Old 06-29-2015, 01:02 AM   #15
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
Originally Posted by dustmann View Post
Yes the switch is normally grounded, so disconnecting it doesn't trigger a CEL or the pressure light on the dash. Note that you will lose that functionality (but it is replaced by your gauge) And yes, i just zip tied it out of the way.
Awesome. And as for temp in galley port... The SUBIE galley plug doesn't work right? Do u know the auto meter part number?
lbroskee is offline   Reply With Quote
Old 06-29-2015, 01:15 AM   #16
dustmann
Drives: '14 WRB BRZ Limited
DIY Request: install Oil Pressure & Temperature gauge
The innovate temp sender is 1/8" PT, so you will need a galley plug threaded as such. I don't know if autometer makes a galley plug for it. The one I linked to earlier at rally sport works well and is threaded correctly. Many galley plugs from other vendors are threaded for 1/8" NPT which will not work for the innovate sender. Just pay attention when you order it and you'll be fine.
dustmann is offline   Reply With Quote
The Following User Says Thank You to dustmann For This Useful Post:
Teclis (07-01-2015)
Old 06-29-2015, 09:19 AM   #17
Teclis
Marine Electrician
Teclis's Avatar
Drives: Toyota TRD86, 2014
Anyone tried to use this gauge (INNOVATE Oil temp & pressure gauge), with the mishimoto oil cooler? And know if I can fit them in the sandwitch plate?
from ft86speedfactory; Install Tip
If not installing any gauge sending units into the housing you will need to use Teflon tape on the side ports to get a good seal. Teflon tape can be found at a local hardware store for 99 cents. A tiny amount is then applied to the treads of the side allen bolts on the housing and then installed back in securely.
http://www.ft86speedfactory.com/mish...stat-1392.html
Teclis is offline   Reply With Quote
Old 06-29-2015, 09:27 AM   #18
dustmann
You will need female PT to male NPT adapters with the mishimoto kit. Not sure about the clearance for the pressure sender though.
http://m.mishimoto.com/subaru-brz-sc...er-kit-13.html
Teclis (06-29-2015)
Old 07-01-2015, 02:44 AM   #19
Teclis
Marine Electrician
Teclis's Avatar
Originally Posted by BRZtoni View Post
if your patient give me 2-3 weeks i can make a guide for the install..
i will be using innovate oil temp/pressure gauge which i sort of already installed
but will re-adjust to make fit for my turbo
and a AEM FAIL SAFE gauge as well
I'm using an ATX vent Pod Gauge
and block8head vent defrost gauge
Where did you install the temp and pressure sensor?
Any ?
Looking forward for your DIY install
Old 07-02-2015, 07:07 PM   #20
Teclis
Marine Electrician
Teclis's Avatar
I just got an e-mail from @[Mishimoto] about the ports in their housing at the oil cooler kit: Yes, the BRZ oil cooler kit comes with (2) 1/8" NPT ports so you can install sensors.
So now I know where to install my pressure and temp sensors
Any1 running the Innovate oil temp & pressure gauge know if I need any adapters for that?
Old 07-02-2015, 07:10 PM   #21
lbroskee
lbroskee's Avatar
Auto meter 2269
Converts 1/8 npt to 1/8 pt(also called Bspt)
Old 07-02-2015, 07:13 PM   #22
lbroskee
lbroskee's Avatar
Corrected my post to proper part #, but that's for pressure. Don't think it'll work with temp due to size
The Following User Says Thank You to lbroskee For This Useful Post:
Teclis (07-02-2015)
Old 07-02-2015, 08:34 PM   #23
Teclis
Marine Electrician
Teclis's Avatar
You sure thats the correct nr? When I search for "Auto meter 2269" I find 1/8" NPT female to 1/8" BSPT male, but I need the opposite
After the sensor is 1/"bspt (please correct me if it's not bspt, but with my search results thats what I found out) and the hole in the housing is 1/8" npt
Whey can't Innovate just use NPT instead of BSPT
But thanks for all the help anyhow!
Old 07-02-2015, 11:05 PM   #24
lbroskee
lbroskee's Avatar
That's it. Jus checked the part number in my box and its bolted onto the sender rt now perfectly
Old 07-02-2015, 11:18 PM   #25
Teclis
Marine Electrician
Teclis's Avatar
Okay Just gotta find one that is male 1/8" NPT to female !/8" BSPT then :P
Do you by any chance have a link to where you bought it? if you got it online thou
Old 07-02-2015, 11:41 PM   #26
lbroskee
lbroskee's Avatar
I think the description was wrong. This is the exact link i got it from
http://pages.ebay.com/link/?nav=item...obalID=EBAY-US
Teclis (07-03-2015)
Old 07-03-2015, 04:15 PM   #27
Teclis
Marine Electrician
Teclis's Avatar
Just talked with Casey from speedfactory, and long story short, the holes on the oil cooler housing are smaller than the sensors, so they can fit with an adapter but will prolly get bad readings..
so back to start again..
Old 07-03-2015, 04:32 PM   #28
lbroskee
lbroskee's Avatar
Just talked with casey, and long story short, the holes on the oil cooler housing are smaller than the sensors, so they can fit with an adapter but will prolly get bad readings..
Just use galley plug for temp and OEM pressure location for pressure. Disconnect OEM DUMMY LIGHT SENSOR AND TEPLACE WITH INNOVATE sensor using the adapter i linked. That's what I'll b doing
The Following 3 Users Say Thank You to lbroskee For This Useful Post:
fumanchu1 (05-13-2016), sroby (10-26-2020), Teclis (07-04-2015)
Oil Pressure and Temp Gauge Install BokChoiTV Cosmetic Modification (Interior/Exterior/Lighting) 14 12-29-2015 07:19 PM
Defi Oil Pressure Gauge and Cravenspeed Flexpod Gauge Mount Install and Review Tye300 Cosmetic Modification (Interior/Exterior/Lighting) 10 05-22-2015 01:48 PM
DIY request: Gauge install and wire routing mikepaul21 DIY (Do-It-Yourself) Guides 3 07-05-2014 01:43 PM
Plot your oil pressure vs temperature Gords_zenith Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 04-22-2014 07:09 PM
Temperature Gauge a dummy gauge? bambbrose BRZ First-Gen (2012+) — General Topics 40 08-19-2012 05:29 PM
