Old 05-27-2015, 07:06 AM   #323
R L Newb
Drives: LR BRZ Ltd, 06 STi
Let the car sit for awhile then check again, you want the oil in the pan not the engine when measuring. If it still reads low I would add more oil.
R L Newb is offline   Reply With Quote
The Following User Says Thank You to R L Newb For This Useful Post:
bizintine (05-28-2015)
Old 05-27-2015, 04:40 PM   #324
bizintine
bizintine's Avatar
Drives: 2013 whiteout frs
Thanks RL. I let the car sit overnight and the dipstick reads slightly above the bottom hole.
bizintine is offline   Reply With Quote
Old 05-27-2015, 09:05 PM   #325
JohnJuan
JohnJuan's Avatar
Drives: 2013 FR-S, Hot Lava; 2012 Z1000 CBO
Make sure it's level too. That can make it weird.
JohnJuan is offline   Reply With Quote
Old 05-28-2015, 08:22 PM   #326
JohnJuan
JohnJuan's Avatar
My analysis for the last set of dealer oil:
Old 06-19-2015, 10:07 PM   #327
fstlane
fstlane's Avatar
Drives: BRZ Limited
Originally Posted by fstlane View Post
Here's my UOA @ 25,000 miles (5,000 mile OCI) with 5qts Mazda 0w-20 Moly + 1qt Mobil One 0w-40. I'm using an AFE Dry panel filter and a black OEM oil filter.
Here's my 30,000 mile UOA using the same OCI, oil blend and filters listed above.
fstlane is offline   Reply With Quote
The Following User Says Thank You to fstlane For This Useful Post:
R L Newb (08-13-2015)
Old 06-20-2015, 03:56 PM   #328
sato
sato's Avatar
Drives: Dodge Patitas
Why the mix? Where do I find this magic Mazda oil? Dealer?
sato is offline   Reply With Quote
Old 06-20-2015, 10:38 PM   #329
fstlane
fstlane's Avatar
Drives: BRZ Limited
Yes, the Mazda 0W-20 GF-5 with moly can be purchased from the dealership for around $7.00 per quart. Adding the M1 0W-40 makes a slightly heavier 0W-20 and increases the HTHS for greater high temperature protection while maintaining a high VI. Search "Caterham blend BITOG" for more information.
sato (06-21-2015)
Old 06-25-2015, 04:16 PM   #330
rixter145
Sleep Chomper
rixter145's Avatar
1st uoa from blackstone. Was using Amsoil and I am running a turbo
rixter145 is offline   Reply With Quote
The Following User Says Thank You to rixter145 For This Useful Post:
Old 06-26-2015, 03:28 PM   #331
bluesubie
Drives: 2004 Subaru Forester 2.5XT
Which Amsoil 0W20 is this? Looks like Signature Series. I thought people generally ran more robust oils when boosted (Amsoil Dominator, Red Line, Motul 300V, or a thicker viscosity GF5 oil).
I definitely wouldn't extend the interval, and would possibly cut back on it, until you've absolutely confirmed that the wear metals are still from the break-in process.
Yes TBN is great showing the oil can be run longer, but what good is a high TBN if you have high wear?
bluesubie is offline   Reply With Quote
Old 06-26-2015, 03:38 PM   #332
rixter145
Sleep Chomper
rixter145's Avatar
Agreed. Amsoil 0w20 Signature synthetic with the green cap. I will do an oil change earlier this time around to see for sure. How would I confirm the wear metals are from the break-in process btw? Change the oil and have another analysis?
Thanks for the insight
Last edited by rixter145; 06-28-2015 at 03:30 PM. Reason: Got the oil brand and model
Old 06-29-2015, 08:57 AM   #333
bluesubie
Sometimes break-in wear metals linger around for 10-18k miles, depending on driving style and probably other factors (number of oil changes, how long you ran the factory fill, etc.). If everything drops on the next oil change it is likely just break-in metals.
The Following User Says Thank You to bluesubie For This Useful Post:
rixter145 (06-29-2015)
Old 06-30-2015, 07:40 PM   #334
billyk
billyk's Avatar
Drives: 2014 Argento FR-S
Well, I am one of those FRS owners that decided to wait until the first oil change interval and to take advantage of the dealer Toyota "free maintenance" offer.
Gotta say, the dealer seemed to have done a good, clean job. From the factory, the oil level was a scosh higher than the top mark, it didn't move any lower in 6500 miles, and the refill is exactly at the same level. The old oil still appeared to be very clean prior to refill, and the new oil is almost impossible to read on the stick.
For me, I am happy to stick with TGMO synth. Have to admit, it feels great to have fresh oil in there. 13,000 miles/7.5 months is the next interval.
billyk is offline   Reply With Quote
Old 06-30-2015, 10:12 PM   #335
Blorb
Drives: GBS BRZ
4th oil change, Toyota 0w-20 and OEM filter
Blorb is offline   Reply With Quote
The Following 2 Users Say Thank You to Blorb For This Useful Post:
R L Newb (08-13-2015), TofuJoe (01-03-2018)
Old 07-01-2015, 01:04 AM   #336
qqzj
Drives: MDX, Camry
Has anybody seen Blackstone produced any negative report for BRZ? If I have to use one sentence to summarize the results, my choice would be:
Any 0w20 works just fine!
LOL
qqzj is offline   Reply With Quote
DIY BRZ / FR-S Oil Change RallySport Direct DIY (Do-It-Yourself) Guides 169 09-01-2018 02:42 AM
First Oil Change Jehuty77 CANADA 14 08-09-2012 11:54 PM
When to do your first oil change, and why... MrBodyMassage Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 07-17-2012 07:43 PM
Do you change your own oil? If so, why? SteelReign Other Vehicles & General Automotive Discussions 76 04-15-2012 04:44 AM
