Old 06-27-2015, 12:51 PM   #1
owenxguo
owenxguo's Avatar
Drives: MY13 BRZ
Unhappy Power steering issue with slicks?
I got some new Hankook slicks for previous race, it was my first time run with slicks on BRZ. However with slicks the power steering stops working(or feel like no power steering) sometimes, mostly during high speed turns, some low speed turns too. But when I switch back to AD08R the problem disappeared. 2 of my other friends has same issue on their GT86, so I assuming this is a common problem with our cars??? I was wondering if any of you found out solution to fix this issue?
owenxguo is offline   Reply With Quote
Old 06-28-2015, 10:22 PM   #2
troek
troek's Avatar
Drives: 2012 Toyota 86
I had this happen to me on rs-3s this weekend right after a right hand sweeper transitions quickly to a sharp left. felt like i was driving a go kart for a second. theres a more extensive thread about this somewhere on here, by i think evasive motor sports or element tuning.
http://www.ft86club.com/forums/showthread.php?p=250538
troek is offline   Reply With Quote
Old 06-29-2015, 01:18 PM   #3
ja1217
Drives: 2004 Toyota RAV-4 5M
Yeah, this seems to be pretty common on the track, especially when you start using stickier tires. It happens to me all the time and you just get used to it. I'm so used to it now that I didn't even remember that this was an issue until I let someone else drive my car on the track and he complained about the steering getting weird at times.
ja1217 is offline   Reply With Quote
Old 06-30-2015, 06:53 AM   #4
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
If you are getting the sensation that the PS isn't working, it means that your car is too low for those slicks. We had this issue when running Continental Race Tires, we raised the car slightly and the binding went away in the turns.
-mike
AZP Installs is offline   Reply With Quote
Old 06-30-2015, 08:20 AM   #5
troek
troek's Avatar
what is actually binding, the tie rods at too extreme of an angle? im lowered only 30 mm and not even on slicks.
Old 07-02-2015, 12:09 AM   #6
owenxguo
owenxguo's Avatar
Drives: MY13 BRZ
-mike
I will try raise the car a bit and try, my car is running complete racerX arms with whiteline roll center adjuster tie rod joint, and I am not a fan lower my car a lot, didn't thought this way.
Old 07-02-2015, 01:01 AM   #7
Sleepless
Drives: 2016 FR-S
My impression is that this happens while trail braking too hard and ABS is about to engage. Easing off the brakes just a bit makes it go away.
I wonder if there is a power drop to the steering due to power used by ABS??
Sleepless is offline   Reply With Quote
Old 07-02-2015, 04:59 PM   #8
FingR-S
I got sucked into boost..
FingR-S's Avatar
Drives: Whiteout FR-S & Supercharged BRZ
I've experienced the same thing - My car is lowered as well on 245 17 RS-3's
I've learned not to trail brake on tight, high G corners. It definitely feels like ABS kicking in when you don't want it.. possibly affecting power steering.
I haven't tried the same tight roads with the pedal dance engaged (all aides off). I always run with TC turned off, but not the pedal dance as much. I need to try this and see if that helps at all.
For sale: 2013 BRZ Vortech Supercharged with nice updates.
Vortech Supercharger - Perrin exhaust - 245 RS3 on RPF1's
FingR-S is offline   Reply With Quote
Old 07-02-2015, 05:33 PM   #9
Sleepless
Drives: 2016 FR-S
I always use pedal dance.
Mine is lowered 20mm.
Have experienced this on several tires: PSS, AD08, RE11, NT01 and Z2 Star Spec
Old 06-02-2016, 12:11 PM   #10
Pat
Pat's Avatar
Drives: 2023 BRZ
-mike
FWIW I experience this on stock suspension with BFG R1S tires.
Old 06-04-2016, 02:31 AM   #11
zdr93523
zdr93523's Avatar
Drives: 2013 BRZ Limited
I run Pirelli DH Slicks and have the same thing occur. I think it is definitely the fact that we have waaaay more grip than the system was designed to operate with.
Instagram: @zdr_93523
Youtube: https://www.youtube.com/user/zdr93523
Pink Ribbon Racing 2013 BRZ Limited NASA ST2 and TT2 race car
www.makesmodels.com
www.camautomag.com
zdr93523 is offline   Reply With Quote
Old 06-04-2016, 02:42 AM   #12
Fish Eagle
Platinum Member
Fish Eagle's Avatar
Drives: Toyota 86 Vortech SC
I get the same with stock suspension and semi-slicks.
I'm so used to it, I don't notice it anymore.
Fish Eagle is offline   Reply With Quote
Old 06-27-2017, 07:29 AM   #13
Cybmx
Drives: 2016 Hyperblue Brz
Anyone got a fix for this yet?
Cybmx is offline   Reply With Quote
Old 06-27-2017, 09:44 AM   #14
Icecreamtruk
Drives: Track preped NA FRS
Man handle the steering wheel. The steering still works, you just have to use more force on it. Think of it this way, if you arent getting to the point it shuts off, you can still corner faster there
Icecreamtruk is offline   Reply With Quote
Steering issue under braking ! AJ PwR Tracking / Autocross / HPDE / Drifting 146 04-25-2023 05:47 PM
Possible Steering Issue ? TJB_902 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 06-24-2015 01:38 AM
power steering ender2664 Engine, Exhaust, Transmission 32 03-21-2015 04:16 PM
Steering wheel issue Khalis Issues | Warranty | Recalls / TSB 1 05-04-2013 01:19 AM
Electric power steering madfast Scion FR-S / Toyota 86 GT86 General Forum 33 10-13-2011 10:11 AM
