Drives: 13 FRS
Quick: Need torque spec for suspension component
Help! Putting together my car and I need the torque spec for this piece:
I think it's the trailing arm? Bottom of the picture, points to the bottom right. Starts in front of the wheel and connects to the bottom of the hub. |
#2 |
Drives: FRS!!!
check for it here? http://www.ft86club.com/forums/showthread.php?t=85760
not sure if its in there. |
#3 |
Drives: 2014 Subaru BRZ LTD 6MT
I'll tack onto this thread as I need an ASAP type of answer.
Installing RCE yellows today. First install like this for me. Jacked up car, removed front struts. No spring compressors. Hand tools. Took the strut into my lawn and stood on it and loosened top bolt. Quite difficult by myself, I should say. Installed RCE yellow onto strut. End of coil up against notch at bottom of strut, more tightly wound end down. I compressed spring with my knee atop Top mount and hand threaded bolt on, and then began going at it. Problem now is that it will not torque down. Something is spinning. If any saviors out there need more info, let me know. My thought is, if I leave it as is and put the car on the floor, will it maybe compress the spring a bit more and thus allow an extra crank or two where it might then torque down? Very amateur at this stuff. Thanks! |
#4 | |
Undisputed El Presidente
Drives: Zenki 37J ZN6
If you don't hold the strut in place the shaft will just spin and probably blew. There are two very good DIYs on this forum to explain the install without the use of spring compressors. Install DIY http://www.ft86club.com/forums/showthread.php?t=10842 Additional DIY for no spring compressor http://www.ft86club.com/forums/showthread.php?t=32414 |
| The Following User Says Thank You to finch1750 For This Useful Post: | ajaxthebetter (06-28-2015) |
| Torque spec for lug nuts | wrxneffect | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 37 | 09-06-2016 08:39 PM |
| Torque spec for steering wheel nut? | zooki | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 08-11-2015 02:14 PM |
| Oil pan torque spec? | Astroboy | Engine, Exhaust, Transmission | 1 | 12-23-2014 01:43 PM |
| Camber bolt torque spec | ayau | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 01-09-2013 10:30 AM |
| OptionJDM- Cusco Suspension Component | OptionJDM | Brakes, Suspension, Chassis | 27 | 11-09-2012 11:46 AM |
