Old 06-27-2015, 07:38 AM   #155
Cal3000
Drives: Panda FR-S
Is the lockout of 1st and reverse directly related to pedal travel? I just started getting locked out often. I can hear when the clutch engages. One time when i depressed the clutch pedal all the way to the floor, I heard it engage. My engagement is super low as it is. I'll adjust the pedal to see if it remedies the issue.
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
242whp/197ft-lb on Mustang Dyno (91 octane water)
284whp/223ft-lb on Mustang Dyno (E85)
Cal3000 is offline   Reply With Quote
Old 06-27-2015, 10:56 AM   #156
Readytoxplod
Tire Destroyer
Drives: Firestorm+snail
How new is your clutch? I know they had a revision of the stage 2 which seem to be working fine.
Readytoxplod is offline   Reply With Quote
Old 06-28-2015, 01:08 AM   #157
Fricke
Drives: Toyota GT86
Have a exedy stage 1 whit exedy fly wheel.
The first thing I noticed when installing the clutch, was the very poor liquid like grease that's follow the clutch kit.
Know as soon as I saw and felt the grease on my fingers that it would fail in lubricant.
So I did go for a high temp graffit grease, and i do a lot of o tracking whit the car, and also compete in time attack, and have never had any issues.
Fricke is offline   Reply With Quote
Old 06-28-2015, 02:21 AM   #158
Gopherboy6956
Gopherboy6956's Avatar
Drives: 13 BRZ Limited WRB
The grease they include with the clutch is ideal. Best case scenario is to use provided grease, not guess with aftermarket stuff.
Sent from my HTC6525LVW using Tapatalk
I plan to live forever. So far, so good.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925
Gopherboy6956 is offline   Reply With Quote
Old 06-28-2015, 01:55 PM   #159
Cal3000
Drives: Panda FR-S
I get locked out of 1st gear all the time now. lol. I need to contact them for solutions.
Old 06-28-2015, 11:59 PM   #160
Cal3000
Drives: Panda FR-S
So I adjusted the clutch pedal master cylinder rod as per this thread
http://www.ft86club.com/forums/showthread.php?t=8040
Adjusted it so that the cylinder stroke is further. Before, the catch point was very low, slightly above full depression. Now its about the midway point. After the adjustment, I haven't been locked out when before I would be locked out of 1st about 70% of the time. But I'll drive it for a week to see if the adjustment provided actual good results.
The Following 2 Users Say Thank You to Cal3000 For This Useful Post:
Astroboy (12-26-2015), midnight23 (06-30-2015)
Old 07-22-2015, 04:16 PM   #161
Scalzo
Scalzo's Avatar
Drives: Asphalt FRS <3
I'm having the same issue.
[ame="https://www.youtube.com/watch?v=g5LIHPXvUPE"]FRS problem - YouTube[/ame]
Scalzo is offline   Reply With Quote
Old 07-22-2015, 06:42 PM   #162
JDKane527
JDKane527's Avatar
Drives: Asphalt Scion FR-S
Update, it's been 18 months since I've had the kit, it would lock out occasionally. Now it's been occurring more frequently.
JDKane527 is offline   Reply With Quote
Old 07-23-2015, 12:09 PM   #163
Darryljr11
Sideways and Smiling!
Darryljr11's Avatar
Drives: Scion FR-S
Now im starting to get locked out of first gear and difficulty getting in and out of reverse. Anyone know what I need to do for a warranty claim?
Element Tuning 10:1 Pro Comp Long Block, Ptuning SS GT3076R turbo kit, Exedy Stage 2 Clutch, and a bunch of other stuff
Darryljr11 is offline   Reply With Quote
Old 07-23-2015, 01:21 PM   #164
FrX
Drives: 2013 Scion FR-S, 1993 Lexus SC300
I just want to add a point of data. Previously with my Stg. 1, I was having difficulty with 1st gear. When swapping my motor I reused the clutch, but I took the opportunity to carefully clean and grease the splines of the clutch disc and the input shaft. As of yet, about 3 months later, I have not had any trouble with the clutch.
FrX is offline   Reply With Quote
Old 07-23-2015, 03:54 PM   #165
Scalzo
Scalzo's Avatar
How are you going to claim it if your turbo'd?
curious because I am too and would love to claim it under warranty
Old 07-23-2015, 05:07 PM   #166
Darryljr11
Darryljr11's Avatar
Drives: Scion FR-S
No clue if that has any bearing. I will call exedy and o from there.
Old 07-30-2015, 11:56 PM   #167
midnight23
dying bird under the hood
Drives: 2013 SWP Limited BRZ
anyone else besides @Kiske using the revised stage 2 with the flywheel from the original stage 2 kit? I'm sick of the daily lock outs now and just looking for confirmation that the issues are still not returning after some usage.
Build Thread
Instagram
Old 07-31-2015, 08:29 AM   #168
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Never been locked out yet!
The Following 3 Users Say Thank You to Kiske For This Useful Post:
Astroboy (12-27-2015), midnight23 (07-31-2015), Sportsguy83 (08-02-2015)
Exedy Clutch KAR Engine, Exhaust, Transmission 28 01-03-2016 07:27 PM
Exedy Stage 2 Clutch alpine Engine, Exhaust, Transmission 21 09-09-2014 12:24 AM
Share your interesting experience when you bought your BRZ/FRS g0ast BRZ First-Gen (2012+) — General Topics 18 02-25-2014 12:39 PM
exedy clutch questions ft86me Engine, Exhaust, Transmission 8 02-13-2014 09:58 PM
