 grade viscosity can be anywhere from 6.9 to 9.29 cSt's at 100C and the HTHS can be 2.6 to 2.9. That's the newest SAE chart which also lists 8, 12, and 16 grade oils. OMG, you run 20 weight? That is SO thick!
This is the "hotter" oil
Viscosity grade SAE J 300 0W-20
Density at 20°C (68°F) ASTM D1298 0.838
Viscosity at 40°C (104°F) ASTM D445 48.6 mm²/s
Viscosity at 100°C (212°F) ASTM D445 8.8 mm²/s
HTHS viscosity at 150°C (302°F) ASTM D4741 2.7 mPa.s
Viscosity index ASTM D2270 162
Pour point ASTM D97 < -50°C / < -58°F
Flash point ASTM D92 238°C / 460.4°F
Sulfated ash ASTM D874 0.8% weight
TBN ASTM D2896 8.4 mg KOH/g
Colder
Old 07-01-2015, 09:39 AM   #44
bluesubie
Drives: 2004 Subaru Forester 2.5XT
The colder oil is thinner at 100C, but it doesn't list the HTHS. It also has a very high Viscosity Index which usually points to better quality base stocks. I'm guessing that it has at least some esters in it or is even predominately ester based.
Neither one appears to be very thick though (e.g. thinner than Red Line) and the visocisty is right in the middle with the hotter oil being very slightly thicker. Not sure if that little of a difference in viscosity is attributable to the actual thickness at 100C, but maybe the oil formulation itself.
The other thing about a high Viscosity Index is that high VI oils are supposed to have less viscosity change. Under hard use, a lower VI oil could thicken up quite a bit due to oxidation. This can be seen with used oil analysis, especially if you use a lab that tests for oxidation.
I'm guessing the cooler one is pricier. Is it a Euro oil or Eneos Sustina?
bluesubie is offline   Reply With Quote
Old 07-01-2015, 10:43 AM   #45
bluesubie
Originally Posted by IBill4You View Post
Is anyone running Shell Rotella Conventional 15w40? I'm looking for a good forced induction oil for only summer driving and with change intervals of 3k miles. I know a few years ago the motorcycle world was loving this stuff. It's also pretty cheap if I remember correctly. I thought synthetics were for lengthening change intervals, so why run them if they'll only be there for 3k miles?
That's too thin. Try finding some Penrite 25W70.
http://www.penriteoil.com.au/pis_pdf...MAY%202012.pdf
The Following User Says Thank You to bluesubie For This Useful Post:
IBill4You (07-01-2015)
Old 07-01-2015, 11:01 AM   #46
cab33
Drives: Fast
http://www.speedtalk.com/forum/viewt...hp?f=1&t=31363
Good read on oil temps.
Pennzoil Ultra looks pretty good.
cab33 is offline   Reply With Quote
Old 07-01-2015, 12:32 PM   #47
Andrew025
Andrew025's Avatar
Yep, sustina. The other is motul 8100 ecolite.
Old 07-01-2015, 01:14 PM   #48
IBill4You
Drives: 2015 Subaru BRZ
Hey bluesubie, thanks for the suggestion! I'm going to give that a try for my next oil change!
IBill4You is offline   Reply With Quote
Old 07-01-2015, 03:49 PM   #49
bluesubie
Eco-lite is ester based, and has higher levels of ZDDP, so it's no slouch. Were ambient temps exactly the same?
Old 07-01-2015, 05:34 PM   #50
Andrew025
Andrew025's Avatar
Within a few degrees.
Scratches from Window Usage? DieselxIndustry Issues | Warranty | Recalls / TSB 27 03-08-2015 08:03 PM
Help: keyless access trunk usage ohtheantics BRZ First-Gen (2012+) — General Topics 13 09-07-2013 02:17 AM
Track Day: Upcoming Joey G Open Track Day for ADVANCED Drivers, Aug 20 NJMP Lightning AZP Installs NY / NJ / CT / PA 11 08-20-2012 11:31 PM
Stock tires usage in winter? ft86Fan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 22 07-13-2012 09:38 AM
