Old 06-15-2015, 06:54 PM   #29
Stark Performance
Drives: 2014 FR-S
Originally Posted by Campo View Post
It makes sense for you to put it there so the front can be jammed with other stuff.
I need to take some measurements, but could I use a Setrab Series 9 15 row cooler instead of the Series 6 19 row? Then the tranny and the oil cooler cores would be the same. The btu/hr is about the same between the two cores, but the psi delta is different.
Now I'm getting all aesthetic and stuff, trying to keep it even.
Or you could use a Series 6 19 row for the engine oil cooler core instead.
Stark Performance is offline   Reply With Quote
Old 06-15-2015, 07:21 PM   #30
Campo
Campo's Avatar
Drives:
Touché.
Tapatalk - because smoke signals would be too easy.
"Fuck, you've gone completely sideways, man."
~Raoul Duke
Gas is pretty cheap considering you're buying liquid explosive dinosaurs.
Campo is offline   Reply With Quote
Old 06-16-2015, 02:28 PM   #31
RFB
RFB's Avatar
Drives: FRS
Good call on the radiator space. I'm also considering a rad change to something more efficient plus changing the tstat setting.
What is hot weather where you're at? I live in Phoenix and it was 91*F at 7 this morning.
Same, more humidity, not as often or for as many days as the desert.
RFB is offline   Reply With Quote
Old 06-28-2015, 04:59 PM   #32
Weapon86
Weapon86's Avatar
Drives: 2014 Scion FRS monogram series
@Stark Performance are you guys still looking for an 86 with force induction setup? I have a vortech SC and i need a transmission cooler badly. My transmission overheated at the track even without the vortech.
Weapon86 is offline   Reply With Quote
Old 06-28-2015, 08:24 PM   #33
Astroboy
Astroboy's Avatar
Drives: None
I like how you cut a hole where the wheel guard is and placed that air passage. Where did you get it?
Astroboy is offline   Reply With Quote
Old 06-29-2015, 11:27 AM   #34
RFB
RFB's Avatar
Drives: FRS
If you need a grill for the wheel well, look under the front rt. bumper, there is a plastic removable grill access plate that is perfect to use in the well.
Just make sure you orient the fins for water flow.
Old 06-29-2015, 11:41 PM   #35
Stark Performance
Drives: 2014 FR-S
Yes, we are still looking for a vehicle for test fitting. Please send an e-mail to mike@starkperformanceparts.com with your contact info and your availability so we can setup an appointment.
Old 12-17-2015, 05:49 AM   #36
Efferalgan
Drives: 2025 BRZ, ex-2012 GT86
I'm planning to buy your kit to install it on the driver's side as the passenger side is already occupied by a HKS oil cooler. To do that I'm planning to buy a washer fluid recloation kit as well. What do you think will be easier to mate with your AT cooler, PTuning:
http://www.ptuning.com/product_insta...-reservoir.pdf
or the Kraftwerks one:
Efferalgan is offline   Reply With Quote
Old 12-17-2015, 06:05 PM   #37
Lonewolf
Lonewolf's Avatar
Drives: Moped
@Stark Performance
The Following User Says Thank You to Lonewolf For This Useful Post:
Efferalgan (12-18-2015)
Old 12-20-2015, 11:56 PM   #38
Stark Performance
Drives: 2014 FR-S
Either one of those may work for what you want to do, but it is impossible to tell until you actually mock it up and install the bumper. Even then, you'll need a flashlight to look up into the area and possibly use some blue tape and a bit of clay to determine if you have contact anywhere.
We will be working on an engine oil cooler kit that is a bit unique, but we won't have the initial prototyping done until mid to late February at the earliest. The cooler will be mounted in the driver side foglight area with a replacement windshield washer reservoir, much like what you are trying to do.
The Following 2 Users Say Thank You to Stark Performance For This Useful Post:
Efferalgan (12-21-2015), Rosticles (12-21-2015)
Old 08-11-2016, 08:50 AM   #39
Efferalgan
Here we go! Fits my ChargeSpeed bumper rather well. And the fluid washer tank from PTuning completes the setup. Let's see how cool the AT will be now!
The Following 2 Users Say Thank You to Efferalgan For This Useful Post:
Lonewolf (08-11-2016), Stark Performance (08-21-2016)
Old 08-14-2016, 07:44 PM   #40
ysu
Drives: Toyota 86 GTS Auto
Gents, question;
I've got a GTS I'd like to keep cool on track (Australian summers are hot!).
But the GTS has some lights down in the area where you install this radiator. Also, we drive on the correct - I mean the other - side of the road
So my question, really; what do you guys think about all this? RHD, no grille on the side... And finally, can you guys tell us your price, please? The link leading to the classifieds area is dead.
Thanks!
Toyota 86 GTS A/T, ACE 250/B header + OP, Apexi air filter, Whiteline camber bolts
ysu is offline   Reply With Quote
The Following User Says Thank You to ysu For This Useful Post:
Stark Performance (09-01-2016)
Old 09-01-2016, 04:50 AM   #41
JP86
JP86's Avatar
Drives: Toyota 86 GTS Aero Silver Auto
I'm in the exact situation as @ysu although I'm thinking of removing the fog lights as I honestly don't require them and replacing the cover with FR-S ones. My city is hot 100% of the time (if not wet) so a cooler for the track and everyday would be preferred
JP86 is offline   Reply With Quote
The Following User Says Thank You to JP86 For This Useful Post:
Old 09-01-2016, 07:02 AM   #42
churchx
churchx's Avatar
Drives: 2014 GT86
Why not place that rad in front of main rad at one side of main rad grill? If people use that place for mounting oil rads, why not put there on another side transmission one?
Automatic Transmission Fluid Cooler. ?? connor_lol Engine, Exhaust, Transmission 177 01-02-2023 09:02 AM
10% Off All SSP Automatic Transmission Upgrades! // DSG Performance Jason@DSG Transmission and Driveline 13 07-29-2014 01:19 PM
Automatic Transmission Cooler RYU Engine, Exhaust, Transmission 9 11-14-2013 02:15 PM
Automatic Transmission Cooler KGFRS86 Engine, Exhaust, Transmission 14 08-26-2013 08:55 PM
Automatic Transmission Cooler, necessary for autoX and Track? BRZPDX Engine, Exhaust, Transmission 4 07-11-2013 07:13 PM
