Old 09-12-2013, 11:18 AM   #127
charged86
charged86's Avatar
Originally Posted by industrial View Post
I've had my flywheel/clutch setup for around 10,000 miles now. Had the transmission oil changed the same time and it's always sounded this way. After reading some of the particulate laden pentosin threads in the maintenance forum, I might try out a heavier gear oil sooner than later.
Let us know! Thanks for pioneer-ing
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
Old 09-12-2013, 11:22 AM   #128
industrial
Add lightness!
industrial's Avatar
Drives: 17' WRX
Will do. I have to do something while I wait for cams.......
industrial is offline   Reply With Quote
The Following User Says Thank You to industrial For This Useful Post:
charged86 (09-12-2013)
Old 09-12-2013, 05:37 PM   #129
CajunFRS
Drives: Challenger R/T, CRX SI,
Any updates on cams?
CajunFRS is offline   Reply With Quote
Old 06-23-2015, 08:16 AM   #130
Enalband24
Drives: Subaru BRZ Limited MT
To revive an extinct thread....Figured I would share my experience as it was relevant.
First, little background...I have a vortech supercharger, had a LW crank pulley (currently replaced by fluidampr pulley), have a LW flywheel, LW driveshaft, shorter diff gearing, 2 way diff, and many more mods.
I was running a LW flywheel (ACT) and LW crank pulley (Perrin) for, ahhh, probably 8K miles. Here was my experience:
I did not have any CEL's or major issues, however, it was a bit rough to drive from a take off (jerky), as well as would idle like shit most of the time (constant AFR hunting), and on E85, would stall occasionally coming to a stop. I was confident it was not the tune, as my last tune did the same thing (delicious tuning) as my current tune (Moto-mike). I had always felt that the crank was a bit light from both ends and was causing these issues.
Now, I had seen this thread a while back and bought the fluidampr pulley to replace my LW pulley when it was convenient. FINALLY, I replaced it two days ago. As I had suspected, all my issues went away. No more AFR hunting, smoother take offs, and no more stalling, car runs butter smooth at idle, etc.
So, in summary, though the lightweight combo did not cause any CEL's or MAJOR issues, it definitely was not smooth, and certainly did not give any noticeable gains as compared to the annoyances it was causing me.
Enalband24 is offline   Reply With Quote
The Following 7 Users Say Thank You to Enalband24 For This Useful Post:
GhostOp86 (12-11-2015), Hostile_Kittens (09-22-2016), jeepmor (09-05-2024), Scootertribe (06-29-2017), Strife26 (07-07-2017), Toyota86.ir (03-03-2016), xkalelx (09-17-2015)
Old 06-23-2015, 10:02 AM   #131
Thorpedo
The SquadWhisperer
Mind elaborating on the AFR hunting? Idle/cruise?wot?
2013+14+15 Atlantic Region Motor Sports Autocross STX Champion
2013+14+15 Atlantic Region Motor Sports Overall Autocross Champion
2017 Bluenose Autosport Club Overall Rallycross Champion
Powered by Great North Performance, Jani-King Canada, and OK Tire.
Thorpedo is offline   Reply With Quote
Old 06-23-2015, 10:41 AM   #132
Enalband24
Only at idle. Cruise and WOT were perfect. I always keep a close eye on AFR's with my wideband.
It wasn't even minor AFR hunting, it would swing from low 13's to high 15's, the car would be revving at stop signs/stop lights. Kind of embarrassing at times...
EDIT: Thinking about it more...I suppose I should say that it is a possibility that the combo did not cause this, but rather exacerbated the inherent idle/dip issues already present in these cars. Just a thought.
The Following 2 Users Say Thank You to Enalband24 For This Useful Post:
GhostOp86 (12-11-2015), jeepmor (09-05-2024)
Old 06-23-2015, 11:44 AM   #133
Kodename47
Kodename47's Avatar
Drives: UK GT86
Probably would just need the idle stability calmed down a little to stop the "hunting" as it needs to overcome less inertia.
.: Stealth 86 :.
Kodename 47 DJ:
Enalband24 (03-07-2016)
Old 06-23-2015, 01:04 PM   #134
celek
Resident Gear Head
celek's Avatar
No known issues as of yet the crank trigger on the flywheel would only be a concern, but since it is a separate piece and not integrated into the flywheel there should not be any adverse effects.
celek is offline   Reply With Quote
The Following User Says Thank You to celek For This Useful Post:
Aftermarket Crank Pulley Install Enigmus DIY (Do-It-Yourself) Guides 305 02-04-2019 11:37 PM
Perrin Crank Pulley now available milenko11 Engine, Exhaust, Transmission 96 12-10-2017 06:45 PM
Agency Power Crank Pulley / Clutch Masters Flywheel vividracing Engine, Exhaust, Transmission 67 11-07-2012 02:35 PM
Crank Pulley and the warranty Brimford Scion FR-S / Toyota 86 GT86 General Forum 4 07-08-2012 03:47 PM
