Old 06-17-2015, 03:39 PM   #113
surfuxalot
Drives: Toyota Frs
Originally Posted by LucidMomentum View Post
First post:
[/B]
That was feb 2014
surfuxalot is offline   Reply With Quote
Old 06-17-2015, 03:40 PM   #114
F3RGY68
F3RGY68's Avatar
Drives: FR-S 10 Series MT, Honda 919
Yes, you can data log with the oft, as well as adjust tunes. Also, the map that comes with this is mean't for a stock car with the kit.
I meant send logs to Works or a tuning company for improvements and receive custom tunes. I was under the assumption the map was for a car with just the kit, maybe high-flow filter and exhaust. Main interest in this kit was for me to be able to install and flash myself. Otherwise ecutek with another kit installed at a shop...
F3RGY68 is offline   Reply With Quote
Old 06-17-2015, 03:44 PM   #115
tyrantcf
Drives: '16 WRX, CBR1000RR
Originally Posted by surfuxalot View Post
That was feb 2014
They're still waiting on approval. I'm sure it'll be posted on here as soon as @WORKS finds out.
Phantom ESC'd Build Thread (Retired):http://www.ft86club.com/forums/showthread.php?t=75293
tyrantcf is offline   Reply With Quote
The Following User Says Thank You to tyrantcf For This Useful Post:
raven1231 (06-17-2015)
Old 06-17-2015, 03:45 PM   #116
surfuxalot
Drives: Toyota Frs
oops, sorry, it was 4-10-15, my bad. New to this .
Old 06-17-2015, 03:46 PM   #117
surfuxalot
Drives: Toyota Frs
Oh, okay thanks very much
Old 06-17-2015, 03:48 PM   #118
tyrantcf
Can you elaborate a little on this? I admit I was assuming the base maps were based on an otherwise stock car except for panel filter and maybe a catback/header back.
F3RGY68 (06-17-2015)
Old 06-17-2015, 04:09 PM   #119
raven1231
I'm confused ha ah that's what I'm saying the map that they provide is for a stock car with just the turbo kit.
Old 06-17-2015, 04:10 PM   #120
raven1231
Sure you can e tune the car via logs, whether or not they would do it using the OFT is dependent on the tuner though. I'm sure if nothing else shiv would for a price.
Old 06-17-2015, 04:15 PM   #121
tyrantcf
Youre right. I read it as "the map isN'T meant for a stock car.
Carry on..
Old 06-17-2015, 09:31 PM   #122
calmtigers
Drives: 2014 Whiteout TRD FR-S 6MT
Nevermind stage 1 is $3299 I forgot lol yes stage 2 has mostly everything from stage 1 but uses an air to water intercooler instead of the heat dissipater tube, and runs at 12.5 psi instead of 7.4.
Awesome so doing some hypothetical math. If we were to take the stage 2 kit with an aftermarket UEL we can expect some decent gains.
I've also been looking closely and it seems with some tweaking might even be able to use the grimmspeed intake? Though the works routing is probably best.
Really considering this kit because it allows me to use my UEL header. I'll definitely need to do more research as I'm looking for a nice blow off sound as well which I'm sure is upgradable. Also my worry of reliability
"I love dinosaurs so much that I’ve based my life on burning as much black melted dinosaur flesh as I can on a daily basis...even the screaming sound of prehistoric reptilians being burnt through any of the classic Japanese four cylinders gives me great joy."
calmtigers is offline   Reply With Quote
Old 06-17-2015, 10:46 PM   #123
Fred E
Drives: WRB BRZ
With the way this kit is configured (MAF sensor before the turbocharger), a blowoff valve cannot be used. All air that has passed the MAF sensor has to stay within the system, or the ECU will end up injecting too much fuel and run too rich, since air that was accounted for (passed the MAF sensor) will be blown off instead of passed through to the combustion chamber. Therefore, a recirculating valve must be used to keep all intake air within the system.
(If I got any of that wrong, please feel free to correct me.)
Fred E is offline   Reply With Quote
The Following 2 Users Say Thank You to Fred E For This Useful Post:
calmtigers (06-18-2015), WORKS (06-22-2015)
Old 06-22-2015, 07:21 PM   #124
WORKS
WORKS's Avatar
Drives: WORKS CARB Legal Turbo BRZ
Our WORKS Stage 2 Turbo Kit has officially been released!
Commercial thread and web-store listing now live with pricing, purchasing and additional information!
See our commercial thread here: http://www.ft86club.com/forums/showt...74#post2296074
Cheers.
WORKS is offline   Reply With Quote
The Following 2 Users Say Thank You to WORKS For This Useful Post:
khantran04 (03-01-2016), raven1231 (06-23-2015)
Old 06-23-2015, 01:55 PM   #125
stoked_on_spool
Drives: 2013 BRZ, SSM, Limited, M/T
Cheers.
Awesome news and price!
I'm VERY excited to see this kit and I hope it passes its CARB certification. I'll be awaiting that information and track impressions of people with this kit, but it works out perfect with approx 15k more miles until my warranty is up. Keep up the great work guys!
And fwiw, your base map that comes with the kit appears to get the car up and running well enough, but you recommend taking it to a tuner to get it dialed in better. Is my understanding correct?
Thanks,
Bret
stoked_on_spool is offline   Reply With Quote
The Following User Says Thank You to stoked_on_spool For This Useful Post:
WORKS (06-23-2015)
Old 06-23-2015, 02:11 PM   #126
LucidMomentum
No Money, No Problems
LucidMomentum's Avatar
Cheers.
That is a good looking kit!
The Following User Says Thank You to LucidMomentum For This Useful Post:
WORKS (06-23-2015)
P&L Motorsports Stage 1 Turbo Kit Build Thread P&L Motorsports Forced Induction 31 10-25-2017 04:26 AM
WORKS Stage 1 Turbo Kit - Officially Released! - Now CARB Compliant/SMOG Legal WORKS Forced Induction 230 08-11-2016 06:01 PM
Stage 2 Cosworth Kit Preview!!!! Titanmotorsports Forced Induction 377 04-01-2015 07:29 AM
WORKS Stage 1 Turbo Kit Pre-Release Offer - Over $800 Discount! WORKS Forced Induction 107 11-22-2014 12:15 AM
WORKS Stage 1 Turbo Kit Pre-Release Offer WORKS Northern California 31 11-11-2014 07:24 PM
