Old 06-25-2015, 01:20 PM   #3319
Locust
Custom User Title
Locust's Avatar
Drives: 2015 Scion FR-S, 2012 OB Evo X MR
Send a message via AIM to Locust
Originally Posted by markw View Post
It came with the kind of meh wheels? I've only seen it with the TRD's but then I wasn't paying the premium. I'm fat dumb and happy with my 7" rpf1's and 71r's.
It absolutely came with the standard wheels. The only performance part it has (I'm not counting the quad exhaust) is the springs. Everything else you get in the same fashion as the other FR-S'.
LOCUST
2015 FR-S (STX) and 2012 Evo X MR
Instagram:
LocustAutoX
Sponsors:
DSGPerformance Drift Office Evil Apex Racing
Locust is offline   Reply With Quote
Old 06-25-2015, 03:19 PM   #3320
renfield90
The Stig's German cousin
Originally Posted by SeanRTR View Post
Bought a set of Sparco 16 inch +48 16x7 wheels in 215/45/16's Rival-S to try in the rear for the Pro Solo this weekend....I don't think this is going to be the answer, and the car looks ridiculous with 235/45/17 'Stones up front, and 215/45/16 Rival-S in the back, but I need to try something for the Pro's as I'm getting killed before the first turn. Initial drive had the steering wheel slightly off center...what's up with that? Put the Bridge stones back on in the rear and it went back to the (almost) perfectly straight position....
Props for trying something wild, but I don't see that working on several levels. I suspect you will have lots of oversteer, and your 60' times may actually be worse.
That said, good luck!
Old 06-25-2015, 03:47 PM   #3321
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
Sean, could it be that you're down on power a little? Maybe some electrical gremlins, timing being pulled, anything of that sort?
have you ever had it analyzed on a dyno with A/F monitoring etc.
Old 06-25-2015, 03:59 PM   #3322
SeanRTR
C-Street AutoX
SeanRTR's Avatar
I don't see it working either, but I need to try something. I don't think I could have drove the car much faster at the last Pro, and it came up just short. Tall tires just aren't that good off the line, so I went for the total opposite approach. My car has 54k miles on it now, but I don't feel it's down on power, it's just not as fast as the other cars from a dig, on 235/45/17 rear tires....
-2013 Scion FR-S C-Street
Gearhead Homes - Homes geared towards car enthusiasts: https://www.facebook.com/GearheadHomes.RealEstate
SeanRTR is offline   Reply With Quote
Old 06-25-2015, 06:05 PM   #3323
SeanRTR
C-Street AutoX
SeanRTR's Avatar
Originally Posted by Arigh View Post
Fastest car we've seen off the line in CS has been on a set of 245 Rival S, so why not go that direction?
Could run 245 all around, or do something weird like run staggered 225 or 235 front for better turn in, and 245 rear. It'd understeer, but you could always try to tune that out with the swaybar.
Edit: Actually, would it even understeer? You're in an FRS on the TRD springs, and if the spring rates are close to the quoted ones in some threads, the car should now oversteer a bit more.
My 60' times are actually good, they're about the same as Manfred's 245 Rival-S's, it's 60 feet, to the first braking zone I need to improve upon. I understand I'll be well into third on these tires on most national style courses, but again, I need to try something...and I'm not buying Penske shocks....Christ.
Also, I won a Match Tour last year on staggered 225/245 Rivals, it doesn't understeer.
Old 06-25-2015, 06:33 PM   #3324
markw
Drives: 2014 FR-S
Originally Posted by doggieboy09 View Post
The TRD equipped FR-S has already been put down for B-Street by SCCA. I personally don't see an issue for TRD parts on the FR-S for C-Street for the foreseeable future and it hasn't proven to be a significant advantage yet.
