-   Software Tuning (https://www.ft86club.com/forums/forumdisplay.php?f=88)
-   -   OFT Blank Screen when connected car (https://www.ft86club.com/forums/showthread.php?t=90714)
zc06_kisstherain 06-27-2015 11:03 AM
Shiv@Openflash
I updated my OFT few days ago so i want to check out and datalog as well
so i connected OFT and gave me screen blank. i double checked cable too
I disconnect and went back to computer and OFT recognize as it should be.
went back to car and same thing...nothing happens. screen is on but it's blank screen.
how to resolve this issue!!??
help!
Shiv@Openflash 06-27-2015 11:17 AM
Unplug and then plug it back in. It may take a few attempts to get it to boot up correctly once it gets in this state.
RFB 06-27-2015 11:25 AM
Which begs the next question -
What makes it get in this state ? :iono:
zc06_kisstherain 06-27-2015 11:39 AM
I connected my OBII through OBII extender then connected OFT.
i disconnected extender and directly connected my OFT and it worked!
it used to work fine somehow it stopped working? so i thought somehow i fried extender while connecting OFT
so i connected my extender to other vehicle, Camry and tested with my bluetooth torque and it worked fine.. so extender is working..SO WEIRD
what causing my extender doesnt work anymore in BRZ?
D_Thissen 06-27-2015 12:09 PM
I believe if the connections aren't 100% plugged in, you will get the white screen. It happened to be last week and then I realized the connection with the OBD2 port was a bit loose.
RFB 06-27-2015 01:09 PM
So the OFT will not boot up if its not fully plugged in, makes sense.
What does not make sense is why it will continually not boot when it "gets in this state".
Does an improper or loose connection traumatize the tablets brain ?
What causes it to get into "this state" ? Why "several attempts" ?
zc06_kisstherain 06-27-2015 01:24 PM
I probably am another victim of "loose OBII port" or my extender got fucked up by always plugged in.
cameronjones239 06-27-2015 01:41 PM
It goes into this state when the OFT does not get enough power from my understanding. (poor connection) I have had it happen twice now, both when repositioning the oft to another location. Took a few tries to get it going again but is fine once it comes back.
elBarto 06-27-2015 02:57 PM
This has happened to me a few times also. Most of the times after I did an update.
Just disconnect en reconnect again and it should work.
zc06_kisstherain 06-27-2015 03:06 PM
i have another quick question. can i connect OFT while engine is running?
cameronjones239 06-27-2015 03:12 PM
Yes you can, you won't run into any issues.
zc06_kisstherain 06-27-2015 03:38 PM
i thought something is gonna fry if i connect OFT to car while engine is running. lol
D_Thissen 06-27-2015 03:53 PM
I think if you disconnect it while the car is running you might get a traction control and abs light show up.
cameronjones239 06-27-2015 04:18 PM
I have yet to have any issue plugging and unplugging with the car on or off. Recently I switched over to run the extension cable with toggle switch, flip it on once I'm out of the garage and no CEL's or lights that have popped up
