Old 06-27-2015, 11:03 AM   #1
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
OFT Blank Screen when connected car
Shiv@Openflash
I updated my OFT few days ago so i want to check out and datalog as well
so i connected OFT and gave me screen blank. i double checked cable too
I disconnect and went back to computer and OFT recognize as it should be.
went back to car and same thing...nothing happens. screen is on but it's blank screen.
how to resolve this issue!!??
help!
Old 06-27-2015, 11:17 AM   #2
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Unplug and then plug it back in. It may take a few attempts to get it to boot up correctly once it gets in this state.
Shiv@Openflash is offline   Reply With Quote
The Following 2 Users Say Thank You to Shiv@Openflash For This Useful Post:
D_Thissen (06-27-2015), zc06_kisstherain (06-27-2015)
Old 06-27-2015, 11:25 AM   #3
RFB
RFB's Avatar
Drives: FRS
Which begs the next question -
What makes it get in this state ?
RFB is offline   Reply With Quote
Old 06-27-2015, 11:39 AM   #4
zc06_kisstherain
Drives: SWP BRZ
I connected my OBII through OBII extender then connected OFT.
i disconnected extender and directly connected my OFT and it worked!
it used to work fine somehow it stopped working? so i thought somehow i fried extender while connecting OFT
so i connected my extender to other vehicle, Camry and tested with my bluetooth torque and it worked fine.. so extender is working..SO WEIRD
what causing my extender doesnt work anymore in BRZ?
Old 06-27-2015, 12:09 PM   #5
D_Thissen
D_Thissen's Avatar
I believe if the connections aren't 100% plugged in, you will get the white screen. It happened to be last week and then I realized the connection with the OBD2 port was a bit loose.
Old 06-27-2015, 01:09 PM   #6
RFB
RFB's Avatar
Drives: FRS
So the OFT will not boot up if its not fully plugged in, makes sense.
What does not make sense is why it will continually not boot when it "gets in this state".
Does an improper or loose connection traumatize the tablets brain ?
What causes it to get into "this state" ? Why "several attempts" ?
Old 06-27-2015, 01:24 PM   #7
zc06_kisstherain
Drives: SWP BRZ
I probably am another victim of "loose OBII port" or my extender got fucked up by always plugged in.
Old 06-27-2015, 01:41 PM   #8
cameronjones239
cameronjones239's Avatar
Drives: 2015 Subaru BRZ Series Blue
It goes into this state when the OFT does not get enough power from my understanding. (poor connection) I have had it happen twice now, both when repositioning the oft to another location. Took a few tries to get it going again but is fine once it comes back.
cameronjones239 is offline   Reply With Quote
Old 06-27-2015, 02:57 PM   #9
elBarto
elBarto's Avatar
Drives: Toyota GT86
This has happened to me a few times also. Most of the times after I did an update.
Just disconnect en reconnect again and it should work.
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners
elBarto is offline   Reply With Quote
Old 06-27-2015, 03:06 PM   #10
zc06_kisstherain
Drives: SWP BRZ
i have another quick question. can i connect OFT while engine is running?
Old 06-27-2015, 03:12 PM   #11
cameronjones239
Yes you can, you won't run into any issues.
The Following User Says Thank You to cameronjones239 For This Useful Post:
Old 06-27-2015, 03:38 PM   #12
zc06_kisstherain
Drives: SWP BRZ
i thought something is gonna fry if i connect OFT to car while engine is running. lol
Old 06-27-2015, 03:53 PM   #13
D_Thissen
D_Thissen's Avatar
I think if you disconnect it while the car is running you might get a traction control and abs light show up.
Old 06-27-2015, 04:18 PM   #14
cameronjones239
I have yet to have any issue plugging and unplugging with the car on or off. Recently I switched over to run the extension cable with toggle switch, flip it on once I'm out of the garage and no CEL's or lights that have popped up
dashboard blank button replacement question relaxjim Hawaii 2 11-24-2014 03:52 PM
Part Number for USB/Aux Jack Blank Cover BRZNutt Electronics | Audio | NAV | Infotainment 1 12-15-2013 05:39 PM
BRZ Navigation screen blank Dvipercop Issues | Warranty | Recalls / TSB 2 11-03-2013 01:35 AM
T7019A HELP boot screen or splash screen change Trap63 Electronics | Audio | NAV | Infotainment 2 06-09-2013 05:04 PM
Blank Key Options stea1thbear Cosmetic Modification (Interior/Exterior/Lighting) 4 03-08-2013 07:41 PM
