Old 06-30-2015, 02:16 PM   #15
brady86
Drives: 2013 firestorm fr-s
so when i let off the throttle and cruise down while in gear and the afr is 20 i should not be concerned about that?
brady86 is offline   Reply With Quote
Old 06-30-2015, 04:57 PM   #16
steve99
Drives: FT86
thats normal on overrun, injectors are shut off to save fuel
brady86 (06-30-2015)
Old 06-30-2015, 05:12 PM   #17
brady86
alright I was a bit worried when i saw it go up to 20 lol but figured that was the reason. Guess its running good other then that
Old 02-05-2016, 01:00 AM   #18
Astroboy
Astroboy's Avatar
Drives: None
Where should my engine load be during idle?
Sent from my LG-D850 using Tapatalk
Astroboy is offline   Reply With Quote
Old 02-05-2016, 02:38 AM   #19
steve99
Drives: FT86
usually about 0.2 or 0.3 thats for NA car
Astroboy (02-05-2016)
Old 02-05-2016, 08:29 AM   #20
Astroboy
Astroboy's Avatar
Drives: None
Mine is sitting around 34 percent while at idle. Is this normal? I already swapped out the ecu 30 miles ago to. I'm turbocharged And my tuner raised my rpm so to 900 while at idle
Old 02-05-2016, 04:51 PM   #21
steve99
Drives: FT86
The load calculation is based on airflow reading from maf sensor so if idle is higher than normal then load will be higher than normal
Old 02-05-2016, 08:03 PM   #22
Astroboy
Astroboy's Avatar
Drives: None
Remember a while back you were helping me with cel p0018? Well I managed to swap out my ecm. Code hasn't came back on in 43 miles, thank god, but what I'm concern about is that my o2 sensor and evaporative system monitors are still incomplete. Since you know a lot about the way the ecu and p0018 work on this car, I was wondering you can help me with my issue
Old 02-05-2016, 08:37 PM   #23
steve99
Drives: FT86
If your turbo with ecutek, the ecutek software re-purposes the evap sensor and sometimes the rear 02 sensor for the flex fuel sensor.
The tuner may have done this.
If these are re-purposed or disabled ie the P0420 cat efficience cel code disabled then the readyness checks will never complete as the ecu code checks to the inputs .
not even ecutek forces readyness check to complete as far as i know
Old 04-18-2016, 03:33 PM   #24
Bzives
I just flashed the ECU yday and seem to have an LT Fuel Trim of 10.15% Is this too high? My car is stock Except for the TRD intake..
Brent
Bzives is offline   Reply With Quote
Old 04-18-2016, 03:55 PM   #25
steve99
Drives: FT86
Brent
If the ltft is only high at or around idle that likely ok if its off 10% all the time even at higher rpm that probably not the best. Usually it an indication intake issue (ie intake changed without re-scaling maf) or exhaust leak especially high positive ltft.
TRD intakes usually pretty close to stock maf scaling wise. It not unusual for ltft to be 8% or so on a stock car.
Old 04-18-2016, 11:04 PM   #26
Bzives
Ok I'll keep an eye on it, that 10 percent did happen to be at idle. Thanks for the info.
The Following User Says Thank You to Bzives For This Useful Post:
randomthoughts (06-12-2016)
Old 06-12-2016, 01:57 PM   #27
randomthoughts
Drives: 2014 White BRZ
I am hitting -1.3 flkc in 3rd gear pull between 6100 and 6500 rpm, is that bad?
http://www.datazap.me/u/randomthough...10-105-115-113
randomthoughts is offline   Reply With Quote
Old 06-12-2016, 05:14 PM   #28
freerunner
freerunner's Avatar
Drives: GT86
If IAM/advance multiplier stays at 1, nothing to worry about.
freerunner is offline   Reply With Quote
Ecutek logging Andreas83 Software Tuning 3 07-09-2018 10:57 PM
OP2 logging discussion AdrianG Software Tuning 37 10-06-2017 01:41 PM
BRZ Basic SQ Build hellyvin Electronics | Audio | NAV | Infotainment 13 07-22-2014 12:25 AM
IAT logging, what are you guys seeing? BRZPDX Forced Induction 3 03-02-2014 01:59 PM