You need to go read your latest fastrack. All FRS including 1.0 are CS.
markw is offline   Reply With Quote
The Following User Says Thank You to markw For This Useful Post:
TrqlessWonder (06-25-2015)
Old 06-25-2015, 06:36 PM   #3325
simpleisbest
Senior Citizen
Drives: Scion FR-S
Originally Posted by solort View Post
I would think that the Toyota website saying that it is a port installed price means it is port installed...
http://uat.mobile.accessories.setbuy.../Wheels/YTMS80
2015 Scion FR-S
6252 - FR-S (6 Spd Auto)
18" FRS TRD Alloy Wheels w/Michelin Tires
Accessory Code: YTMS80
Port Installed MSRP: $1,849.00*
Part Number: 00016-21540-18
Part Number: 00016-22540-20
Part Number: PTR56-18130
Part Number: PTR56-18131
* Manufacturer's Suggested Retail Price, actual dealer price will vary and depend upon the dealer. Available in FL, GA, AL, SC & NC. Some features and options are not available on all models and may not be available separately. Images are for illustrative purposes only. Prices and accessory style subject to change without notice. See Dealer for details.
Maybe it's a southern thing
But I will let them make the decision...
I think those wheels are only port options for SouthEast Toyota. You may want to see if you contact anyone in SET to confirm whether or not the SET port option list is approved by Toyota Motor Sales. If so, I think you might have a case
Otherwise, the SAC may take factory options offered by SET as non-official, as they are not actually a Toyota company, but rather a private USA distribution company with the power to operate autonomously.
simpleisbest is offline   Reply With Quote
Old 06-25-2015, 08:23 PM   #3326
markw
Drives: 2014 FR-S
The 235/45-17 rears are like 3/4" taller than stock tires. That will KILL your 60 foot times if you don't have gobs of bottom end. If possible I always try to go for a slightly shorter tire than stock. 235/40 would be ideal, but since they're not available in the RE71, I went to 225/45 which is .3" taller . These are not drag cars, make up for the 60 foot times by nailing .520's or better on the tree.
Old 06-25-2015, 11:32 PM   #3327
SeanRTR
C-Street AutoX
SeanRTR's Avatar
Check my sixty times from Wilmington, I'm in the game with 2.2xx times, and .50x lights, you just have to launch at 5.5k to get the right wheel spin. but the tall tires do not hurt the 60 foot times, like you think. I just feel like once the tires hook up the car does not have enough low end torque to get going and keep up with the other cars.
Old 06-26-2015, 01:17 AM   #3328
doggieboy09
Sènior Member
doggieboy09's Avatar
Drives: '22 BRZ |'13 BRZ SSC (formerly)
I meant it has been proposed for BS but has been turned down.
My only real concern for an unfair advantage is the lowering springs because of the lower center of gravity that can't be achieved in my BRZ unless I move up to STX. I'm not too bothered by the sway bars, 18s.
But in general I'm not concerned about the TRD FR-S personally. All the more reason to be just that much better of a driver.
doggieboy09 is offline   Reply With Quote
Old 06-26-2015, 11:32 AM   #3329
qoncept
qoncept's Avatar
Originally Posted by 7thgear View Post
AFAIk there was an issue with sizing (not meeting scca requirements or something) but I gather that's done, they caterer to bare minimum 4 diameters and 6 sizes.
price is certainly nice
I'd love to hear reviews.
Tirerack lists 5 sizes across 4 diameters. Oops.
qoncept is offline   Reply With Quote
Old 06-26-2015, 11:33 AM   #3330
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
https://www.tirerack.com/tires/tires...del=Ecsta+V720
... lists 6?
Old 06-26-2015, 11:50 AM   #3331
qoncept
qoncept's Avatar
Wow, would you believe it changed in the last 15 minutes? My RS3s are pretty much toast so maybe I'll try them out, but I haven't tried RE71Rs to compare.
Old 06-26-2015, 11:57 AM   #3332
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
when I made my post yesterday it was already listed at 6
maybe your page was cached from back then when it was all ambiguous.
If they're a treaded V710 with some voodoo magic, I think it should be an amazing tire. Definitely would be nice to see Khumo back in the game at the street level.
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 05:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 12:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 01:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
