Old 06-22-2015, 10:41 PM   #1
tcroft91
tcroft91's Avatar
Drives: 2013 Scion FRS
new intake shudder at 3300-4000 rmp
i just installed a fabbed 3''intake sets the filter in the bumper it was designed off of the perrin my problem is it stutters when accelerating with driving it has about 80%gone away but you can still feel it a hair in 4th an in 5th an 6th a little more is the just the ecu learning or is it getting too much air maf was placed 8 inches from the t/b an there is a vacuum spot also mounted
tcroft91 is offline   Reply With Quote
Old 06-22-2015, 10:44 PM   #2
Turdinator
Señor Member
Turdinator's Avatar
What do you mean by shudder? Is it a vibration through the car or a noise?
1974 TA22 Celica
2013 86 GT
Old 06-22-2015, 10:58 PM   #3
DJCarbine
Thupercharged
DJCarbine's Avatar
Pictures of intake specifically where the MAF is installed?
Is the MAF in a different diameter tube?
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
The Following User Says Thank You to DJCarbine For This Useful Post:
celek (06-23-2015)
Old 06-22-2015, 11:11 PM   #4
tcroft91
tcroft91's Avatar
like a lack of power
i don't have anyway of putting pictures up
Old 06-22-2015, 11:11 PM   #5
tcroft91
tcroft91's Avatar
it is all 3in tubing
Old 06-22-2015, 11:42 PM   #6
steve99
Drives: FT86
A maf sensor does not measure the total air passing, it measures a sample and that reading is used to estimate the air flow in total.
As you have increased the diameter of the tube the maf sits in you have thrown this calculation way off.
You may also have turbulance issues
you wil definitely have to rescale you maf sensor . its a major sensor used to calculate engine load as well which the ecu uses extensivly for fueling timing and camm timing
you may be able to use the perrin 3" scaling a a rough starting point.
see maf scaling links below
Old 06-22-2015, 11:49 PM   #7
KoolBRZ
KoolBRZ's Avatar
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
If you haven't scaled the MAF that's a problem. Your fuel trims are going to be way off. In closed loop mode, (cruising, moderate acceleration, etc.) the ECU corrects the fuel mixture automatically, but this gets much worse in open loop mode, since the ECU can't use the same feedback to moderate fuel to air ratios, so don't floor it until you have the MAF scaled. A 3" intake is 125 to 150 % higher that the stock MAF multiplier. The airflow in this intake is also slower and so the torque dip is going to be more severe.
KoolBRZ is offline   Reply With Quote
Old 06-23-2015, 12:59 PM   #8
tcroft91
tcroft91's Avatar
how do I use romraider on my car?
Sent from my HTC One using Tapatalk
Old 06-23-2015, 06:04 PM   #9
steve99
Drives: FT86
you will have to do a bit of reading, see links below, romraider tips and also at romraider.com .
romraider allows you to edit the tables in the ecu rom then you can flash the edited rom
Intense rear wheel shudder during e-brake drifts SkAsphalt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 07-09-2014 01:05 PM
BMW M4 (and new M3) is BEAST. 430hp and under 3300 pounds jakoye Other Vehicles & General Automotive Discussions 18 09-28-2013 08:15 PM
Driveline shudder when lifting off throttle (not touching clutch) NYC BRZ Issues | Warranty | Recalls / TSB 6 10-19-2012 05:35 PM
