Old 06-21-2015, 07:13 PM   #15
Calum
That Guy
Drives: 2013 asphalt FRS MT
Originally Posted by Rybot View Post
That is only a single system for the crankcase and not PCV it seems.
There's no reason you couldn't use two, one for each part of the system.
Old 06-21-2015, 08:07 PM   #16
Rybot
Rybot's Avatar
Drives: Subaru BRZ Series.Blue
I know. I just wanted one catch can that is able to cover both vapor escapes.
Also, it's usually cheaper to have it packaged with two inlets instead of two separate cans. Not looking to spend tons on a catch can.
Rybot is offline   Reply With Quote
Old 06-21-2015, 09:45 PM   #17
Calum
That Guy
If you want to run a closed system you'll need two segregated cans. They can be attached together, but they have to act as two separate units.
The Following 2 Users Say Thank You to Calum For This Useful Post:
CSG Mike (06-22-2015), Rybot (06-22-2015)
Old 06-22-2015, 12:08 AM   #18
Rybot
Rybot's Avatar
Ah, very well. I thought it might be down to that.
Welp, guess I'll just have to save for a bit longer if I'm to go with Radiums then.
Old 06-22-2015, 05:53 AM   #19
scarfo
Drives: gts 86
noob question.
Is it possible to recirculate a vta catch can like the fullblown kit,
By removing the filter/baffle and piping the vapour back into the intake?
I ask as It's already installed and am
Now trying to get my turbo kit to pass Australian emissions testing and Nothing in the engine bay can VTA( I would then return it to baffled/filtered once passed)
Cheers
scarfo is offline   Reply With Quote
Old 06-22-2015, 10:12 AM   #20
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
This guy knows closed systems.
Old 06-22-2015, 10:33 AM   #21
Rybot
Rybot's Avatar
So it seems. I figured going into this I'd need two separate cans.
Old 06-22-2015, 10:55 AM   #22
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Crawford catch can is for both sides and recirculated. Problem solved.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Rybot (06-22-2015)
Old 06-22-2015, 12:57 PM   #23
Rybot
Rybot's Avatar
That looks like it would work were it not for the giant AEM strut bar I use.
If I can find the dimensions, I'll probably be getting this if it fits. If not, Radium it is.
Old 06-22-2015, 01:05 PM   #24
Calum
That Guy
LOL,
Jackson Racing engine oil cooler for NA applications CSG Mike Engine, Exhaust, Transmission 107 12-01-2021 04:03 PM
P&L Oil Cooler for Forced Induction Applications!! Compatible with FMICs!!! P&L Motorsports Forced Induction 9 03-26-2017 01:27 PM
Supporting Mods For F/I Applications Tansey86 Forced Induction 59 02-26-2013 01:42 AM
Oil Cooler kit for FI applications, getting one? JoeBoxer Forced Induction 84 01-20-2013 09:48 AM
