Old 06-23-2015, 02:12 PM   #127
WORKS
WORKS's Avatar
Drives: WORKS CARB Legal Turbo BRZ
Originally Posted by calmtigers View Post
So how much would this cost for the whole package?
Also would be this be tunable on the OFT? I'm actually California local, would be curious to how much install might cost as well?
Please PM
Thanks!
Hi calmtigers,
PM sent.
Visit our commercial thread for pricing, purchasing and the like.
A base tune file is included, but you may also tune with OFT.
WORKS is offline   Reply With Quote
Old 06-23-2015, 02:20 PM   #128
WORKS
WORKS's Avatar
Originally Posted by tyrantcf View Post
Can you elaborate a little on this? I admit I was assuming the base maps were based on an otherwise stock car except for panel filter and maybe a catback/header back.
Minus the catback/header-back, you are correct. The base ECU calibration was created on an entirely stock vehicle with exception of our WORKS high-flow drop-in air filter installed.
The Following User Says Thank You to WORKS For This Useful Post:
tyrantcf (06-23-2015)
Old 06-23-2015, 02:57 PM   #129
tyrantcf
Drives: '16 WRX, CBR1000RR
Thanks!
This is at the top of my list.
One more question that I haven't seen:
Does the kit include a MAP sensor? Either way, what pressure MAP sensor is the base tune assuming? 3 bar? Stock?
Phantom ESC'd Build Thread (Retired):http://www.ft86club.com/forums/showthread.php?t=75293
tyrantcf is offline   Reply With Quote
Old 06-23-2015, 03:01 PM   #130
raven1231
Thanks!
Runs off the MAF not MAP.
Old 06-23-2015, 03:06 PM   #131
tyrantcf
Thank you
The Following User Says Thank You to tyrantcf For This Useful Post:
raven1231 (06-23-2015)
Old 06-23-2015, 07:18 PM   #132
WORKS
WORKS's Avatar
Originally Posted by stoked_on_spool View Post
Awesome news and price!
I'm VERY excited to see this kit and I hope it passes its CARB certification. I'll be awaiting that information and track impressions of people with this kit, but it works out perfect with approx 15k more miles until my warranty is up. Keep up the great work guys!
And fwiw, your base map that comes with the kit appears to get the car up and running well enough, but you recommend taking it to a tuner to get it dialed in better. Is my understanding correct?
Thanks,
Bret
Thank you very much!
The base tune is intentionally conservative due to the need for a degree of safety when creating a tune that will be used in many different cars in many different environments.
We recommend custom dyno tuning from a competent tuner if you want to get the very most out of your setup, but it is, of course, not a necessary procedure.
Cheers.
Old 06-23-2015, 08:01 PM   #133
WORKS
WORKS's Avatar
Originally Posted by LucidMomentum View Post
That is a good looking kit!
Thank you!
Old 06-23-2015, 11:26 PM   #134
F3RGY68
F3RGY68's Avatar
Drives: FR-S 10 Series MT, Honda 919
I've been very interested but missing or misunderstanding numbers. What can one expect with just this kit and a high-flow air filter running on the base tune?
-The dyno from ghost is at 7.5psi, with aftermarket exhaust
-The description says up to 92hp gain, but the dyno on page 4 looks around 75whp gained. (225-150) Dyno also includes aftermarket exhaust...
Not bashing anything; it looks great. It's just a huge investment, not to mention for anyone being an early adopter.
F3RGY68 is offline   Reply With Quote
Old 06-24-2015, 12:23 AM   #135
tyrantcf
The dyno graphs that works released will be very close to what you can expect. They aren't gaining much from the front pipe, and the header is still OEM.
Works also quoted crank hp numbers in their 92hp gained statement, not whp.
WORKS (06-24-2015)
Old 06-24-2015, 01:34 PM   #136
WORKS
WORKS's Avatar
Tyrant is correct.
The dyno graphs display readings at the wheels.
