| View Poll Results: What weight oil do you run for track days? | |||
| 0W-20 |
98 | 40.66% |
| 5W-20 |
12 | 4.98% |
| 0W-30 |
21 | 8.71% |
| 5w-30 |
76 | 31.54% |
| 10W-30 |
7 | 2.90% |
| 0W-40 |
16 | 6.64% |
| Other |
11 | 4.56% |
| Voters: 241. You may not vote on this poll | |||
#29 |
Drives: '13 Whiteout FR-S (M/T)
@CSG Mike @CSG David have you guys gone to 0W20? I've seen some posts where you guys have suggested both 5w30 and 0w20...just wanted to know what the latest thinking now is
Also, if 0W20, any thoughts on oil pressure at redline?Cheers.
#30 |
It's fine, but we're using 5W30 for the FI setup. Make sure to use the Jackson Racing Oil Cooler kit as the temps are pretty rock solid during track use.
#31 |
Drives: 13 FRS
So stock FRS should also run 5w-30 on the track? Or since it's not F/I run 0w-20?
#32 |
Drives: Neptune GR86
Anyone notice different temps between different brands even when they're the same weight?
Recently changed and noticed temps in 210-220 range from just normal driving when previously it would be below 210 regularly. A couple WOT pulls and its up to 240s, previously touching 220s. Weather has been consistent as well. I'm sure there's a bunch of different factors, just thought it was odd seeing that much of a difference back to back.
![]() Last edited by Andrew025; 06-26-2015 at 12:42 AM. |
#33 | |
Drives: bmw
i am also a big fan of amsoil signature series.
PointMeBy - auto enthusiast / 86 / car blog - https://www.pointmeby.com
IGoByPlane - travel/credit/auto experience blog - https://www.igobyplane.com |
| The Following User Says Thank You to sickmint79 For This Useful Post: | FRStock (06-26-2015) |
#34 |
Stig's dark passenger
Torco 10W-30 but going to a 15W-40 (because I have over a 1000 gallons laying around) or 20W-50
#35 |
#36 | |
-mike |
#37 |
I don't have a cooler.
#38 |
#39 | |
Drives: 2004 Subaru Forester 2.5XT
I'm not sure if it affects oil temp., but HTHS definitely affects oil pressure. |
#40 | |
I was going to name the oils, but didn't want to do so before getting some information to prevent a possible fanboy war and not getting information.
#41 | |
![]() Really it comes down to what information they provide and what they include on their product data sheets. Mobil1, Red Line, Motul, Amsoil, Pennzoil and a lot of others are good at posting their data sheets with the relevant information. http://www.mobil.com/USA-English/Lub...l_1_5W-20.aspx http://www.amsoil.com/lit/databulletins/g2880.pdf Castrol doesn't list actual HTHS (data sheet only lists the minimum) http://msdspds.castrol.com/bpglis/Fu...20US%20PDS.pdf And data sheets are always changing. Oils can be reformulated and the viscosity may change. Although if it's an API certified oil, it has to be resubmitted for certification if it's reformulated. I tried copying a viscosity chart above but it didn't work. Here's a link: http://www.widman.biz/English/Tables/J300.html Note that a 20 grade viscosity can be anywhere from 6.9 to 9.29 cSt's at 100C and the HTHS can be 2.6 to 2.9. That's the newest SAE chart which also lists 8, 12, and 16 grade oils. OMG, you run 20 weight? That is SO thick!
#42 |
Drives: 2015 Subaru BRZ
Is anyone running Shell Rotella Conventional 15w40? I'm looking for a good forced induction oil for only summer driving and with change intervals of 3k miles. I know a few years ago the motorcycle world was loving this stuff. It's also pretty cheap if I remember correctly. I thought synthetics were for lengthening change intervals, so why run them if they'll only be there for 3k miles?
| Scratches from Window Usage? | DieselxIndustry | Issues | Warranty | Recalls / TSB | 27 | 03-08-2015 08:03 PM |
| Help: keyless access trunk usage | ohtheantics | BRZ First-Gen (2012+) — General Topics | 13 | 09-07-2013 02:17 AM |
| Track Day: Upcoming Joey G Open Track Day for ADVANCED Drivers, Aug 20 NJMP Lightning | AZP Installs | NY / NJ / CT / PA | 11 | 08-20-2012 11:31 PM |
| Stock tires usage in winter? | ft86Fan | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 22 | 07-13-2012 09:38 AM |
