View Poll Results: What weight oil do you run for track days?
0W-20 98 40.66%
5W-20 12 4.98%
0W-30 21 8.71%
5w-30 76 31.54%
10W-30 7 2.90%
0W-40 16 6.64%
Other 11 4.56%
Voters: 241. You may not vote on this poll
Old 06-17-2015, 03:58 PM   #29
1Cor10:23
1Cor10:23's Avatar
Drives: '13 Whiteout FR-S (M/T)
@CSG Mike @CSG David have you guys gone to 0W20? I've seen some posts where you guys have suggested both 5w30 and 0w20...just wanted to know what the latest thinking now is Also, if 0W20, any thoughts on oil pressure at redline?
Cheers.
1Cor10:23 is offline   Reply With Quote
Old 06-18-2015, 05:16 AM   #30
CSG David
CSG David's Avatar
Cheers.
It's fine, but we're using 5W30 for the FI setup. Make sure to use the Jackson Racing Oil Cooler kit as the temps are pretty rock solid during track use.
Old 06-25-2015, 11:17 PM   #31
FRStock
Drives: 13 FRS
So stock FRS should also run 5w-30 on the track? Or since it's not F/I run 0w-20?
FRStock is offline   Reply With Quote
Old 06-25-2015, 11:52 PM   #32
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Anyone notice different temps between different brands even when they're the same weight?
Recently changed and noticed temps in 210-220 range from just normal driving when previously it would be below 210 regularly.
A couple WOT pulls and its up to 240s, previously touching 220s.
Weather has been consistent as well.
I'm sure there's a bunch of different factors, just thought it was odd seeing that much of a difference back to back.
Old 06-26-2015, 11:02 PM   #33
sickmint79
Drives: bmw
if you are tracking i'd say run at least 5w30 IMHO.
i am also a big fan of amsoil signature series.
PointMeBy - auto enthusiast / 86 / car blog - https://www.pointmeby.com
IGoByPlane - travel/credit/auto experience blog - https://www.igobyplane.com
sickmint79 is offline   Reply With Quote
The Following User Says Thank You to sickmint79 For This Useful Post:
FRStock (06-26-2015)
Old 06-27-2015, 03:17 PM   #34
D K
Stig's dark passenger
Torco 10W-30 but going to a 15W-40 (because I have over a 1000 gallons laying around) or 20W-50
D K is offline   Reply With Quote
Old 06-30-2015, 07:03 AM   #35
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
I think a 10, 15 or 20W is going to be way too thick IMO.
-mike
AZP Installs is offline   Reply With Quote
Old 06-30-2015, 07:03 AM   #36
AZP Installs
Do you have a cooler on your car at all? Those temps seem pretty high for street driving if you have proper cooling.
-mike
Old 06-30-2015, 10:35 AM   #37
Andrew025
Andrew025's Avatar
-mike
I don't have a cooler.
Old 06-30-2015, 01:36 PM   #38
D K
-mike
Id rather it be too thick than too thin.
With the 10w30, I have over 10 trackdays and most of them with fairly decent power.
Old 06-30-2015, 02:29 PM   #39
bluesubie
Drives: 2004 Subaru Forester 2.5XT
But are they really the same weight? The number on the bottle is a grade, or a viscosity range. You can have oils on the low end of the grade, in the middle of the grade, and on the high end of the grade.
I'm not sure if it affects oil temp., but HTHS definitely affects oil pressure.
bluesubie is offline   Reply With Quote
Old 06-30-2015, 02:40 PM   #40
Andrew025
Andrew025's Avatar
What's the best way to figure that out?
I was going to name the oils, but didn't want to do so before getting some information to prevent a possible fanboy war and not getting information.
Old 06-30-2015, 04:21 PM   #41
bluesubie
It depends on the oil company.
Really it comes down to what information they provide and what they include on their product data sheets. Mobil1, Red Line, Motul, Amsoil, Pennzoil and a lot of others are good at posting their data sheets with the relevant information.
http://www.mobil.com/USA-English/Lub...l_1_5W-20.aspx
http://www.amsoil.com/lit/databulletins/g2880.pdf
Castrol doesn't list actual HTHS (data sheet only lists the minimum)
http://msdspds.castrol.com/bpglis/Fu...20US%20PDS.pdf
And data sheets are always changing. Oils can be reformulated and the viscosity may change. Although if it's an API certified oil, it has to be resubmitted for certification if it's reformulated.
I tried copying a viscosity chart above but it didn't work. Here's a link:
http://www.widman.biz/English/Tables/J300.html
Note that a 20 grade viscosity can be anywhere from 6.9 to 9.29 cSt's at 100C and the HTHS can be 2.6 to 2.9. That's the newest SAE chart which also lists 8, 12, and 16 grade oils. OMG, you run 20 weight? That is SO thick!
Old 06-30-2015, 05:12 PM   #42
IBill4You
Drives: 2015 Subaru BRZ
Is anyone running Shell Rotella Conventional 15w40? I'm looking for a good forced induction oil for only summer driving and with change intervals of 3k miles. I know a few years ago the motorcycle world was loving this stuff. It's also pretty cheap if I remember correctly. I thought synthetics were for lengthening change intervals, so why run them if they'll only be there for 3k miles?
IBill4You is offline   Reply With Quote
Scratches from Window Usage? DieselxIndustry Issues | Warranty | Recalls / TSB 27 03-08-2015 08:03 PM
Help: keyless access trunk usage ohtheantics BRZ First-Gen (2012+) — General Topics 13 09-07-2013 02:17 AM
Track Day: Upcoming Joey G Open Track Day for ADVANCED Drivers, Aug 20 NJMP Lightning AZP Installs NY / NJ / CT / PA 11 08-20-2012 11:31 PM
Stock tires usage in winter? ft86Fan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 22 07-13-2012 09:38 AM