The quoted gains are, as it states, at the crank.
Lastly, as he explained, the dyno graphs we published will be very close to what you can expect from just a high-flow drop-in air filter and Stage 2.
Cheers.
Old 06-25-2015, 05:40 PM   #137
WORKS
WORKS's Avatar
Our intercooler radiator blends in nicely behind the grill.
tyrantcf (06-25-2015)
Old 06-26-2015, 09:16 PM   #138
WORKS
WORKS's Avatar
Originally Posted by Kaotic Lazagna View Post
Cool. Thanks for answering. Waiting for that CARB approval
Originally Posted by surfuxalot View Post
hey, just wondering, is this kit carb approved?
Thanks,
Thank you @WORKS!
I'm out here in CA so I hope your CARB certs go well too!
Can't wait to see this kit in action, just the amount of oomph this car needs!
Either way, hope the CARB papers get thru!
It's official!
The WORKS Stage 1 and Stage 2 Turbo Kits are the first FR-S/BRZ turbo kits to be granted a CARB Executive Order!
Under CARB Executive Order D-748, the installation of our WORKS Stage 1 and Stage 2 Turbo Kits are exempt from the prohibitions of Section 27156 of the Vehicle Code for 2013 through 2016 model year Subaru BRZ and Scion FR-S vehicles.
What does that mean? 50 state smog legal versions of our Stage 1 and Stage 2 Turbo Kits will soon be available!
Stay tuned for more details and pre-ordering.
Cheers,
WORKS Motorsports
The Following 22 Users Say Thank You to WORKS For This Useful Post:
AyJay (07-23-2015), Bach415 (06-27-2015), BigFatFlip (06-27-2015), clayrush (06-26-2015), DeliciousTuning (06-28-2015), DriftinFRS (06-28-2015), GhostOp86 (06-26-2015), hmong337 (06-28-2015), JonAvalon (06-26-2015), Kaotic Lazagna (06-27-2015), khantran04 (03-01-2016), Lonewolf (06-29-2015), LucidMomentum (06-29-2015), protpibe (06-27-2015), raven1231 (06-27-2015), surfuxalot (06-27-2015), Trefoil (06-29-2015), turtlefeeder (07-19-2016), Tylub (08-02-2015), tyrantcf (06-26-2015), Xero-Limit (06-27-2015), zoth (06-28-2015)
Old 06-26-2015, 09:39 PM   #139
stoked_on_spool
Drives: 2013 BRZ, SSM, Limited, M/T
WORKS Motorsports
Great news guys!!!
Can't wait to see a couple of these kits out in the wild! I'm running buttonwillow race track this weekend and it's 110 F outside right now... how do you think the turbo kit will hold up in this kind of heat during HPDE's?
(And yes, I already have an oil cooler. lol)
stoked_on_spool is offline   Reply With Quote
The Following User Says Thank You to stoked_on_spool For This Useful Post:
WORKS (06-29-2015)
Old 06-26-2015, 10:17 PM   #140
clayrush
Drives: FRS,09 370z, 00 CelicaGT-S, 85 300Z
Congratulations!
clayrush is offline   Reply With Quote
The Following User Says Thank You to clayrush For This Useful Post:
WORKS (06-29-2015)
P&L Motorsports Stage 1 Turbo Kit Build Thread P&L Motorsports Forced Induction 31 10-25-2017 04:26 AM
WORKS Stage 1 Turbo Kit - Officially Released! - Now CARB Compliant/SMOG Legal WORKS Forced Induction 230 08-11-2016 06:01 PM
Stage 2 Cosworth Kit Preview!!!! Titanmotorsports Forced Induction 377 04-01-2015 07:29 AM
WORKS Stage 1 Turbo Kit Pre-Release Offer - Over $800 Discount! WORKS Forced Induction 107 11-22-2014 12:15 AM
WORKS Stage 1 Turbo Kit Pre-Release Offer WORKS Northern California 31 11-11-2014 07:24 PM
